代码挑战:迁移0元素|Java
Jet Ding 发表于 2020/09/30 16:04:50 2020/09/30
【摘要】 Given an array nums, write a function to move all 0's to the end of it while maintaining the relative order of the non-zero elements.Example:Input: [0,1,0,3,12]Output: [1,3,12,0,0]Note:You must do ...
Example:
Input: [0,1,0,3,12]
Note:
  1. You must do this in-place without making a copy of the array.
  2. Minimize the total number of operations.
方案:
class Solution {
    public void moveZeroes(int[] nums) {
        int index = 0;
        for (int i = 0; i < nums.length; i++) {
            if (nums[i] != 0) {
                nums[index++] = nums[i];
        while (index < nums.length) {
            nums[index++] = 0;
测试案例:
   @Test
    public void test1() {
        Solution solution = new Solution();
        int[] nums = { 0, 1, 0, 3, 12 };
        solution.moveZeroes(nums);
        int[] expected = { 1, 3, 12, 0, 0 };
            Assert.assertEquals(nums[i], expected[i]);
    @Test
    public void test2() {
        int[] nums = { 1, 9, 8, 4, 0, 0, 2, 7, 0, 6, 0, 9 };
        int[] expected = { 1, 9, 8, 4, 2, 7, 6, 9, 0, 0, 0, 0 };
