【双目测距】基于OpenCV的双目摄像头测距
一颗小树x 发表于 2020/05/28 23:06:28 2020/05/28
【摘要】 首先进行双目摄像头定标,获取双目摄像头内部的参数后,进行测距;本文的双目视觉测距是基于BM算法。注意:双目定标的效果会影响测距的精准度,建议大家在做双目定标时,做好一些(尽量让误差小)。
前言
一、双目测距--输入图片
效果1:
效果2:
本人通过测试,误差是1cm.
其中参数:BlockSize、UniquenessRatio、NumDisparities 根据实际情况来调整;
选择C++运行效率高,BM算法可以自定义修改,比较灵活;尝试过Python版的BM算法双目测距,效果没C++好。
源代码:
/*        双目测距        */
#include <opencv2/opencv.hpp>
#include <iostream>
#include <math.h>
using namespace std;
using namespace cv;
const int imageWidth = 640;                             //摄像头的分辨率
const int imageHeight = 360;
Vec3f  point3;
float d;
Size imageSize = Size(imageWidth, imageHeight);
Mat rgbImageL, grayImageL;
Mat rgbImageR, grayImageR;
Mat rectifyImageL, rectifyImageR;
Rect validROIL;//图像校正之后,会对图像进行裁剪,这里的validROI就是指裁剪之后的区域
Rect validROIR;
Mat mapLx, mapLy, mapRx, mapRy;     //映射表
Mat Rl, Rr, Pl, Pr, Q;              //校正旋转矩阵R,投影矩阵P 重投影矩阵Q
Mat xyz;              //三维坐标
Point origin;         //鼠标按下的起始点
Rect selection;      //定义矩形选框
bool selectObject = false;    //是否选择对象
int blockSize = 0, uniquenessRatio = 0, numDisparities = 0;
Ptr<StereoBM> bm = StereoBM::create(16, 9);
/*事先标定好的左相机的内参矩阵
fx 0 cx
0 fy cy
0  0  1
Mat cameraMatrixL = (Mat_<double>(3, 3) << 418.523322187048, -1.26842201390676, 343.908870120890,
	0, 421.222568242056, 235.466208987968,
	0, 0, 1);
//获得的畸变参数
/*418.523322187048	0	0
-1.26842201390676	421.222568242056	0
344.758267538961	243.318992284899	1 */ //2
Mat distCoeffL = (Mat_<double>(5, 1) << 0.006636837611004, 0.050240447649195, 0.006681263320267, 0.003130367429418, 0);
//[0.006636837611004,0.050240447649195] [0.006681263320267,0.003130367429418]
/*事先标定好的右相机的内参矩阵
fx 0 cx
0 fy cy
0  0  1
Mat cameraMatrixR = (Mat_<double>(3, 3) << 417.417985082506, 0.498638151824367, 309.903372309072,
	0, 419.795432389420, 230.6,
	0, 0, 1);
417.417985082506	0	0
0.498638151824367	419.795432389420	0
309.903372309072	236.256106972796	1
*/ //2
Mat distCoeffR = (Mat_<double>(5, 1) << -0.038407383078874, 0.236392800301615, 0.004121779274885, 0.002296129959664, 0);
//[-0.038407383078874,0.236392800301615]  [0.004121779274885,0.002296129959664]
Mat T = (Mat_<double>(3, 1) << -1.210187345641146e+02, 0.519235426836325, -0.425535566316217);//T平移向量
//[-1.210187345641146e+02,0.519235426836325,-0.425535566316217]
															 //对应Matlab所得T参数
//Mat rec = (Mat_<double>(3, 1) << -0.00306, -0.03207, 0.00206);//rec旋转向量,对应matlab om参数  我
Mat rec = (Mat_<double>(3, 3) << 0.999341122700880, -0.00206388651740061, 0.0362361815232777,
	0.000660748031451783, 0.999250989651683, 0.0386913826603732,
	-0.0362888948713456, -0.0386419468010579, 0.998593969567432);                //rec旋转向量,对应matlab om参数  我
/* 0.999341122700880	0.000660748031451783	-0.0362888948713456
-0.00206388651740061	0.999250989651683	-0.0386419468010579
0.0362361815232777	0.0386913826603732	0.998593969567432 */
//Mat T = (Mat_<double>(3, 1) << -48.4, 0.241, -0.0344);//T平移向量
																							  //对应Matlab所得T参数
//Mat rec = (Mat_<double>(3, 1) << -0.039, -0.04658, 0.00106);//rec旋转向量,对应matlab om参数   倬华
Mat R;//R 旋转矩阵
	  /*****立体匹配*****/
void stereo_match(int, void*)
	bm->setBlockSize(2 * blockSize + 5);     //SAD窗口大小,5~21之间为宜
	bm->setROI1(validROIL);
	bm->setROI2(validROIR);
	bm->setPreFilterCap(31);
	bm->setMinDisparity(0);  //最小视差,默认值为0, 可以是负值,int型
	bm->setNumDisparities(numDisparities * 16 + 16);//视差窗口,即最大视差值与最小视差值之差,窗口大小必须是16的整数倍,int型
	bm->setTextureThreshold(10);
	bm->setUniquenessRatio(uniquenessRatio);//uniquenessRatio主要可以防止误匹配
	bm->setSpeckleWindowSize(100);
	bm->setSpeckleRange(32);
	bm->setDisp12MaxDiff(-1);
	Mat disp, disp8;
	bm->compute(rectifyImageL, rectifyImageR, disp);//输入图像必须为灰度图
	disp.convertTo(disp8, CV_8U, 255 / ((numDisparities * 16 + 16)*16.));//计算出的视差是CV_16S格式
	reprojectImageTo3D(disp, xyz, Q, true); //在实际求距离时,ReprojectTo3D出来的X / W, Y / W, Z / W都要乘以16(也就是W除以16),才能得到正确的三维坐标信息。
	xyz = xyz * 16;
	imshow("disparity", disp8);
/*****描述:鼠标操作回调*****/
static void onMouse(int event, int x, int y, int, void*)
	if (selectObject)
		selection.x = MIN(x, origin.x);
		selection.y = MIN(y, origin.y);
		selection.width = std::abs(x - origin.x);
		selection.height = std::abs(y - origin.y);
	switch (event)
	case EVENT_LBUTTONDOWN:   //鼠标左按钮按下的事件
		origin = Point(x, y);
		selection = Rect(x, y, 0, 0);
		selectObject = true;
		//cout << origin << "in world coordinate is: " << xyz.at<Vec3f>(origin) << endl;
		  point3 = xyz.at<Vec3f>(origin);
		point3[0];
		//cout << "point3[0]:" << point3[0] << "point3[1]:" << point3[1] << "point3[2]:" << point3[2]<<endl;
		cout << "世界坐标:" << endl;
		cout << "x: " << point3[0] << "  y: " << point3[1] << "  z: " << point3[2] << endl;
		 d = point3[0] * point3[0]+ point3[1] * point3[1]+ point3[2] * point3[2];
		 d = sqrt(d);   //mm
		// cout << "距离是:" << d << "mm" << endl;
		 d = d / 10.0;   //cm
         cout << "距离是:" << d << "cm" << endl;
		// d = d/1000.0;   //m
		// cout << "距离是:" << d << "m" << endl;
		break;
	case EVENT_LBUTTONUP:    //鼠标左按钮释放的事件
		if (selection.width > 0 && selection.height > 0)
			break;
/*****主函数*****/
int main()
	立体校正
	Rodrigues(rec, R); //Rodrigues变换
	stereoRectify(cameraMatrixL, distCoeffL, cameraMatrixR, distCoeffR, imageSize, R, T, Rl, Rr, Pl, Pr, Q, CALIB_ZERO_DISPARITY,
		0, imageSize, &validROIL, &validROIR);
	initUndistortRectifyMap(cameraMatrixL, distCoeffL, Rl, Pr, imageSize, CV_32FC1, mapLx, mapLy);
	initUndistortRectifyMap(cameraMatrixR, distCoeffR, Rr, Pr, imageSize, CV_32FC1, mapRx, mapRy);
	读取图片
	rgbImageL = imread("image_left_1.jpg", CV_LOAD_IMAGE_COLOR);
	cvtColor(rgbImageL, grayImageL, CV_BGR2GRAY);
	rgbImageR = imread("image_right_1.jpg", CV_LOAD_IMAGE_COLOR);
	cvtColor(rgbImageR, grayImageR, CV_BGR2GRAY);
	imshow("ImageL Before Rectify", grayImageL);
	imshow("ImageR Before Rectify", grayImageR);
	经过remap之后,左右相机的图像已经共面并且行对准了
	remap(grayImageL, rectifyImageL, mapLx, mapLy, INTER_LINEAR);
	remap(grayImageR, rectifyImageR, mapRx, mapRy, INTER_LINEAR);
	把校正结果显示出来
	Mat rgbRectifyImageL, rgbRectifyImageR;
	cvtColor(rectifyImageL, rgbRectifyImageL, CV_GRAY2BGR);  //伪彩色图
	cvtColor(rectifyImageR, rgbRectifyImageR, CV_GRAY2BGR);
	//单独显示
	//rectangle(rgbRectifyImageL, validROIL, Scalar(0, 0, 255), 3, 8);
	//rectangle(rgbRectifyImageR, validROIR, Scalar(0, 0, 255), 3, 8);
	imshow("ImageL After Rectify", rgbRectifyImageL);
	imshow("ImageR After Rectify", rgbRectifyImageR);
	//显示在同一张图上
	Mat canvas;
	double sf;
	int w, h;
	sf = 600. / MAX(imageSize.width, imageSize.height);
	w = cvRound(imageSize.width * sf);
	h = cvRound(imageSize.height * sf);
	canvas.create(h, w * 2, CV_8UC3);   //注意通道
										//左图像画到画布上
	Mat canvasPart = canvas(Rect(w * 0, 0, w, h));                                //得到画布的一部分
	resize(rgbRectifyImageL, canvasPart, canvasPart.size(), 0, 0, INTER_AREA);     //把图像缩放到跟canvasPart一样大小
	Rect vroiL(cvRound(validROIL.x*sf), cvRound(validROIL.y*sf),                //获得被截取的区域
		cvRound(validROIL.width*sf), cvRound(validROIL.height*sf));
	//rectangle(canvasPart, vroiL, Scalar(0, 0, 255), 3, 8);                      //画上一个矩形
	cout << "Painted ImageL" << endl;
	//右图像画到画布上
	canvasPart = canvas(Rect(w, 0, w, h));                                      //获得画布的另一部分
	resize(rgbRectifyImageR, canvasPart, canvasPart.size(), 0, 0, INTER_LINEAR);
	Rect vroiR(cvRound(validROIR.x * sf), cvRound(validROIR.y*sf),
		cvRound(validROIR.width * sf), cvRound(validROIR.height * sf));
	//rectangle(canvasPart, vroiR, Scalar(0, 0, 255), 3, 8);
	cout << "Painted ImageR" << endl;
	//画上对应的线条
	for (int i = 0; i < canvas.rows; i += 16)
		line(canvas, Point(0, i), Point(canvas.cols, i), Scalar(0, 255, 0), 1, 8);
	imshow("rectified", canvas);
	立体匹配
	namedWindow("disparity", CV_WINDOW_AUTOSIZE);
	// 创建SAD窗口 Trackbar
	createTrackbar("BlockSize:\n", "disparity", &blockSize, 8, stereo_match);
	// 创建视差唯一性百分比窗口 Trackbar
	createTrackbar("UniquenessRatio:\n", "disparity", &uniquenessRatio, 50, stereo_match);
	// 创建视差窗口 Trackbar
	createTrackbar("NumDisparities:\n", "disparity", &numDisparities, 16, stereo_match);
	//鼠标响应函数setMouseCallback(窗口名称, 鼠标回调函数, 传给回调函数的参数,一般取0)
	setMouseCallback("disparity", onMouse, 0);
	stereo_match(0, 0);
	waitKey(0);
	return 0;
流程说明:
先采集左右摄像头的图片,然后,修改一下指定的图片,可以进行测距。
里面有双目摄像头的参数,具体需要自己定标和矫正后,然后,填入。
双目定标可以参考我这篇博客:https://guo-pu.blog.csdn.net/article/details/86602452
双目数据转化可以参考我这篇博客:https://guo-pu.blog.csdn.net/article/details/86710737
详细讲解摄像头参数:
1)Mat cameraMatrixL        左相机的内参矩阵
2)Mat distCoeffL = (Mat_(5, 1) .......                          左相机 畸变参数    即K1,K2,P1,P2,K3。
3) Mat cameraMatrixR                                                               右相机的内参矩阵
4)Mat distCoeffR = (Mat_(5, 1)  .......                          右相机畸变参数    即K1,K2,P1,P2,K3。
5) Mat T = (Mat_(3, 1) << -1.210187345641146e+02, 0.519235426836325, -0.425535566316217);//  相机的 平移向量
6) Mat rec = (Mat_(3, 3) << 0.99934112270088...................        相机的旋转向量
一共6个相机参数,1、2是 左相机的参数; 3、4是 右相机的参数; 5、6是相机(相对)整体的参数。
二、实时采集摄像头数据,进行双目测距
效果如下图:
源代码:
/*        立体匹配和测距        */
#include <iostream>
#include <math.h>
using namespace cv;
Vec3f  point3;
float d;
Rect validROIR;
Mat xyz;              //三维坐标
/*事先标定好的左相机的内参矩阵
fx 0 cx
0 fy cy
0  0  1
	0, 0, 1);
//获得的畸变参数
/*事先标定好的右相机的内参矩阵
fx 0 cx
0 fy cy
0  0  1
	0, 0, 1);
*/ //2
															 //对应Matlab所得T参数
																							  //对应Matlab所得T参数
Mat R;//R 旋转矩阵
	  /*****立体匹配*****/
	Mat disp, disp8;
	xyz = xyz * 16;
	if (selectObject)
	switch (event)
		point3[0];
		 d = sqrt(d);   //mm
		 d = d / 10.0;   //cm
		break;
			break;
/*****主函数*****/
int main()
	立体校正
	initUndistortRectifyMap(cameraMatrixL, distCoeffL, Rl, Pl, imageSize, CV_32FC1, mapLx, mapLy);
	打开摄像头
	VideoCapture cap;
		cap.open(1);                             //打开相机,电脑自带摄像头一般编号为0,外接摄像头编号为1,主要是在设备管理器中查看自己摄像头的编号。
		cap.set(CV_CAP_PROP_FRAME_WIDTH, 2560);  //设置捕获视频的宽度
		cap.set(CV_CAP_PROP_FRAME_HEIGHT, 720);  //设置捕获视频的高度
		if (!cap.isOpened())                         //判断是否成功打开相机
			cout << "摄像头打开失败!" << endl;
			return -1;
		Mat frame, frame_L, frame_R;
		cap >> frame;                                //从相机捕获一帧图像
		while (1) {
			double fScale = 0.5;                         //定义缩放系数,对2560*720图像进行缩放显示(2560*720图像过大,液晶屏分辨率较小时,需要缩放才可完整显示在屏幕)
			Size dsize = Size(frame.cols*fScale, frame.rows*fScale);
			Mat imagedst = Mat(dsize, CV_32S);
			resize(frame, imagedst, dsize);
			char image_left[200];
			char image_right[200];
			frame_L = imagedst(Rect(0, 0, 640, 360));  //获取缩放后左Camera的图像
		//	namedWindow("Video_L", 1);
		//	imshow("Video_L", frame_L);
			frame_R = imagedst(Rect(640, 0, 640, 360)); //获取缩放后右Camera的图像
	//		namedWindow("Video_R", 2);
//			imshow("Video_R", frame_R);
			cap >> frame;
			读取图片
			//rgbImageL = imread("image_left_1.jpg", CV_LOAD_IMAGE_COLOR);
			cvtColor(frame_L, grayImageL, CV_BGR2GRAY);
			//rgbImageR = imread("image_right_1.jpg", CV_LOAD_IMAGE_COLOR);
			cvtColor(frame_R, grayImageR, CV_BGR2GRAY);
		//	imshow("ImageL Before Rectify", grayImageL);
		//	imshow("ImageR Before Rectify", grayImageR);
			把校正结果显示出来
			//单独显示
		//	imshow("ImageL After Rectify", rgbRectifyImageL);
		//	imshow("ImageR After Rectify", rgbRectifyImageR);
			//显示在同一张图上
			Mat canvas;
			double sf;
			int w, h;
												//左图像画到画布上
		//	cout << "Painted ImageL" << endl;
			//右图像画到画布上
		//	cout << "Painted ImageR" << endl;
			//画上对应的线条
			立体匹配
			// 创建SAD窗口 Trackbar
			// 创建视差窗口 Trackbar
			stereo_match(0, 0);
			waitKey(10);
		} //wheil
	return 0;
希望对你有帮助。
补充说明:
1.关于如何求出世界坐标?
1)x,y,z 是由
Vec3f point3;
point3 = xyz.at<Vec3f>(origin); 来转化的。
2)x,y,z求平方和后开根号,是两点的距离公式,即点(0,0,0)------双目摄像头的中心点,和点(x,y,z)进行两点求距离。
