MRS Hive 内存溢出问题解决方案
一刀双杀辣舞源 发表于 2020/06/15 10:04:25 2020/06/15
【摘要】 Hive 内存溢出问题解决方案l Mapper/Reducer阶段JVM内存溢出1. Java.lang.OutOfMemoryError: GC overhead limit exceeded;2. Error: java heapspace3. running beyondphysical memory limits.Current usage: 4...
Hive 内存溢出问题解决方案
3.       running beyondphysical memory limits.Current usage: 4.3 GB of 4.3 GBphysical memory used; 7.4 GB of 13.2 GB virtual memory used. Killing container
修复方案:运行时
                                     set mapreduce.map.java.opts=-XmxXXXXm(数值调大)
set mapreduce.map.memory.mb = XXXX(数值调大) (Container内存)
set mapreduce.reduce.java.opts=-XmxXXXXm (数值调大)
                set mapreduce.reduce.memory.mb = XXXX(数值调大) (Container内存)
set 语句运行时报错: cannot modify XXXXXXXXX at runtime, it is not in list of params that are allowed to be modified at runtime
在此处填写需要加入白名单的参数,重启Hive
l  栈内存溢出
1.       Java.lang.StackOverflowError
修复方案:Sql过于复杂,优化sql
l  MRAppMaster内存不足
1.       Halting due to Out of Memory Error…
修复方案:
修改此二处配置,数值调大,然后重启yarn
