鲲鹏-ARM-欧拉os 2.8安装mysql
Leo Xiao 发表于 2020/05/28 19:51:03 2020/05/28
【摘要】 # 前言欧拉os和鲲鹏生态越来越好,很多应用已经不需要源码安装了# 环境:euler OS 2.8```shell# cat /etc/os-release NAME="EulerOS"VERSION="2.0 (SP8)"ID="euleros"ID_LIKE="rhel fedora centos"VERSION_ID="2.0"PRETTY_NAME="EulerOS 2.0 (SP8...
# 前言
# 环境:euler OS 2.8
```shell
NAME="EulerOS"
VERSION="2.0 (SP8)"
ID="euleros"
VERSION_ID="2.0"
PRETTY_NAME="EulerOS 2.0 (SP8)"
ANSI_COLOR="0;31"
# 安装依赖
```shell
yum install bison* ncurses*
# 下载社区版mysql
```shell
wget https://repo.huaweicloud.cn/mysql/Downloads/MySQL-8.0/mysql-community-common-8.0.18-1.el7.aarch64.rpm
wget https://repo.huaweicloud.cn/mysql/Downloads/MySQL-8.0/mysql-community-libs-8.0.18-1.el7.aarch64.rpm
wget https://repo.huaweicloud.cn/mysql/Downloads/MySQL-8.0/mysql-community-client-8.0.18-1.el7.aarch64.rpm
wget https://repo.huaweicloud.cn/mysql/Downloads/MySQL-8.0/mysql-community-server-8.0.18-1.el7.aarch64.rpm
# 安装
```shell
rpm -ivh mysql-community-common-8.0.18-1.el7.aarch64.rpm
rpm -ivh mysql-community-libs-8.0.18-1.el7.aarch64.rpm
rpm -ivh mysql-community-client-8.0.18-1.el7.aarch64.rpm
rpm -ivh mysql-community-server-8.0.18-1.el7.aarch64.rpm
如果碰到下面的问题:
```shell
]# rpm -ivh /root/mysql-community-client-8.0.18-1.el7.aarch64.rpm
warning: /root/mysql-community-client-8.0.18-1.el7.aarch64.rpm: Header V3 DSA/SHA1 Signature, key ID 5072e1f5: NOKEY
error: Failed dependencies:
    libncurses.so.5()(64bit) is needed by mysql-community-client-8.0.18-1.el7.aarch64
    libtinfo.so.5()(64bit) is needed by mysql-community-client-8.0.18-1.el7.aarch64
可以--nodeps --force跳过:
```shell
# rpm -ivh /root/mysql-community-client-8.0.18-1.el7.aarch64.rpm --nodeps --force
Verifying...                          ################################# [100%]
Preparing...                          ################################# [100%]
Updating / installing...
   1:mysql-community-client-8.0.18-1.e################################# [100%]
# 启动mysqld
```shell
# systemctl start mysqld
# systemctl status mysqld
    mysqld.service - MySQL Server
   Loaded: loaded (/usr/lib/systemd/system/mysqld.service; enabled; vendor preset: disabled)
   Active: active (running) since Thu 2020-05-28 10:40:13 CST; 26s ago
     Docs: man:mysqld(8)
           http://dev.mysql.com/doc/refman/en/using-systemd.html
  Process: 5581 ExecStartPre=/usr/bin/mysqld_pre_systemd (code=exited, status=0/SUCCESS)
 Main PID: 6089 (mysqld)
   Status: "Server is operational"
    Tasks: 39 (limit: 21273)
   Memory: 638.7M
   CGroup: /system.slice/mysqld.service
             6089 /usr/sbin/mysqld
May 28 10:39:39 host-172-16-100-188 systemd[1]: Starting MySQL Server...
May 28 10:40:13 host-172-16-100-188 systemd[1]: Started MySQL Server
# 查看初始密码:
```shell
# cat /var/log/mysqld.log
2020-05-28T02:40:06.880856Z 0 [System] [MY-013169] [Server] /usr/sbin/mysqld (mysqld 8.0.18) initializing of server in progress as process 5958
2020-05-28T02:40:09.346658Z 5 [Note] [MY-010454] [Server] A temporary password is generated for root@localhost: bA6eBeowau<1
2020-05-28T02:40:12.963252Z 0 [System] [MY-010116] [Server] /usr/sbin/mysqld (mysqld 8.0.18) starting as process 6089
2020-05-28T02:40:13.446960Z 0 [Warning] [MY-010068] [Server] CA certificate ca.pem is self signed.
2020-05-28T02:40:13.501516Z 0 [System] [MY-010931] [Server] /usr/sbin/mysqld: ready for connections. Version: '8.0.18'  socket: '/var/lib/mysql/mysql.sock'  port: 3306  MySQL Community Server - GPL.
2020-05-28T02:40:13.573300Z 0 [System] [MY-011323] [Server] X Plugin ready for connections. Socket: '/var/run/mysqld/mysqlx.sock' bind-address: '::' port: 33060
# 用初始密码登录并修改密码:
```shell
# mysql -u root -p
Enter password:
mysql> alter user 'root'@'localhost' identified by 'YOUR_PAASWORD';
Query OK, 0 rows affected (0.01 sec)
