envoy proxy的配置介绍
fuziye 发表于 2019/12/26 20:57:39 2019/12/26
【摘要】 § envoy proxy的配置包含以下四个部分§ 1. bootstrap: Envoy proxy启动时候加载的静态配置Bootstrap 是 Envoy 中配置的根本来源,Bootstrap 消息中有一个关键的概念,就是静态和动态资源的之间的区别。§ #2. listeners: 监听器配置,使用LDS下发Listener 顾名思义,监听器,监听的IP地址和端口§ 关键字段addres...
§ 关键字段
  • address
    改字段定义了服务的地址和端口
    例如监听ingressgateway的的address
      "listener": {
        "name": "0.0.0.0_15443",
        "address": {
         "socket_address": {
          "address": "0.0.0.0",
          "port_value": 15443
  • filter_chains:
    改字段定义了一系列作用在该监听服务上的操作。
    在istio中可以通过创建envoyfilter来拓展filter
    例如ingressgateway的filter_chains
        "filter_chains": [
          "filter_chain_match": {
           "server_names": [
            "*.uzone1.region1"
          "filters": [
            "name": "envoy.filters.network.sni_cluster"
            "name": "mixer",
            "config": {
             "transport": {
              "check_cluster": "outbound|15004||istio-policy.istio-system.svc.cluster.local",
              "network_fail_policy": {
               "policy": "FAIL_CLOSE",
               "max_retry_wait": "1s",
               "base_retry_wait": "0.080s"
              "report_cluster": "outbound|15004||istio-telemetry.istio-system.svc.cluster.local"
             "mixer_attributes": {
              "attributes": {
               "context.reporter.kind": {
                "string_value": "outbound"
               "source.namespace": {
                "string_value": "istio-system"
               "context.reporter.uid": {
                "string_value": "kubernetes://istio-ingressgateway-77bbb77959-f9lgg.istio-system"
               "source.uid": {
             "disable_check_calls": true
            "name": "envoy.filters.network.tcp_cluster_rewrite",
            "config": {
             "cluster_replacement": ".svc.cluster.local",
             "cluster_pattern": "\\.global$"
            "name": "envoy.tcp_proxy",
            "config": {
             "stat_prefix": "BlackHoleCluster",
             "cluster": "BlackHoleCluster"
§ 其他字段
§ 3.clusters: 集群配置
Cluster指的是Envoy连接的一组逻辑相同的上游主机, Envoy通过服务发现来发现cluster成员。Istio中的ServiceEntry、DestinationRule都会作用到cluster字段
ServiceEntry配置
apiVersion: networking.istio.io/v1alpha3
kind: ServiceEntry
metadata:
  generation: 1
  namespace: test
spec:
  endpoints:
  - address: 192.xxx.xx.xx
    ports:
      grpc: 35522
  hosts:
  - productcatalogservice.test.global
  ports:
  - name: grpc
    number: 3550
    protocol: GRPC
  resolution: DNS
Envoyfilter cluster配置
     "cluster": {
      "name": "outbound_.3550_._.productcatalogservice.test.global",
      "type": "STRICT_DNS",
      "connect_timeout": "10s",
      "circuit_breakers": {
       "thresholds": [
         "max_retries": 1024
      "dns_refresh_rate": "300s",
      "dns_lookup_family": "V4_ONLY",
      "metadata": {
       "filter_metadata": {
        "istio": {
         "config": "/apis/networking/v1alpha3/namespaces/micro-demo/destination-rule/istio-dr-product"
      "load_assignment": {
       "cluster_name": "outbound_.3550_._.productcatalogservice.test.global",
       "endpoints": [
         "lb_endpoints": [
           "endpoint": {
            "address": {
             "socket_address": {
              "address": "192.xx.xx.xx",
              "port_value": 35522
           "load_balancing_weight": 1
§ 关键字段
  • type:即服务发现类型,支持的参数有 STATIC(缺省值)、STRICT_DNS、LOGICAL_DNS、EDS、ORIGINAL_DST。
例如一个istio ServiceEntry对应的cluster, 指明了流向流向cluster要去的地址
§ 其他字段
§ 4.routes: 路由配置
这个路由配置的作用是,是把流量路由到上面提到过的cluster中。 可以做重定向、转发、重试等任务。
改字段可以通过istio中的VirtualService字段来设置生成,通过RDS下发
VirtualService例子
改virtualService吧url 前缀为 /(所有请求)的流量都路由到了frontend
kind: VirtualService
metadata:
  namespace: test
  selfLink: >-
    /apis/networking.istio.io/v1alpha3/namespaces/micro-demo/virtualservices/frontend-ingress
spec:
  hosts:
  gateways:
    - frontend-gateway
  http:
    - match:
        - uri:
            prefix: /
      route:
        - destination:
            host: frontend
            port:
              number: 80
route例子
      "virtual_hosts": [
        "name": "*:81",
        "domains": [
         "*:81"
        "routes": [
          "match": {
           "prefix": "/"
          "route": {
           "cluster": "outbound|80||frontend.test.svc.cluster.local",
           "timeout": "0s",
           "retry_policy": {
            "retry_on": "connect-failure,refused-stream,unavailable,cancelled,resource-exhausted,retriable-status-codes",
            "num_retries": 2,
            "retry_host_predicate": [
              "name": "envoy.retry_host_predicates.previous_hosts"
            "host_selection_retry_max_attempts": "5",
            "retriable_status_codes": [
             503
           "max_grpc_timeout": "0s"
          "metadata": {
            "istio": {
             "config": "/apis/networking/v1alpha3/namespaces/test/virtual-service/frontend-vs"
          "decorator": {
           "operation": "frontend.test.svc.cluster.local:80/*"
          "per_filter_config": {
           "mixer": {
            "forward_attributes": {
             "attributes": {
              "destination.service.uid": {
               "string_value": "istio://test/services/frontend"
              "destination.service.host": {
               "string_value": "frontend.test.svc.cluster.local"
              "destination.service.namespace": {
               "string_value": "test"
              "destination.service.name": {
               "string_value": "frontend"
§ 关键字段
  • match:路由匹配参数。例如 URL prefix(前缀)、path(URL 的完整路径)、regex(规则表达式)等。
  • route:这里面配置路由的行为,可以是 route、redirect 和 direct_response,不过这里面没有专门的一个配置项用来配置以上三种行为,而是根据实际填充的配置项来确定的。例如在此处添加 cluster 配置则暗示路由动作为”route“,表示将流量路由到该 cluster。详情请参考 route.RouteAction。
§ 其他字段
§ 参考
https://jimmysong.io/istio-handbook/data-plane/envoy-proxy-config-deep-dive.html
