ceph部署(一,yum配置)
snowofsummer 发表于 2020/08/25 15:33:00 2020/08/25
【摘要】 1,关闭selinuxsed -i 's/enforcing/disabled/' /etc/selinux/config2,配置yum仓库文件cd /etc/yum.repos.d/mkdir /tmp/bakmv * /tmp/bak/curl -o /etc/yum.repos.d/CentOS-Base.repo https://mirrors.aliyun.com/repo/Cen...
1,关闭selinux
2,配置yum仓库文件
mkdir /tmp/bak
mv * /tmp/bak/
curl -o /etc/yum.repos.d/CentOS-Base.repo https://mirrors.aliyun.com/repo/Centos-7.repo
yum install wget -y
wget -O /etc/yum.repos.d/epel.repo http://mirrors.aliyun.com/repo/epel-7.repo
#YUM优先级别:
yum -y install yum-plugin-priorities.noarch
cat << EOF | tee /etc/yum.repos.d/ceph.repo
[Ceph]
name=Ceph packages for $basearch
baseurl=http://mirrors.163.com/ceph/rpm-nautilus/el7/\$basearch
enabled=1
gpgcheck=1
type=rpm-md
gpgkey=https://download.ceph.com/keys/release.asc
priority=1
[Ceph-noarch]
name=Ceph noarch packages
baseurl=http://mirrors.163.com/ceph/rpm-nautilus/el7/noarch
enabled=1
gpgcheck=1
type=rpm-md
priority=1
[ceph-source]
name=Ceph source packages
baseurl=http://mirrors.163.com/ceph/rpm-nautilus/el7/SRPMS
enabled=1
gpgcheck=1
type=rpm-md
EOF
3,安装ntp
yum -y install ntp ntpdate
systemctl start ntpd
systemctl enable ntpd
systemctl status ntpd
评论(0
