PHP接入快递鸟查询快递api接口demo
爱程序的小猿 发表于 2020/01/27 13:38:33 2020/01/27
【摘要】 今天做物流查询,用到了快递鸟.首先去快递鸟官网注册一个账号,然后进行实名认证.认证完之后进会员中心.这里有用户id和api key.在右侧技术支持中有一个API开发指南.之前已经实名认证过了,直接点击技术文档我现在用的是PHP,下载PHP版的. <?php//电商IDdefined('EBusinessID') or define('EBusinessID', '请到快递鸟官网申请http:...
今天做物流查询,用到了快递鸟.
这里有用户id和api key.
在右侧技术支持中有一个API开发指南.
之前已经实名认证过了,直接点击技术文档
我现在用的是PHP,下载PHP版的.
<?php
//电商ID
defined('EBusinessID') or define('EBusinessID', '请到快递鸟官网申请http://kdniao.com/reg');
//电商加密私钥,快递鸟提供,注意保管,不要泄漏
defined('AppKey') or define('AppKey', '请到快递鸟官网申请http://kdniao.com/reg');
//请求url
defined('ReqURL') or define('ReqURL', 'http://api.kdniao.com/Ebusiness/EbusinessOrderHandle.aspx');
//调用查询物流轨迹
$logisticResult=getOrderTracesByJson();
echo $logisticResult;
* Json方式 查询订单物流轨迹
function getOrderTracesByJson(){
   $requestData= "{'OrderCode':'','ShipperCode':'YTO','LogisticCode':'12345678'}";
   $datas = array(
       'EBusinessID' => EBusinessID,
       'RequestType' => '1002',
       'RequestData' => urlencode($requestData) ,
       'DataType' => '2',
   $datas['DataSign'] = encrypt($requestData, AppKey);
   $result=sendPost(ReqURL, $datas);
   //根据公司业务处理返回的信息......
   return $result;
*  post提交数据
* @param  string $url 请求Url
* @param  array $datas 提交的数据
* @return url响应返回的html
function sendPost($url, $datas) {
   $temps = array();
   foreach ($datas as $key => $value) {
       $temps[] = sprintf('%s=%s', $key, $value);
   $post_data = implode('&', $temps);
   $url_info = parse_url($url);
   if(empty($url_info['port']))
       $url_info['port']=80;
   $httpheader = "POST " . $url_info['path'] . " HTTP/1.0\r\n";
   $httpheader.= "Host:" . $url_info['host'] . "\r\n";
   $httpheader.= "Content-Type:application/x-www-form-urlencoded\r\n";
   $httpheader.= "Content-Length:" . strlen($post_data) . "\r\n";
   $httpheader.= "Connection:close\r\n\r\n";
   $httpheader.= $post_data;
   $fd = fsockopen($url_info['host'], $url_info['port']);
   fwrite($fd, $httpheader);
   $gets = "";
   $headerFlag = true;
   while (!feof($fd)) {
       if (($header = @fgets($fd)) && ($header == "\r\n" || $header == "\n")) {
           break;
       $gets.= fread($fd, 128);
   fclose($fd);
   return $gets;
* 电商Sign签名生成
* @param data 内容
* @param appkey Appkey
* @return DataSign签名
function encrypt($data, $appkey) {
   return urlencode(base64_encode(md5($data.$appkey)));
这里的EBusinessID的值和AppKey的值就是会员中心那个页面的用户id和api key
在getOrderTracesByJson()方法中的ShipperCode是快递公司的编码,可以在快递鸟里面下载快递公司编码
LogisticCode是快递单号
改一下EBusinessID, AppKey, ShipperCode, LogisticCode这四个值,再运行这个PHP文件就可以了.
