验证GaussDB T 闪回事务查询功能;闪回表功能强劲闪回TRUNCATE
社会主义的一块砖 发表于 2020/03/12 17:28:15 2020/03/12
【摘要】 一、验证 GaussDB T 支持闪回事务查询功能环境:redhat7.5+gaussdb1001. 创建表:SQL> conn wsx/password@127.0.0.1:1888connected.SQL> create table wsx.t1 as select * from dual;Succeed.2. 模拟delete操作:SQL> delete from wsx.t1;1 ...
1. 创建表:
connected.
Succeed.
2. 模拟delete操作:
1 rows affected.
SQL>
SQL>
SQL> commit;
Succeed.
SQL>
 select * from t1;
DUMMY
0 rows fetched.
SQL>
 select sysdate from dual;
SYSDATE
2020-02-18 17:05:56
1 rows fetched.
3. 查看回收站是否有记录。
SQL> col org_name format a10;
SQL>
SQL> col partition_name format a10;
SQL>
SQL>
SQL> conn / as sysdba
connected.
SQL>
SQL> select name,user#,org_name,partition_name,operation#,flags from sys_recyclebin;
NAME                           USER#        ORG_NAME   PARTITION_ OPERATION#   FLAGS
0 rows fetched.
4.闪回查询
SQL> SELECT * FROM wsx.t1
    AS OF TIMESTAMP TO_DATE ('2020/02/18 17:04:00', 'yyyy/mm/dd hh24:mi:ss');
DUMMY
X
1 rows fetched.
5.恢复表wsx.t1在2020.02.18 17:04:00误删除的记录:
connected.
SQL>
SQL>
SQL> insert into wsx.t1
(SELECT * FROM wsx.t1
    AS OF TIMESTAMP TO_DATE ('2020/02/18 17:04:00', 'yyyy/mm/dd hh24:mi:ss'));
1 rows affected.
SQL>
SQL> commit;
Succeed.
SQL>
SQL>
SQL> select * from wsx.t1;
DUMMY
X
1 rows fetched.
----可以看到,表wsx.t1已经有记录了
总的来说,gaussdb100 T 是可以支持闪回事务查询。
二、GaussDB T 的 Flashback Table 功能非常强劲可以闪回TRUNCATE
Gaussdb提供了类似Oracle的闪回表功能;可以很好的应对drop table或者truncate table的误操作场景;这个功能非常赞。本质上来讲也是使用了回收站功能。下面进行简单测试:
清空回收站
SQL> select * from v$version;
VERSION
GaussDB_100_1.0.1.SPC2.B003 Release 3ae9d6c
ZENGINE
3ae9d6c
3 rows fetched.
SQL> purge recyclebin;
Succeed.
SQL> select name,USER#,ORG_NAME,PARTITION_NAME,OPERATION#,FLAGS from SYS_RECYCLEBIN;
0 rows fetched.
drop table
SQL> conn roger/Roger007@127.0.0.1:1611
connected.
SQL>
 drop table test;
Succeed.
查看回收站内容
connected.
BIN$0$88F6E0==$0               2            IDX_TEST_ID                     1            2
BIN$0$88F6D6==$0               2            TEST                            1            3
2 rows fetched.
闪回被drop table
SQL>  flashback table roger.test to before drop;
Succeed.
0 rows fetched.
SQL> select * from roger.test;
A                                        B
1                                        www.enmotech.com
1                                        www.killdb.com
666                                      www.modb.pro
3 rows fetched.
那么truncate 的表能闪回吗 ?
SQL> create table roger.test_copy as select * from roger.test ;
Succeed.
SQL> select * from roger.test_copy;
A                                        B
1                                        www.enmotech.com
1                                        www.killdb.com
666                                      www.modb.pro
3 rows fetched.
SQL> truncate table roger.test_copy;
Succeed.
A                                        B
0 rows fetched.
BIN$1$88FFA4==$0               2            TEST_COPY                       0            3
1 rows fetched.
SQL> flashback table roger.test_copy to before truncate force;
Succeed.
A                                        B
1                                        www.enmotech.com
1                                        www.killdb.com
666                                      www.modb.pro
3 rows fetched.
SQL>
可以看到成功闪回了被truncate table。
那么如果表被truncate之后,被写入数据之后,还能闪回吗? 下面测试一下。
SQL> create table roger.test_copy2 as select * from roger.test ;
Succeed.
SQL> select * from roger.test_copy2;
A                                        B
1                                        www.enmotech.com
1                                        www.killdb.com
666                                      www.modb.pro
3 rows fetched.
SQL> truncate table roger.test_copy2;
Succeed.
SQL> insert into roger.test_copy2 values(999,'www.baidu.com');
1 rows affected.
SQL> commit;
Succeed.
BIN$2$890165==$0               2            TEST_COPY2                      0            3
1 rows fetched.
SQL> flashback table roger.test_copy2 to before truncate force;
Succeed.
A                                        B
1                                        www.enmotech.com
1                                        www.killdb.com
666                                      www.modb.pro
3 rows fetched.
可以看到非常强大;仍然可以进行闪回。。。。 这样妈妈再也不用担心数据被truncate了。。。。
那么如果表被ddl change了,还能闪回吗? 我们进一步验证一下呢?
SQL> create table roger.test_copy3 as select * from roger.test;
Succeed.
SQL> select * from roger.test_copy3;
A                                        B
1                                        www.enmotech.com
1                                        www.killdb.com
666                                      www.modb.pro
3 rows fetched.
SQL> desc roger.test_copy3
Name                                Null?    Type
A                                            NUMBER
B                                            VARCHAR(20 BYTE)
SQL> truncate table roger.test_copy3;
Succeed.
SQL> alter table roger.test_copy3 modify (b VARCHAR(30));
Succeed.
SQL> insert into roger.test_copy3 values(55,'support.enmotech.com');
1 rows affected.
SQL> commit;
Succeed.
A                                        B
55                                       support.enmotech.com
1 rows fetched.
SQL> flashback table roger.test_copy3 to before truncate force;
GS-00732, The table definition of ROGER.TEST_COPY3 has been changed.
SQL>
SQL> alter table roger.test_copy3 modify (b VARCHAR(20));
GS-00805, Column B is not empty in table TEST_COPY3
SQL>
SQL> delete from roger.test_copy3;
1 rows affected.
SQL> commit;
Succeed.
Succeed.
SQL>
可以看到,如果表进行了ddl 变更,即表定义发生了改变,就不再能进行flashback了。
总的来说,gaussdb这个flashback table的功能还是非常赞的。
转自“墨天轮”
