Prometheus系列——监控zookeeper
郁唯xiaolin 发表于 2020/05/15 15:26:07 2020/05/15
【摘要】 prometheus监控zookeeper
笔者所在公司有使用zookeeper集群,所以,也配置一下对于zookeeper这个集群的监控吧。
一、下载jmx_exporter
#linux下
cd /usr/local/prometheus
wget https://repo1.maven.org/maven2/io/prometheus/jmx/jmx_prometheus_javaagent/0.3.1/jmx_prometheus_javaagent-0.3.1.jar
二、编写jmx_exporter配置文件
jmx_exporter官方推荐配置: https://github.com/prometheus/jmx_exporter/blob/master/example_configs/zookeeper.yaml
#将文件下载下来放到下面文件中/usr/local/prometheus/jmx-exporter.yaml
#cat /usr/local/prometheus/jmx-exporter.yaml
rules:
# replicated Zookeeper
- pattern: "org.apache.ZooKeeperService<name0=ReplicatedServer_id(\\d+)><>(\\w+)"
type: GAUGE
- pattern: "org.apache.ZooKeeperService<name0=ReplicatedServer_id(\\d+), name1=replica.(\\d+)><>(\\w+)"
type: GAUGE
labels:
replicaId: "$2"
- pattern: "org.apache.ZooKeeperService<name0=ReplicatedServer_id(\\d+), name1=replica.(\\d+), name2=(\\w+)><>(Packets\\w+)"
type: COUNTER
labels:
replicaId: "$2"
memberType: "$3"
- pattern: "org.apache.ZooKeeperService<name0=ReplicatedServer_id(\\d+), name1=replica.(\\d+), name2=(\\w+)><>(\\w+)"
type: GAUGE
labels:
replicaId: "$2"
memberType: "$3"
- pattern: "org.apache.ZooKeeperService<name0=ReplicatedServer_id(\\d+), name1=replica.(\\d+), name2=(\\w+), name3=(\\w+)><>(\\w+)"
type: GAUGE
labels:
replicaId: "$2"
memberType: "$3"
# standalone Zookeeper
- pattern: "org.apache.ZooKeeperService<name0=StandaloneServer_port(\\d+)><>(\\w+)"
type: GAUGE
- pattern: "org.apache.ZooKeeperService<name0=StandaloneServer_port(\\d+), name1=InMemoryDataTree><>(\\w+)"
type: GAUGE
三、修改zookeeper启动文件
修改bin/zkServer.sh,在第六十行添加内容
JMX_DIR="/usr/local/prometheus"
JVMFLAGS="$JVMFLAGS -javaagent:$JMX_DIR/jmx_prometheus_javaagent-0.3.1.jar=20000:$JMX_DIR/jmx-exporter.yaml"
启动zookeeper
使用命令验证是否配置成功:
curl localhost:20000/metrics
四、添加prometheus关于zookeeper的配置
# vim prometheus.yml
- job_name: 'zookeeper'
    static_configs:
    - targets: ['192.168.1.200:20000']
重启prometheus,然后在Prometheus页面中的Targets中就能看到新加入的zookeeper,
grafana中可以搜索相应的dashboard,不再赘述。
