【Ascend 310常见问题处理】Mind Studio安装时执行apt-get update命令检查源配置出错
山人_mhc 发表于 2020/03/02 14:15:55 2020/03/02
【摘要】 Ascend 310常见问题处理方法
问题1:
Mind Studio部署前环境准备阶段,配置完源依赖后,执行apt-get update命令,报以下错误:
Aborted (core dumped)
Reading package lists… Done
E: Problem executing scripts APT::Update::Post-Invoke-Success ‘if /usr/bin/test -w /var/cache/app-info -a -e /usr/bin/appstreamcli; then appstreamcli refresh > /dev/null; fi’
E: Sub-process returned an error code
解决方法:
缺少libappstream3库,执行如下命令进行先清除相关软件包,在执行更新:
sudo apt-get purge libappstream3
sudo apt-get update
问题2:
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
解决方法:
执行如下命令删除lock:
sudo rm /var/cache/apt/archives/lock
sudo rm /var/lib/dpkg/lock
每日推送Ascend 310常见问题及处理方法,更多昇腾技术干货,尽在昇腾社区等你,敬请持续关注!
