service broker如何对接华为云
zhongjun2 发表于 2020/01/21 16:57:34 2020/01/21
【摘要】 什么是service broker通常程序员要编码数据库源语处理Mysql、PostgreSQL等数据库,逻辑复杂以后处理数据库的代码变的异常复杂,于是程序员把这些复杂的代码整理起来,就变成了service broker。在需要处理复杂sql逻辑的时候,调用service broker就可以用统一的命令实现。 service broker可以和cloudfoundry、openshift等配...
什么是service broker
service broker可以和cloudfoundry、openshift等配合使用,平台上的应用需要对接数据库,只用安装service broker,配置好service broker需要的yaml文件,告诉service broker你需要管理什么数据库,service broker就帮你创建、绑定、删除等,帮你用简单的统一的命令管理不同类型的数据库。
如何本地测试service broker功能
1、  在华为云上创建rds
如果对rds参数非常熟悉的可以跳过此步骤
                   图1
                   图2                                     图3
                  图4
rds-tt实例创建成功
                 图5
2、rds绑定ip
           图6                                           图7
3、rds创建数据库
            图8
4、将图中的参数值记录到config.json文件中。
git clone https://github.com/huaweicloud/huaweicloud-service-broker
cd huaweicloud-service-broker
vi config.json
其他类型的数据库参数配置详见:
 https://github.com/huaweicloud/huaweicloud-service-broker/blob/master/config.json
https://github.com/huaweicloud/huaweicloud-service-broker/blob/master/docs/configuration.md
    "broker_config": {
        "log_level": "DEBUG",
        "username": "username",
        "password": "password"
    "back_database": {
        "database_type": "mysql",        //图2
        "database_host": "100.3.3.3",     //图7
        "database_port": "3306",
        "database_name": "broker",       //图8
        "database_username": "root",     //图4
        "database_password": "ppp"      //图4
    // 详见:https://support.huaweicloud.cn/api-iam/zh-cn_topic_0057845624.html
    "cloud_credentials": {
        "auth_url": "https://iam.cn-north-4.myhuaweicloud.com",
        "user_name": "user_name",
        "password": "psword",
        "domain_name": "domain_name",
        "tenant_name": "cn-north-4",
        "region": "cn-north-4",
        "access_key": "xxxxxxxxxxxxxxxx",
        "secret_key": "yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy"
    "catalog": {
        "services": [
                "id": "275f3e0b-86fd-4303-946c-171374d29150",
                "name": "rds-mysql",
                "description": "RDS MySQL Service",
                "bindable": true,
                "tags": [
                    "mysql",
                    "relational"
                "plan_updateable": true,
                "plans": [
                        "id": "fc1b0ebf-aabf-4ab1-87e9-83544a5902e8",
                        "name": "5.7.21",   //图2
                        "description": "RDS MySQL 5.7.21",
                        "metadata": {
                            //图2、3、4
                            "parameters": {
                                "datastore_type": "MySQL",
                                "datastore_version": "5.7",
                                "speccode": "rds.mysql.m1.xlarge",
                                "volume_type": "ULTRAHIGH",
                                "volume_size": 100,
                                "availability_zone": "cn-north-4a",
                                "vpc_id": "0157ad02-451d-4f93-9f8d-8e9b50ca8678",
                                "subnet_id": "30e0ecdb-8e5d-4474-b755-68681be4d182",
                                "security_group_id": "c879a26e-a36b-48f0-a635-61c67ec2128d",
5、启动服务
./huaweicloud-service-broker --config config.json
6、创建数据库
curl -H 'Accept: application/json' -H 'Content-Type: application/json' -H 'X-Broker-Api-Version: 2.x' -X PUT "http://username:password@localhost:3000/v2/service_instances/testrdsmysql?accepts_incomplete=true" -d '{"service_id":"275f3e0b-86fd-4303-946c-171374d29150","plan_id":"fc1b0ebf-aabf-4ab1-87e9-83544a5902e8","organization_guid":"organization_id","space_guid":"space_id","parameters":{"name":"testrdsmysql", "database_password": "Mysql1234!"}}}'
绑定链接数据库
#curl -H 'Accept: application/json' -H 'Content-Type: application/json' -H 'X-Broker-Api-Version: 2.x' -X PUT "http://username:password@localhost:3000/v2/service_instances/testrdsmysql/service_bindings/testrdsmysqlbinding" -d '{"service_id":"275f3e0b-86fd-4303-946c-171374d29150","plan_id":"fc1b0ebf-aabf-4ab1-87e9-83544a5902e8"}'
{"credentials":{"host":"root","port":3306,"username":"root","password":"Mysql1234!",                                                     "uri":"root:Mysql1234!@root:3306","type":"rds-mysql"}}
其他去绑定数据库、删除数据库等操作命令详见如下链接:
https://github.com/huaweicloud/huaweicloud-service-broker/blob/master/scripts/lifecycle.sh
