GaussDB(DWS)存储过程中实现作业执行过程日志记录方法
dual 发表于 2020/08/28 15:58:56 2020/08/28
【摘要】 本文提供了GaussDB(DWS)存储过程实现作业执行过程的日志记录方法示例,根据该示例可以更好的为业务开发提供业务的日志审计和作业审查工作。
具体示例如下:
--存储过程日志记录
--创建日志表
create table fun_all_execute_log(
id varchar2(32) default lower(sys_guid()),
pro_name varchar2(60),
patch_num int,
log_date date,
deal_date date,
log_mesage text);
--创建测试表和数据准备:
create table test(no int,id int);
insert into test select dbms_random.value(1,1000)::int,generate_series(1,100);
--创建业务存储过程:
CREATE OR REPLACE FUNCTION fun_affect_rows(out exe_info text)
  LANGUAGE plpgsql
  as $$
  declare v_count int;
  pro_result text;
  fun_name   text;
  patch_no   int;
begin
  fun_name := 'fun_affect_rows';
  select nvl(max(patch_num), '0') + 1 into patch_no from fun_all_execute_log where pro_name = fun_name;
  insert into test  values (dbms_random.value(1, 1000)::int,generate_series(1, dbms_random.value(10000, 20000)::int));
  GET DIAGNOSTICS v_count = ROW_COUNT;
  exe_info = sysdate || '# step1:本次插入数据量:' || v_count || '行。;';
  delete from test where no = dbms_random.value(1, 1000)::int;
  exe_info = exe_info || sysdate || '# step2:本次删除数据量:' || v_count || '行。;';
  update test set id = dbms_random.value(1, 100)::int where no = dbms_random.value(1, 1000)::int and c1 = 0;
  exe_info = exe_info || sysdate || '# step3:本次更新数据量:' || sql%rowcount || '行。';
  RAISE INFO '本次信息为: %', exe_info;
  insert into fun_all_execute_log(pro_name, patch_num, log_date, deal_date, log_mesage)
  values (fun_name,patch_no,sysdate,split_part(regexp_split_to_table(exe_info, ';'), '#', 1),split_part(regexp_split_to_table(exe_info, ';'), '#', 2));
EXCEPTION
  WHEN OTHERS THEN
    pro_result := exe_info || sysdate || '# z exception error message is: ' || sqlerrm;
    values(fun_name,patch_no,sysdate,split_part(regexp_split_to_table(pro_result, ';'), '#', 1),split_part(regexp_split_to_table(pro_result, ';'), '#', 2));
END; $$;
--调用存储过程
select fun_affect_rows();
--查询日志
select * from fun_all_execute_log order by log_date desc,deal_date,log_mesage;
