GaussDB T分布式分布式DN和CN实例内存调整
社会主义的一块砖 发表于 2019/12/25 19:01:39 2019/12/25
【摘要】 GaussDB T提供了gs_gucZenith工具来帮助完成在线状态下对CN和DN的内核参数设置。此处将分别演示对DN和CN实例进行内存压缩。查看实力当前状态[omm@Gauss1 ~]$ gs_om -t statusSet output to terminal.---------------------------------------------------------------...
查看实力当前状态
--------------------------------------------------------------------Cluster Status--------------------------------------------------------------------
az_state :      single_az
cluster_state : Normal
balanced :      true
----------------------------------------------------------------------AZ Status-----------------------------------------------------------------------
AZ:AZ1                ROLE:primary            STATUS:ONLINE
---------------------------------------------------------------------Host Status----------------------------------------------------------------------
HOST:Gauss1           AZ:AZ1                  STATUS:ONLINE       IP:192.168.10.11
HOST:Gauss2           AZ:AZ1                  STATUS:ONLINE       IP:192.168.10.12
HOST:Gauss3           AZ:AZ1                  STATUS:ONLINE       IP:192.168.10.13
HOST:Gauss4           AZ:AZ1                  STATUS:ONLINE       IP:192.168.10.14
----------------------------------------------------------------Cluster Manager Status----------------------------------------------------------------
INSTANCE:CM1          ROLE:slave              STATUS:ONLINE       HOST:Gauss1           ID:601
INSTANCE:CM2          ROLE:slave              STATUS:ONLINE       HOST:Gauss2           ID:602
INSTANCE:CM3          ROLE:slave              STATUS:ONLINE       HOST:Gauss3           ID:603
INSTANCE:CM4          ROLE:primary            STATUS:ONLINE       HOST:Gauss4           ID:604
---------------------------------------------------------------------ETCD Status----------------------------------------------------------------------
INSTANCE:ETCD1        ROLE:follower           STATUS:ONLINE       HOST:Gauss1           ID:701      PORT:2379         DataDir:/opt/huawei/gaussdb/data/etcd/data_etcd1
INSTANCE:ETCD2        ROLE:leader             STATUS:ONLINE       HOST:Gauss2           ID:702      PORT:2379         DataDir:/opt/huawei/gaussdb/data/etcd/data_etcd1
INSTANCE:ETCD3        ROLE:follower           STATUS:ONLINE       HOST:Gauss3           ID:703      PORT:2379         DataDir:/opt/huawei/gaussdb/data/etcd/data_etcd1
----------------------------------------------------------------------CN Status-----------------------------------------------------------------------
INSTANCE:cn_401       ROLE:no role            STATUS:ONLINE       HOST:Gauss1           ID:401      PORT:8000         DataDir:/opt/gaussdb/data/cn
INSTANCE:cn_402       ROLE:no role            STATUS:ONLINE       HOST:Gauss2           ID:402      PORT:8000         DataDir:/opt/gaussdb/data/cn
INSTANCE:cn_403       ROLE:no role            STATUS:ONLINE       HOST:Gauss3           ID:403      PORT:8000         DataDir:/opt/gaussdb/data/cn
INSTANCE:cn_404       ROLE:no role            STATUS:ONLINE       HOST:Gauss4           ID:404      PORT:8000         DataDir:/opt/gaussdb/data/cn
---------------------------------------------------------Instances Status in Group (group_1)----------------------------------------------------------
INSTANCE:DB1_1        ROLE:standby            STATUS:ONLINE       HOST:Gauss1           ID:1        PORT:40000        DataDir:/opt/gaussdb/data/dn1
INSTANCE:DB1_2        ROLE:primary            STATUS:ONLINE       HOST:Gauss2           ID:2        PORT:40021        DataDir:/opt/gaussdb/data/dn1
---------------------------------------------------------Instances Status in Group (group_2)----------------------------------------------------------
INSTANCE:DB2_3        ROLE:primary            STATUS:ONLINE       HOST:Gauss2           ID:3        PORT:40000        DataDir:/opt/gaussdb/data/dn2
INSTANCE:DB2_4        ROLE:standby            STATUS:ONLINE       HOST:Gauss3           ID:4        PORT:40021        DataDir:/opt/gaussdb/data/dn2
---------------------------------------------------------Instances Status in Group (group_3)----------------------------------------------------------
INSTANCE:DB3_5        ROLE:primary            STATUS:ONLINE       HOST:Gauss3           ID:5        PORT:40000        DataDir:/opt/gaussdb/data/dn3
INSTANCE:DB3_6        ROLE:standby            STATUS:ONLINE       HOST:Gauss4           ID:6        PORT:40021        DataDir:/opt/gaussdb/data/dn3
---------------------------------------------------------Instances Status in Group (group_4)----------------------------------------------------------
INSTANCE:DB4_8        ROLE:standby            STATUS:ONLINE       HOST:Gauss1           ID:8        PORT:40021        DataDir:/opt/gaussdb/data/dn4
INSTANCE:DB4_7        ROLE:primary            STATUS:ONLINE       HOST:Gauss4           ID:7        PORT:40000        DataDir:/opt/gaussdb/data/dn4
--------------------------------------------------Manage IP--------------------------------------------------
HOST:Gauss1           IP:192.168.10.11
HOST:Gauss2           IP:192.168.10.12
HOST:Gauss3           IP:192.168.10.13
HOST:Gauss4           IP:192.168.10.14
[omm@Gauss1 ~]$
1.DN实例内存调整
    1>查看当前主机负载及DN实例内存配置
[omm@Gauss1 ~]$ gs_checkperf
The cpu and memory statistics information of every DN:
                        DB4_7  CPU    uasge : 1.09
                        DB4_7  memory uasge : 76.0%
                        DB3_6  CPU    uasge : 1.09
                        DB3_6  memory uasge : 76.0%
                        DB3_5  CPU    uasge : 2.17
                        DB3_5  memory uasge : 76.0%
                        DB2_4  CPU    uasge : 2.17
                        DB2_4  memory uasge : 76.0%
                        DB2_3  CPU    uasge : 2.42
                        DB2_3  memory uasge : 76.0%
                        DB1_2  CPU    uasge : 2.42
                        DB1_2  memory uasge : 76.0%
                        DB4_8  CPU    uasge : 4.33
                        DB4_8  memory uasge : 56.0%                --各DB实例内存使用均较高
                        DB1_1  CPU    uasge : 4.33
                        DB1_1  memory uasge : 56.0%
[omm@Gauss1 ~]$ zsql omm/'kevinA1!'@192.168.10.14:40000
Warning: SSL connection to server without CA certificate is insecure. Continue anyway? (y/n):y
connected.
SQL> show parameter DATA_BUFFER_SIZE
NAME                                                             DATATYPE             VALUE
DATA_BUFFER_SIZE                                                 GS_TYPE_INTEGER      2G
SQL> show parameter SHARED_POOL_SIZE
NAME                                                             DATATYPE             VALUE
SHARED_POOL_SIZE                                                 GS_TYPE_INTEGER      1G
SQL> show parameter TEMP_BUFFER_SIZE
NAME                                                             DATATYPE             VALUE
TEMP_BUFFER_SIZE                                                 GS_TYPE_INTEGER      1G
SQL>
如上参数为重置建库模版创建,这也就是为什么为何安装时启库报错需要4.5G左右内存的原因,因为模版要求确实有点高。
    2>执行调整
    使用gs_gucZenith命令在线对各个DN实例核心内存进行调整:
[omm@Gauss1 ~]$ gs_gucZenith -c "DATA_BUFFER_SIZE=450M" -I DB4_8,DB4_7,DB3_6,DB3_5,DB2_4,DB2_3,DB1_2,DB1_1
[omm@Gauss1 ~]$ gs_gucZenith -c "SHARED_POOL_SIZE=150M" -I DB4_8,DB4_7,DB3_6,DB3_5,DB2_4,DB2_3,DB1_2,DB1_1
[omm@Gauss1 ~]$ gs_gucZenith -c "TEMP_BUFFER_SIZE=150M" -I DB4_8,DB4_7,DB3_6,DB3_5,DB2_4,DB2_3,DB1_2,DB1_1
命令执行过程示例:
B2_3,DB1_2,DB1_1Get cluster status.
Start getting healthy zenith instances...
Successfully got healthy zenith instances.
Start verifying the specifications of the kernel parameter value...
Successfully verified the specifications of the kernel parameter value.
Start setting kernel parameter.
Current value of DB1_1 is "2G"
Set kernel parameter successfully! Instance: DB1_1
Current value of DB1_2 is "2G"
Set kernel parameter successfully! Instance: DB1_2
Current value of DB2_3 is "2G"
Set kernel parameter successfully! Instance: DB2_3
Current value of DB2_4 is "2G"
Set kernel parameter successfully! Instance: DB2_4
Current value of DB3_5 is "2G"
Set kernel parameter successfully! Instance: DB3_5
Current value of DB3_6 is "2G"
Set kernel parameter successfully! Instance: DB3_6
Current value of DB4_8 is "450M"
Set kernel parameter successfully! Instance: DB4_8
Current value of DB4_7 is "450M"
Set kernel parameter successfully! Instance: DB4_7
Successfully set kernel parameter.
Please restart the cluster to make the new value take effect.
[omm@Gauss1 ~]$
调整完成后重启性能提升:
[omm@Gauss1 ~]$ gs_om -t stop
[omm@Gauss1 ~]$ gs_om -t stopetcd
[omm@Gauss1 ~]$ gs_om -t startetcd
注:实际如果是修改单实例,只需重启单实例就好。
gs_om -t停止-h高斯1 -I DB1_1
gs_om -t start -h高斯1 -I DB1_1
    3>验证查看
    修改完成后重新查看:
connected.
NAME                                                             DATATYPE             VALUE
DATA_BUFFER_SIZE                                                 GS_TYPE_INTEGER      450M
NAME                                                             DATATYPE             VALUE
TEMP_BUFFER_SIZE                                                 GS_TYPE_INTEGER      150M
NAME                                                             DATATYPE             VALUE
SHARED_POOL_SIZE                                                 GS_TYPE_INTEGER      150M
SQL>
                        DB4_7  CPU    uasge : 0.6
                         DB4_7  memory uasge : 18.0%
                        DB3_6  CPU    uasge : 0.6
                        DB3_6  memory uasge : 18.0%
                        DB3_5  CPU    uasge : 1.86
                        DB3_5  memory uasge : 18.0%
                        DB2_4  CPU    uasge : 1.86
                        DB2_4  memory uasge : 18.0%
                        DB2_3  CPU    uasge : 2.09
                        DB2_3  memory uasge : 18.0%
                        DB1_2  CPU    uasge : 2.09
                        DB1_2  memory uasge : 18.0%
                        DB4_8  CPU    uasge : 0.85
                        DB4_8  memory uasge : 13.0%
                        DB1_1  CPU    uasge : 0.85
                        DB1_1  memory uasge : 13.0%
[omm@Gauss1 ~]$
如上:DN内存参数修改成功,主机内存使用率明显下降。
2. CN实例内存调整
    1>查看CN实例主要内存配置
[omm@Gauss1 ~]$ zsql omm/'kevinA1!'@127.0.0.1:8000
connected.
NAME                                                             DATATYPE             VALUE
NAME                                                             DATATYPE             VALUE
NAME                                                             DATATYPE             VALUE
SQL>
    2>执行内存调整
    进行相同的调整
[omm@Gauss1 ~]$ gs_gucZenith -c "DATA_BUFFER_SIZE=450M" -I cn_401,cn_402,cn_403,cn_404
[omm@Gauss1 ~]$ gs_gucZenith -c "SHARED_POOL_SIZE=150M" -I cn_401,cn_402,cn_403,cn_404
[omm@Gauss1 ~]$ gs_gucZenith -c "TEMP_BUFFER_SIZE=150M" -I cn_401,cn_402,cn_403,cn_404
调整完成后重启性能提升:
    3>验证
    调整完成后查看
connected.
SQL> set line 100
NAME                                                             DATATYPE             VALUE
NAME                                                             DATATYPE             VALUE
NAME                                                             DATATYPE             VALUE
SQL>
如上CN实例调整完成。
到这里,GaussDB T的DN,CN内存调整完成。生产环境,可在线先修改备库,重启备库后参数生效后,再将主库业务切换到备库。依次循环保证在不停业务的情况下实现在线调整。
本文转自“墨天轮”社区GaussDB频道
