ASR项目实战-构建Kaldi
JackieAtHome 发表于 2020/06/05 23:19:08 2020/06/05
【摘要】 基于Kaldi源码构建软件的的方法。
准备工作
安装构建时依赖的基础软件
软件清单如下:
  • bzip2
  • python3
  • automake
  • libtool
  • cmake
  • gcc
  • g++
  • gfortran
  • git
  • subversion
不同平台安装软件的方式不同,比如可以使用yum或者apt-get等。
下载开源软件
软件清单如下:
按照一定的规则,将下载后的文件放在指定目录,如下是样例
opensrc
    glog
        glog-0.4.0.zip
    Libunwind
        libunwind-1.3.1-src.zip
    Kaldi
        kaldi-master.zip
    OpenFST
        openfst-1.6.7.tar.gz
    OpenBLAS
        OpenBLAS-0.3.6.tar.gzinstall
    usr
        local
            bin
            sbin
            include
            lib
            lib64
script
    build.sh
构建脚本
build.sh的内容,如下为样例:
BUILD_CORE_NUM=8
SCRIPT_FILE=`readlink -f $0`SCRIPT_ROOT=`dir ${SCRIPT_FILE}`BUILD_ROOT=`dir ${SCRIPT_ROOT}`SOURCE_ROOT=${BUILD_ROOT}/opensrc
INSTALL_ROOT=${BUILD_ROOT}/install/usr/localexport INSTALL_ROOT
PATH=${INSTALL_ROOT}/bin:${INSTALL_ROOT}/sbin:${PATH}export PATH
LD_LIBRARY_PATH=${INSTALL_ROOT}/lib:${INSTALL_ROOT}/lib64:${LD_LIBRARY_PATH}export LD_LIBRARY_PATH# LibunwindVERSION=1.3.1
BUILD_LOG=${SCRIPT_ROOT}/Libunwind.outrm -f ${BUILD_LOG}touch ${BUILD_LOG}cd ${SOURCE_ROOT}/Libunwindrm -rf libunwind-${VERSION}unzip -o libunwind-${VERSION}-src.ziptar vxfz libunwind-${VERSION}.tar.gzcd libunwind-${VERSION}./autogen.sh
CFLAGS="-fPIC -I${INSTALL_ROOT}/include" \
    ./configure \           >> ${BUILD_LOG} 2>&1make -j${BUILD_CORE_NUM} >> ${BUILD_LOG} 2>&1make install prefix=${INSTALL_ROOT} >> ${BUILD_LOG} 2>&1# glogVERSION=0.4.0
BUILD_LOG=${SCRIPT_ROOT}/glog.outrm -f ${BUILD_LOG}touch ${BUILD_LOG}cd ${SOURCE_ROOT}/glogrm -rf glog-${VERSION}tar vxfz glog-${VERSION}.tar.gzcd glog-${VERSION}./autogen.sh
CXXFLAGS="-fPIC -I${INSTALL_ROOT}/include" \
    LDFLAGS="-L${INSTALL_ROOT}/lib -L${INSTALL_ROOT}/lib64" \
    ./configure \
    --prefix=${INSTALL_ROOT} \    >> ${BUILD_LOG} 2>&1make -j${BUILD_CORE_NUM} >> ${BUILD_LOG} 2>&1make install >> ${BUILD_LOG} 2>&1# OpenBLASVERSION=0.3.6
BUILD_LOG=${SCRIPT_ROOT}/OpenBLAS.outrm -f ${BUILD_LOG}touch ${BUILD_LOG}cd ${SOURCE_ROOT}/OpenBLASrm -rf OpenBLAS-${VERSION}rm -f OpenBLAStar vxfz OpenBLAS-${VERSION}.tar.gzln -s OpenBLAS-${VERSION} OpenBLAScd OpenBLAS-${VERSION}make -j${BUILD_CORE_NUM} >> ${BUILD_LOG} 2>&1make PREFIX=${INSTALL_ROOT} install >> ${BUILD_LOG} 2>&1# OpenFSTVERSION=1.6.7
BUILD_LOG=${SCRIPT_ROOT}/OpenFST.outrm -f ${BUILD_LOG}touch ${BUILD_LOG}cd ${SOURCE_ROOT}/OpenFSTrm -rf openfst-${VERSION}tar vxzf openfst-${VERSION}.tar.gzcd openfst-${VERSION}CXXFLAGS="-fPIC -I${INSTALL_ROOT}/include" \
    LIBS="${INSTALL_ROOT}/lib/libglog.a -pthread -lunwind" \
    ./configure \
    --enable-static \
    --enable-shared \
    --enable-far \
    --enable-ngram-fsts \
    --prefix=${INSTALL_ROOT} \    >> ${BUILD_LOG} 2>&1make -j${BUILD_CORE_NUM} >> ${BUILD_LOG} 2>&1make install >> ${BUILD_LOG} 2>&1# KaldiVERSION=master
BUILD_LOG=${SCRIPT_ROOT}/Kaldi.outrm -f ${BUILD_LOG}touch ${BUILD_LOG}cd ${SOURCE_ROOT}/Kaldirm -rf kaldi-${VERSION}.ziprm -f kaldiunzip kaldi-${VERSION}.zipcd kaldi-${VERSION}/src
    ./configure \
    --static \
    --openblas-root=${INSTALL_ROOT} \
    --static-math=yes \
    --threaded-math=yes \
    --static-fst=yes \
    --fst-version=1.6.7 \
    --fst-root=${INSTALL_ROOT} \
    --use-cuda=no \    >> ${BUILD_LOG} 2>&1make clean -j${BUILD_CORE_NUM} >> ${BUILD_LOG} 2>&1make depend -j${BUILD_CORE_NUM} >> ${BUILD_LOG} 2>&1make -j${BUILD_CORE_NUM} >> ${BUILD_LOG} 2>&1
注意事项
OpenFST自身实现一套日志系统,与glog集成时会报符号冲突。当前有用户在官网上提出类似的问题,但没有官方的答复。为了完整利用glog的能力,需要对OpenFST的实现做一定的修改。
修改点主要涉及如下几个文件:
  • src/include/log.h,删除代码中相关的类和变量的定义。
    #include <fst/types.h>#include <fst/lock.h>using std::string;// 删除中间出现的代码#define ATTRIBUTE_DEPRECATED __attribute__((deprecated))#endif
  • src/include/flags.h,在头部引入glog的头文件,增加如下代码:
    #include <fst/types.h>#include <fst/lock.h>#include "glog/logging.h"  // 引入glog的头文件using std::string;
  • src/lib/flags.cc,删除同名的变量。
    // DEFINE_int32(v, 0, "verbosity level");
若非注明,均为原创,欢迎转载,转载请注明来源:ASR项目实战-构建Kaldi
链接地址:http://www.jackieathome.net/archives/958.html
