Python 数据库操作之单表查询
Yuchuan 发表于 2020/06/03 15:36:56 2020/06/03
【摘要】 mysql 数据库单表查询操作相关知识。
一、单表查询的语法及关键字执行的优先级
1)、单表查询语法
SELECT DISTINCT 字段1,字段2... FROM 表名
                 WHERE 条件
                 GROUP BY field
                 HAVING 筛选
                 ORDER BY field
                 LIMIT 限制条数
2)、关键字执行的优先级
from
where
group by
select
distinct
having
order by
limit
1.找到表:from
2.拿着where指定的约束条件,去文件/表中取出一条条记录
3.将取出的一条条记录进行分组group by,如果没有group by,则整体作为一组
4.执行select(去重)
5.将分组的结果进行having过滤
6.将结果按条件排序:order by
7.限制结果的显示条数
二、简单查询
建表和数据库准备:
company.employee:
员工id
id
int
姓名 emp_name varchar
性别 gender enum
年龄 age int
入职日期 hire_date date
岗位 post varchar
岗位描述 post_comment varchar
薪水 salary double
办公室 office int
部门编号 depart_id int
#创建表
create table employee(
id int not null unique auto_increment,
emp_name varchar(20) not null,
gender enum('male','female') not null default 'male', #大部分是男的
age int(3) unsigned not null default 28,
hire_date date not null,
post varchar(50),
post_comment varchar(100),
salary double(15,2),
office int, #一个部门一个屋子
depart_id int
#查看表结构
mysql> desc employee;
#插入记录
#三个部门:教学,销售,运营
insert into employee(emp_name,gender,age,hire_date,post,salary,office,depart_id) values
('egon','male',18,'20170301','老男孩驻沙河办事处外交大使',7300.33,401,1), #以下是教学部
('alex','male',78,'20150302','teacher',1000000.31,401,1),
('wupeiqi','male',81,'20130305','teacher',8300,401,1),
('yuanhao','male',73,'20140701','teacher',3500,401,1),
('liwenzhou','male',28,'20121101','teacher',2100,401,1),
('jingliyang','female',18,'20110211','teacher',9000,401,1),
('jinxin','male',18,'19000301','teacher',30000,401,1),
('成龙','male',48,'20101111','teacher',10000,401,1),
('歪歪','female',48,'20150311','sale',3000.13,402,2),#以下是销售部门
('丫丫','female',38,'20101101','sale',2000.35,402,2),
('丁丁','female',18,'20110312','sale',1000.37,402,2),
('星星','female',18,'20160513','sale',3000.29,402,2),
('格格','female',28,'20170127','sale',4000.33,402,2),
('张野','male',28,'20160311','operation',10000.13,403,3), #以下是运营部门
('程咬金','male',18,'19970312','operation',20000,403,3),
('程咬银','female',18,'20130311','operation',19000,403,3),
('程咬铜','male',18,'20150411','operation',18000,403,3),
('程咬铁','female',18,'20140512','operation',17000,403,3)
#ps:如果在windows系统中,插入中文字符,select的结果为空白,可以将所有字符编码统一设置成gbk
#简单查询
    SELECT id,emp_name,gender,age,hire_date,post,post_comment,salary,office,depart_id
    FROM employee;
    SELECT * FROM employee;
    SELECT emp_name,salary FROM employee;
#避免重复DISTINCT
    SELECT DISTINCT post FROM employee;
#通过四则运算查询
    SELECT emp_name, salary*12 FROM employee;
    SELECT emp_name, salary*12 AS Annual_salary FROM employee;
    SELECT emp_name, salary*12 Annual_salary FROM employee;
#定义显示格式
   CONCAT() 函数用于连接字符串
   SELECT CONCAT('姓名: ',emp_name,'  年薪: ', salary*12)  AS Annual_salary
   FROM employee;
   CONCAT_WS() 第一个参数为分隔符
   SELECT CONCAT_WS(':',emp_name,salary*12)  AS Annual_salary
   FROM employee;
   结合CASE语句:
   SELECT
           CASE
           WHEN emp_name = 'jingliyang' THEN
               emp_name
           WHEN emp_name = 'alex' THEN
               CONCAT(emp_name,'_BIGSB')
           ELSE
               concat(emp_name, 'SB')
           END
       ) as new_name
   FROM
       employee;
小练习:
1 查出所有员工的名字,薪资,格式为
    <名字:egon>    <薪资:3000>
2 查出所有的岗位(去掉重复)
3 查出所有员工名字,以及他们的年薪,年薪的字段名为annual_year
答案:
select concat("<名字:",emp_name,">","<薪水:",salary,">") from employee;
select distinct depart_id from employee;
select emp_name,salary*12 annual_salary from employee;
三、where约束
where字句中可以使用:
1. 比较运算符:> < >= <= <> !=
2. between 80 and 100 值在80到100之间
3. in(80,90,100) 值是80或90或100
4. like 'e%'
    通配符可以是%或_,
    %表示任意多字符
    _表示一个字符
5. 逻辑运算符:在多个条件直接可以使用逻辑运算符 and or not
#1:单条件查询
    SELECT emp_name FROM employee
        WHERE post='sale';
#2:多条件查询
        WHERE post='teacher' AND salary>10000;
#3:关键字BETWEEN AND
        WHERE salary BETWEEN 10000 AND 20000;
        WHERE salary NOT BETWEEN 10000 AND 20000;
#4:关键字IS NULL(判断某个字段是否为NULL不能用等号,需要用IS)
    SELECT emp_name,post_comment FROM employee
        WHERE post_comment IS NULL;
        WHERE post_comment IS NOT NULL;
        WHERE post_comment=''; 注意''是空字符串,不是null
    ps:
        执行
        update employee set post_comment='' where id=2;
        再用上条查看,就会有结果了
#5:关键字IN集合查询
        WHERE salary=3000 OR salary=3500 OR salary=4000 OR salary=9000 ;
        WHERE salary IN (3000,3500,4000,9000) ;
        WHERE salary NOT IN (3000,3500,4000,9000) ;
#6:关键字LIKE模糊查询
    通配符’%’
            WHERE emp_name LIKE 'eg%';
    通配符’_’
            WHERE emp_name LIKE 'al__';
小练习:
. 查看岗位是teacher的员工姓名、年龄
. 查看岗位是teacher且年龄大于30岁的员工姓名、年龄
. 查看岗位是teacher且薪资在9000-10000范围内的员工姓名、年龄、薪资
. 查看岗位描述不为NULL的员工信息
. 查看岗位是teacher且薪资是10000或9000或30000的员工姓名、年龄、薪资
. 查看岗位是teacher且薪资不是10000或9000或30000的员工姓名、年龄、薪资
. 查看岗位是teacher且名字是jin开头的员工姓名、年薪
答案:
select emp_name,age from employee where post = 'teacher';
select emp_name,age from employee where post='teacher' and age > 30;
select emp_name,age,salary from employee where post='teacher' and salary between 9000 and 10000;
select * from employee where post_comment is not null;
select emp_name,age,salary from employee where post='teacher' and salary in (10000,9000,30000);
select emp_name,age,salary from employee where post='teacher' and salary not in (10000,9000,30000);
select emp_name,salary*12 from employee where post='teacher' and emp_name like 'jin%'
四、group by
单独使用GROUP BY关键字分组
    SELECT post FROM employee GROUP BY post;
    注意:我们按照post字段分组,那么select查询的字段只能是post,想要获取组内的其他相关信息,需要借助函数
GROUP BY关键字和GROUP_CONCAT()函数一起使用
    SELECT post,GROUP_CONCAT(emp_name) FROM employee GROUP BY post;#按照岗位分组,并查看组内成员名
    SELECT post,GROUP_CONCAT(emp_name) as emp_members FROM employee GROUP BY post;
GROUP BY与聚合函数一起使用
    select post,count(id) as count from employee group by post;#按照岗位分组,并查看每个组有多少人
强调:
如果我们用unique的字段作为分组的依据,则每一条记录自成一组,这种分组没有意义
多条记录之间的某个字段值相同,该字段通常用来作为分组的依据
五、聚合函数
#强调:聚合函数聚合的是组的内容,若是没有分组,则默认一组
示例:
    SELECT COUNT(*) FROM employee;
    SELECT COUNT(*) FROM employee WHERE depart_id=1;
    SELECT MAX(salary) FROM employee;
    SELECT MIN(salary) FROM employee;
    SELECT AVG(salary) FROM employee;
    SELECT SUM(salary) FROM employee;
    SELECT SUM(salary) FROM employee WHERE depart_id=3;
小练习:
. 查询岗位名以及岗位包含的所有员工名字
. 查询岗位名以及各岗位内包含的员工个数
. 查询公司内男员工和女员工的个数
. 查询岗位名以及各岗位的平均薪资
. 查询岗位名以及各岗位的最高薪资
. 查询岗位名以及各岗位的最低薪资
. 查询男员工与男员工的平均薪资,女员工与女员工的平均薪资
答案:
#题1:select post,group_concat(emp_name) as group_emp_name from employee group by post;
#题目2:select post,count(id) from employee group by post;
#题目3:select gender,count(id) as count from employee group by gender;
#题目4:select post,avg(salary) from employee group by post;
#题目5:select post,max(salary) from employee group by post;
#题目6:select post,min(salary) from employee group by post;
#题目七:select gender,avg(salary) from employee group by gender;
六、HAVING过滤
HAVING与WHERE不一样的地方在于!!!!!!
#!!!执行优先级从高到低:where > group by > having
#1. Where 发生在分组group by之前,因而Where中可以有任意字段,但是绝对不能使用聚合函数。
#2. Having发生在分组group by之后,因而Having中可以使用分组的字段,无法直接取到其他字段,可以使用聚合函数
验证:
mysql> select @@sql_mode;
mysql> select * from employee where salary>100000;
mysql> select post,group_concat(emp_name) from employee group by post having salary>100000;#错误,分组后无法直接取到salary字段
mysql> select post,group_concat(emp_name) from employee group by post having avg(salary)>10000;
小练习:
1. 查询各岗位内包含的员工个数小于2的岗位名、岗位内包含员工名字、个数
3. 查询各岗位平均薪资大于10000的岗位名、平均工资
4. 查询各岗位平均薪资大于10000且小于20000的岗位名、平均工资
答案:
#题1:
mysql> select post,group_concat(emp_name),count(id) from employee group by post having count(id)<2;
#题目2:
mysql> select post,avg(salary) from employee group by post having avg(salary)>10000;
或者:
mysql> select post,avg(salary) as avg_salary from employee group by post having avg_salary>10000;
#题目3:
mysql> select post,avg(salary) as avg_salary from employee group by post having avg_salary>10000 and avg_salary<20000;
七、ORDER BY 查询排序
按单列排序
    SELECT * FROM employee ORDER BY salary;
    SELECT * FROM employee ORDER BY salary ASC;
    SELECT * FROM employee ORDER BY salary DESC;
按多列排序:先按照age排序,如果年纪相同,则按照薪资排序
    SELECT * from employee
        ORDER BY age,
        salary DESC;
小练习:
1. 查询所有员工信息,先按照age升序排序,如果age相同则按照hire_date降序排序
2. 查询各岗位平均薪资大于10000的岗位名、平均工资,结果按平均薪资升序排列
3. 查询各岗位平均薪资大于10000的岗位名、平均工资,结果按平均薪资降序排列
答案:
#题目1
mysql> select * from employee order by age,hire_date desc;
#题目2
mysql> select post,avg(salary) as avg_salary from employee group by post having avg_salary>10000 order by avg_salary asc;
#题目3
mysql> select post,avg(salary) as avg_salary from employee group by post having avg_salary>10000 order by avg_salary desc;
八、LIMIT 限制查询的记录数
示例:
        LIMIT 3;                    #默认初始位置为0
        LIMIT 0,5; #从第0开始,即先查询出第一条,然后包含这一条在内往后查5条
        LIMIT 5,5; #从第5开始,即先查询出第6条,然后包含这一条在内往后查5条
小练习:
1. 分页显示,每页5条
答案:
mysql> select * from employee limit 0,5;
mysql> select * from employee limit 5,5;
mysql> select * from employee limit 10,5;
九、使用正则表达式查询
SELECT * FROM employee WHERE emp_name REGEXP '^ale';
SELECT * FROM employee WHERE emp_name REGEXP 'on$';
SELECT * FROM employee WHERE emp_name REGEXP 'm{2}';
小结:对字符串匹配的方式
WHERE emp_name = 'egon';
WHERE emp_name LIKE 'yua%';
小练习:
查看所有员工中名字是jin开头,n或者g结果的员工信息
答案:
mysql> select * from employee where emp_name regexp "^jin.*[ng]$";
