GaussDB T 分布式集群部署(2)
社会主义的一块砖 发表于 2019/12/25 18:57:46 2019/12/25
【摘要】 上一篇链接:https://bbs.huaweicloud.cn/blogs/1408195.部署安装[root@Gauss1 ~]# su - ommLast login: Sat Dec 14 20:55:28 CST 2019[omm@Gauss1 ~]$ cd /opt/software/gaussdb/script/[omm@Gauss1 script]$ ./gs_instal...
5.部署安装
[omm@Gauss1 script]$ ./gs_install -X /opt/software/gaussdb/clusterconfig.xml
Parsing the configuration file.
Check preinstall on every node.
Successfully checked preinstall on every node.
Creating the backup directory.
Successfully created the backup directory.
Check the time difference between hosts in the cluster.
Installing the cluster.
Installing applications on all nodes.
Successfully installed APP.
Distribute etcd communication keys.
Successfully distrbute etcd communication keys.
Initializing cluster instances
.............1........111s
[SUCCESS] Gauss1:
Using omm:dbgrp to install database.
Using installation program path : /home/omm
Initialize cn_401 instance
Successfully Initialize cn_401 instance.
Initialize DB1_1 instance
Successfully Initialize DB1_1 instance.
Initialize DB4_8 instance
Successfully Initialize DB4_8 instance.
Modifying user's environmental variable $GAUSS_ENV.
Successfully modified user's environmental variable $GAUSS_ENV.
[FAILURE] Gauss2:
Initialize cn_402 instance
[GAUSS-50601] : The port [8000] is occupied.
[SUCCESS] Gauss3:
Initialize cn_403 instance
Successfully Initialize cn_403 instance.
Initialize DB2_4 instance
Successfully Initialize DB2_4 instance.
Initialize DB3_5 instance
Successfully Initialize DB3_5 instance.
[SUCCESS] Gauss4:
Initialize cn_404 instance
Successfully Initialize cn_404 instance.
Initialize DB3_6 instance
Successfully Initialize DB3_6 instance.
Initialize DB4_7 instance
Successfully Initialize DB4_7 instance.
Successfully modified user's environmental variable $GAUSS_ENV.        .[omm@Gauss1 script]$
发现端口占用,修改clusterconfig.xml 中CN_402端口换8001
[root@Gauss1 ~]# lsof | grep 8000
master      1285            root   43u     unix 0xffff88a877878000        0t0      21308 socket
master      1285            root   74u     unix 0xffff88a8778f8000        0t0      21339 private/local
su        115231            root    4u     unix 0xffff88a96c208000        0t0     463998 socket
[root@Gauss1 ~]# lsof | grep 8001
[root@Gauss1 ~]#
再次执行安装脚本
Last time end with Install cluster.
Continue this step.
Rolling back.
Rollback succeeded.
...............225s
Initializing cluster instances is completed.
Configuring standby datanode.        ............99s
Successfully configure datanode.
Cluster installation is completed.        .Configuring.
Load cluster configuration file.
Configuring the cluster.
Successfully configuring the cluster.
Configuration is completed.
Start cm agent.
Successfully start cm agent and ETCD in cluster.
Starting the cluster.
...........11s
Successfully starting the cluster.
安装完成,查看集群状态
[omm@Gauss1 om]$ gs_om -t status
Set output to terminal.
--------------------------------------------------------------------Cluster Status--------------------------------------------------------------------
az_state :      single_az
cluster_state : Normal
balanced :      true
----------------------------------------------------------------------AZ Status-----------------------------------------------------------------------
AZ:AZ1                ROLE:primary            STATUS:ONLINE
---------------------------------------------------------------------Host Status----------------------------------------------------------------------
HOST:Gauss1           AZ:AZ1                  STATUS:ONLINE       IP:192.168.10.11
HOST:Gauss2           AZ:AZ1                  STATUS:ONLINE       IP:192.168.10.12
HOST:Gauss3           AZ:AZ1                  STATUS:ONLINE       IP:192.168.10.13
HOST:Gauss4           AZ:AZ1                  STATUS:ONLINE       IP:192.168.10.14
----------------------------------------------------------------Cluster Manager Status----------------------------------------------------------------
INSTANCE:CM1          ROLE:primary            STATUS:ONLINE       HOST:Gauss1           ID:601
INSTANCE:CM2          ROLE:slave              STATUS:ONLINE       HOST:Gauss2           ID:602
INSTANCE:CM3          ROLE:slave              STATUS:ONLINE       HOST:Gauss3           ID:603
INSTANCE:CM4          ROLE:slave              STATUS:ONLINE       HOST:Gauss4           ID:604
---------------------------------------------------------------------ETCD Status----------------------------------------------------------------------
INSTANCE:ETCD1        ROLE:follower           STATUS:ONLINE       HOST:Gauss1           ID:701      PORT:2379         DataDir:/opt/huawei/gaussdb/data/etcd/data_etcd1
INSTANCE:ETCD2        ROLE:leader             STATUS:ONLINE       HOST:Gauss2           ID:702      PORT:2379         DataDir:/opt/huawei/gaussdb/data/etcd/data_etcd1
INSTANCE:ETCD3        ROLE:follower           STATUS:ONLINE       HOST:Gauss3           ID:703      PORT:2379         DataDir:/opt/huawei/gaussdb/data/etcd/data_etcd1
----------------------------------------------------------------------CN Status-----------------------------------------------------------------------
INSTANCE:cn_401       ROLE:no role            STATUS:ONLINE       HOST:Gauss1           ID:401      PORT:8000         DataDir:/opt/gaussdb/data/cn
INSTANCE:cn_402       ROLE:no role            STATUS:ONLINE       HOST:Gauss2           ID:402      PORT:8001         DataDir:/opt/gaussdb/data/cn
INSTANCE:cn_403       ROLE:no role            STATUS:ONLINE       HOST:Gauss3           ID:403      PORT:8000         DataDir:/opt/gaussdb/data/cn
INSTANCE:cn_404       ROLE:no role            STATUS:ONLINE       HOST:Gauss4           ID:404      PORT:8000         DataDir:/opt/gaussdb/data/cn
---------------------------------------------------------Instances Status in Group (group_1)----------------------------------------------------------
INSTANCE:DB1_1        ROLE:primary            STATUS:ONLINE       HOST:Gauss1           ID:1        PORT:40000        DataDir:/opt/gaussdb/data/dn1
INSTANCE:DB1_2        ROLE:standby            STATUS:ONLINE       HOST:Gauss2           ID:2        PORT:40021        DataDir:/opt/gaussdb/data/dn1
---------------------------------------------------------Instances Status in Group (group_2)----------------------------------------------------------
INSTANCE:DB2_3        ROLE:primary            STATUS:ONLINE       HOST:Gauss2           ID:3        PORT:40000        DataDir:/opt/gaussdb/data/dn2
INSTANCE:DB2_4        ROLE:standby            STATUS:ONLINE       HOST:Gauss3           ID:4        PORT:40021        DataDir:/opt/gaussdb/data/dn2
---------------------------------------------------------Instances Status in Group (group_3)----------------------------------------------------------
INSTANCE:DB3_5        ROLE:primary            STATUS:ONLINE       HOST:Gauss3           ID:5        PORT:40000        DataDir:/opt/gaussdb/data/dn3
INSTANCE:DB3_6        ROLE:standby            STATUS:ONLINE       HOST:Gauss4           ID:6        PORT:40021        DataDir:/opt/gaussdb/data/dn3
---------------------------------------------------------Instances Status in Group (group_4)----------------------------------------------------------
INSTANCE:DB4_8        ROLE:standby            STATUS:ONLINE       HOST:Gauss1           ID:8        PORT:40021        DataDir:/opt/gaussdb/data/dn4
INSTANCE:DB4_7        ROLE:primary            STATUS:ONLINE       HOST:Gauss4           ID:7        PORT:40000        DataDir:/opt/gaussdb/data/dn4
--------------------------------------------------Manage IP--------------------------------------------------
HOST:Gauss1           IP:192.168.10.11
HOST:Gauss2           IP:192.168.10.12
HOST:Gauss3           IP:192.168.10.13
HOST:Gauss4           IP:192.168.10.14
[omm@Gauss1 om]$
6.测试使用:
[omm@Gauss1 ~]$ zsql omm/'kevinA1!'@127.0.0.1:8000 -q    --以omm链接到cn进行管理
connected.
SQL> select * from db_users;
USER_ID      USERNAME                                                         CREATED
0            SYS                                                              2019-12-15 18:33:28
1            PUBLIC                                                           2019-12-15 18:33:28
2            OMM                                                              2019-12-15 18:33:31
3 rows fetched.
SQL> create user kevin identified by 'kevinA1!';
SQL> grant resource,connect,dba to kevin;
SQL> conn kevin/'kevinA1!'@127.0.0.1:8000
SQL> create table T_test(id number(20) not null,name varchar(40)) distribute by hash(id);        --创建分布式表。
SQL> insert into t_test values(1,'kevin');
SQL> insert into t_test values(2,'kinser');
SQL> insert into t_test select * from t_test;
...   --重复插入
SQL> set timing on
ON
524288 rows affected.
Elapsed: 198.247 sec
1048576 rows affected.
Elapsed: 390.385 sec
2097152 rows affected.
Elapsed: 791.999 sec
SQL> select count(*) from t_test;
COUNT(*)
4194304
1 rows fetched.
Elapsed: 0.122 sec
SQL>
如上,分布式插入性能明显低于单机。
7.补充
启停集群命令:
启集群:
[omm@Gauss1 om]$ gs_om -t startetcd
停集群:
[omm@Gauss1 ~]$ gs_om -t stop
[omm@Gauss1 ~]$ gs_om -t stopetcd
本文转自“墨天轮”社区GaussDB频道
