iOS 获取设备uuid,公网ip,手机ip等信息
feichaiyu 发表于 2019/12/17 21:48:56 2019/12/17
【摘要】 最近公司app需要添加获取用户信息的新功能。将这些 功能写下来,以备不时之需。获取手机uuid+ (String *)getUUID { return [[[UIDevice currentDevice] identifierForVendor] UUIDString];}获取操作系统版本+ (float)getIOSVersion { return [[[UIDevi...
获取手机uuid
+ (String *)getUUID
获取操作系统版本
    return [[[UIDevice currentDevice] systemVersion] floatValue];
获取位置信息
设置请求访问信息
<key>NSLocationWhenInUseUsageDescription</key>
<string>when</string>
<key>NSLocationAlwaysUsageDescription</key>
<string>always</string>
完整代码
#import <CoreLocation/CoreLocation.h>@interface MainViewController ()<CLLocationManagerDelegate>{    CLLocationManager *locationmanager;//定位服务
    NSString *currentCity;//当前城市
    NSString *strlatitude;//经度
    NSString *strlongitude;//纬度}@end@implementation MainViewController- (void)viewDidLoad {
    [super viewDidLoad];
    [self startLocation];    // Do any additional setup after loading the view.}//开始定位- (void)startLocation {    if ([CLLocationManager locationServicesEnabled]) {        //        CLog(@"--------开始定位");
        self.locationManager = [[CLLocationManager alloc]init];        self.locationManager.delegate = self;        //控制定位精度,越高耗电量越大
        self.locationManager.desiredAccuracy = kCLLocationAccuracyKilometer;        // 总是授权
        [self.locationManager requestAlwaysAuthorization];        self.locationManager.distanceFilter = 10.0f;
        [self.locationManager startUpdatingLocation];
- (void)locationManager:(CLLocationManager *)manager didFailWithError:(NSError *)error {    if ([error code] == kCLErrorDenied) {        CLog(@"访问被拒绝");
    }    if ([error code] == kCLErrorLocationUnknown) {        CLog(@"无法获取位置信息");
}//定位代理经纬度回调#pragma mark 定位成功后则执行此代理方法-(void)locationManager:(CLLocationManager *)manager didUpdateLocations:(NSArray<CLLocation *> *)locations
    [locationmanager stopUpdatingHeading];    //旧址
    CLLocation *currentLocation = [locations lastObject];    CLGeocoder *geoCoder = [[CLGeocoder alloc]init];    //打印当前的经度与纬度
    NSLog(@"%f,%f",currentLocation.coordinate.latitude,currentLocation.coordinate.longitude);
    //反地理编码
    [geoCoder reverseGeocodeLocation:currentLocation completionHandler:^(NSArray<CLPlacemark *> * _Nullable placemarks, NSError * _Nullable error) {        if (placemarks.count > 0) {            CLPlacemark *placeMark = placemarks[0];
            currentCity = placeMark.locality;            if (!currentCity) {
                currentCity = @"无法定位当前城市";
            /*看需求定义一个全局变量来接收赋值*/
            NSLog(@"----%@",placeMark.country);//当前国家
            NSLog(@"%@",currentCity);//当前的城市//            NSLog(@"%@",placeMark.subLocality);//当前的位置//            NSLog(@"%@",placeMark.thoroughfare);//当前街道//            NSLog(@"%@",placeMark.name);//具体地址
获取公网ip
+(NSString *)deviceWANIPAddress
    NSURL *ipURL = [NSURL URLWithString:@"http://ip.taobao.com/service/getIpInfo.php?ip=myip"];
    NSData *data = [NSData dataWithContentsOfURL:ipURL];
    NSDictionary *ipDic = [NSJSONSerialization JSONObjectWithData:data options:NSJSONReadingMutableContainers error:nil];?
    NSString *ipStr = nil;
    if (ipDic && [ipDic[@"code"] integerValue] == 0) { //获取成功
        ipStr = ipDic[@"data"][@"ip"];
    return (ipStr ? ipStr : @"");
获取当前时间
获取当前时间
- (NSString *)currentDateStr{    NSDate *currentDate = [NSDate date];//获取当前时间,日期
    NSDateFormatter *dateFormatter = [[NSDateFormatter alloc] init];// 创建一个时间格式化对象
    [dateFormatter setDateFormat:@"YYYY/MM/dd hh:mm:ss SS "];//设定时间格式,这里可以设置成自己需要的格式
    NSString *dateString = [dateFormatter stringFromDate:currentDate];//将时间转化成字符串
    return dateString;
获取当前时间戳
//获取当前时间戳- (NSString *)currentTimeStr{    NSDate* date = [NSDate dateWithTimeIntervalSinceNow:0];//获取当前时间0秒后的时间
    NSTimeInterval time=[date timeIntervalSince1970]*1000;// *1000 是精确到毫秒,不乘就是精确到秒
    NSString *timeString = [NSString stringWithFormat:@"%.0f", time];    return timeString;
获取移动端ip
需要的头文件
//IP地址需求库  #import <sys/socket.h>
#import <sys/sockio.h>
#import <sys/ioctl.h>
#import <net/if.h>
#import <arpa/inet.h>
获取ip地址
//获取设备IP地址  + (NSString *)getDeviceIPAddresses
    int sockfd = socket(AF_INET,SOCK_DGRAM, 0);
    // if (sockfd <</span> 0) return nil; //这句报错,由于转载的,不太懂,注释掉无影响,懂的大神欢迎指导
    NSMutableArray *ips = [NSMutableArray array];
    int BUFFERSIZE =4096;
    struct ifconf ifc;
    char buffer[BUFFERSIZE], *ptr, lastname[IFNAMSIZ], *cptr;
    struct ifreq *ifr, ifrcopy;
    ifc.ifc_len = BUFFERSIZE;
    ifc.ifc_buf = buffer;
    if (ioctl(sockfd,SIOCGIFCONF, &ifc) >= 0){
        for (ptr = buffer; ptr < buffer + ifc.ifc_len; ){
            ifr = (struct ifreq *)ptr;
            int len =sizeof(struct sockaddr);
            if (ifr->ifr_addr.sa_len > len) {
                len = ifr->ifr_addr.sa_len;
            ptr += sizeof(ifr->ifr_name) + len;
            if (ifr->ifr_addr.sa_family !=AF_INET) continue;
            if ((cptr = (charchar *)strchr(ifr->ifr_name,':')) != NULL) *cptr =0;
            if (strncmp(lastname, ifr->ifr_name,IFNAMSIZ) == 0)continue;
            memcpy(lastname, ifr->ifr_name,IFNAMSIZ);
            ifrcopy = *ifr;
            ioctl(sockfd,SIOCGIFFLAGS, &ifrcopy);
            if ((ifrcopy.ifr_flags &IFF_UP) == 0)continue;
            NSString *ip = [NSString stringWithFormat:@"%s",inet_ntoa(((struct sockaddr_in *)&ifr->ifr_addr)->sin_addr)];
            [ips addObject:ip];
    close(sockfd);
    NSString *deviceIP =@"";
    for (int i=0; i < ips.count; i++){
        if (ips.count >0){
            deviceIP = [NSString stringWithFormat:@"%@",ips.lastObject];
    return deviceIP;
以上方法没有进行测试,使用时需要自己测试。
最后给出自己的个人博客。
转载声明:本文转载自异步社区
原文链接:https://www.epubit.com/articleDetails?id=Ndd4c5a92-8d92-4f42-abfe-337718b71243
