GaussDB T 基础入门:等待事件 的分类和数量等
GaussDB小粉 发表于 2020/01/17 14:34:40 2020/01/17
【摘要】 等待事件是会话等待某个系统行为发生的事件。等待事件可能由许多因素引起,从磁盘上的慢速读/写,到架构引起的锁定情况,到各种系统资源争用。
等待是系统级或会话级的。会话级等待事件是影响数据库中单个用户活动的事件。系统级等待事件会影响整个数据库系统。用户可通过对等待事件进行分析来定位系统性能问题。
GaussDB T 提供了总共7大类等待事件:Idle、Concurrency、Other、Commit、Application、User I/O、Configuration,总共31种等待事件。
可通过DV_SESSION_EVENTS、DV_SESSION_WAITS查询会话级等待事件的统计信息,可通过DV_SYS_EVENTS查询系统级等待事件的统计信息。
Name                                Null?    Type
EVENT#                              NOT NULL BINARY_INTEGER
EVENT                               NOT NULL VARCHAR(64 BYTE)
P1                                 NOT NULL VARCHAR(64 BYTE)
WAIT_CLASS                            NOT NULL VARCHAR(64 BYTE)
TOTAL_WAITS                            NOT NULL BINARY_BIGINT
TIME_WAITED                            NOT NULL BINARY_BIGINT
TIME_WAITED_MIRCO                         NOT NULL BINARY_BIGINT
AVERAGE_WAIT                           NOT NULL BINARY_DOUBLE
AVERAGE_WAIT_MIRCO                        NOT NULL BINARY_BIGINT
SQL> select count(*) from DV_SYS_EVENTS;
COUNT(*)
31
1 rows fetched.
SQL> select event ,wait_class from dv_sys_events;
EVENT                                                            WAIT_CLASS
idle wait                                                        Idle
message from client                                                   Idle
message to client                                                    Idle
latch: large pool                                                    Concurrency
latch: sql pool                                                     Concurrency
latch: lock pool                                                     Concurrency
latch: dictionary pool                                                  Concurrency
latch: data buffer pool                                                 Concurrency
latch: cache buffers chains                                               Concurrency
cursor: mutex                                                      Other
library : mutex                                                     Other
log file sync                                                      Commit
buffer busy waits                                                    Concurrency
enq: TX row lock contention                                               Application
enq: TX alloc itl entry                                                 Concurrency
enq: TX index contention                                                 Application
enq: TX table lock S                                                   Application
enq: TX table lock X                                                   Application
enq: TX read  wait                                                   Application
db file scattered read                                                  User/IO
db file sequential read                                                 User/IO
log file switch(checkpoint incomplete)                                          Configuration
log file switch(archiving needed)                                            Configuration
read by other session                                                  Concurrency
attached to agent                                                    Idle
heap find map                                                      Concurrency
heap extend segment                                                   Concurrency
resmgr: io quantum                                                    User/IO
direct path read temp                                                  User/IO
direct path write temp                                                  User/IO
advisory lock wait time                                                 Concurrency
31 rows fetched.
SQL>
转自墨天轮
