sysbench测试工具安装
snowofsummer 发表于 2020/08/20 14:31:41 2020/08/20
【摘要】 1,下载地址https://github.com/akopytov/sysbench/releases2,解压和安装软件包//依赖软件:yum -y install make automake libtool pkgconfig libaio-devel [root@db01 ~]# cd sysbench-1.0.16/[root@db01 sysbench-1.0.16]# ./aut...
1,下载地址
2,解压和安装软件包
//依赖软件:
[root@db01 sysbench-1.0.16]# ./autogen.sh
[root@db01 sysbench-1.0.16]# ./configure --with-mysql-includes=/usr/local/mysql/include --with-mysql-libs=/usr/local/mysql/lib
[root@db01 sysbench-1.0.16]#make
[root@db01 sysbench-1.0.16]#make install
指定--with-mysql-includes and --with-mysql-libs 。
//查询方法:
[root@db01 ~]# /usr/local/mysql/bin/mysql_config
Usage: /usr/local/mysql/bin/mysql_config [OPTIONS]
Compiler: GNU 4.8.5
Options:
        --cflags         [-I/usr/local/mysql/include ]
        --cxxflags       [-I/usr/local/mysql/include ]
        --include        [-I/usr/local/mysql/include]
        --libs           [-L/usr/local/mysql/lib -lmysqlclient -lpthread -lm -lrt -lssl -lcrypto -ldl]
        --libs_r         [-L/usr/local/mysql/lib -lmysqlclient -lpthread -lm -lrt -lssl -lcrypto -ldl]
        --plugindir      [/usr/local/mysql/lib/plugin]
        --socket         [/usr/local/mysql/mysql.sock]
        --port           [0]
        --version        [5.7.28]
        --libmysqld-libs [-L/usr/local/mysql/lib -lmysqld -lpthread -lm -lrt -lssl -lcrypto -ldl -lcrypt]
        --variable=VAR   VAR is one of:
                pkgincludedir [/usr/local/mysql/include]
                pkglibdir     [/usr/local/mysql/lib]
3,使用软件
[root@db01 sysbench-1.0.16]# export LD_LIBRARY_PATH=/usr/local/mysql/lib/
[root@db01 sysbench-1.0.16]# sysbench --version
sysbench 1.0.16
