OPPO 5G CPE Omni Released
ltemodem 发表于 2020/08/26 17:20:36 2020/08/26
【摘要】 OPPO 5G CPE Omni Released
The OPPO Mobile Telecommunications from China's Guangdong has announced a new NR/LTE terminal "OPPO 5G CPE Omni". It is a stationary wireless LAN router called the customer premises equipment (CPE) that supports the NR method of the 5th generation mobile communication system (5G).
This is the first 5G CPE for Guangdong OPPO Mobile Telecommunications. The CPU is equipped with Arm Cortex-A53 and the operating frequency is 2.2GHz. The communication modem is equipped with Qualcomm Snapdragon X55 5G Modem-RF System. There are two color variations, Classic White and Mystic Blue.
The new 5G CPE device offering speeds of up to 7.5 Gbps. The Oppo 5G CPE Omni supports millimeter wave and sub-6 GHz dual network frequency bands as well as 5G connections via the company’s “O-Motion 360-degree” antenna solution. The 5G millimeter wave antenna can rotate +/-180 degrees and achieve loss-free and anti-locking during operations, said Oppo, adding that it also supports 2X MIMO and is backed by the “O-Reserve” 4X MIMO antenna in the sub-6GHz frequency.
As the most advanced 5G CPE device in the industry, the OPPO 5G CPE Omni not only supports millimeter wave and sub-6 GHz dual network frequency bands, but also offers users an amazing 5G connection experience powered by the firm’s proprietary O-Motion 360° 5G antenna solution.
Users expect high speed, stable connectivity and blind angle free signal reception from CPE products. As the most advanced 5G CPE device in the industry, the OPPO 5G CPE Omni not only supports millimeter wave and sub-6 GHz dual network frequency bands, but also offers users an amazing 5G connection experience powered by the firm’s proprietary O-Motion 360° 5G antenna solution.
In terms of connectivity, OPPO 5G CPE Omni supports the most advanced Wi-Fi 6 protocols and can connect up to 1,024 devices simultaneously thanks to the integration of the Qualcomm IPQ8074A Wi-Fi chip. In the 5GHz channel, it supports up to 80MHz 8×8 MIMO. In the Dual Band Dual Concurrent (DBDC) mode, the theoretical peak transmission rate between Omni and other devices can reach up to 6Gbps. Omni also supports Mesh Network, Bluetooth low energy protocol (BLE 4.1) and ZigBee 3.0, enabling the expansion into multiple business scenarios in the future.
Omni is also the world’s first 5G CPE to support the MPTCP (MultiPath TCP) protocol. When the 5G cellular network and wired network are working concurrently and one of them fails, the MPTCP protocol algorithm will transfer the device from the failed network to the other function, ensuring seamless network switching and avoidance of data transmission interruption due to intermittent network failures. In addition, due to the use of the MPTCP protocol algorithm, Omni also supports dual frequency Wi-Fi rate overlapping of 2.4GHz and 5GHz channels, providing a higher and more stable Wi-Fi experience for devices.
The OPPO 5G CPE Omni launch is set to accelerate the rollout of the 5G network globally, offering users an unprecedented 5G experience. Oppo didn’t reveal any availability or price details for this new 5G CPE, but we suppose it will be available in coming two months.
Sourcing from https://www.4gltemall.com/blog/oppo-5g-cpe-omni-released/
