MacBook 生成Git SHH Key
技术火炬手 发表于 2019/12/16 16:51:46 2019/12/16
【摘要】 1:进入ssh文件下cd ~/ .ssh2:生成ssh keyssh-keygen -t rsa -C "你的邮箱"3:提示输入目录,目录可以不填,有默认路径,直接回车// '()'里面是默认路径Enter file in which to save the key (/Users/user/.ssh/id_rsa):4:提示输入密码, 密码可以不填, 默认没有密码,直接回车5:提示再次输入...
1:进入ssh文件下
cd ~/ .ssh
2:生成ssh key
// '()'里面是默认路径
5:提示再次输入密码
Enter passphrase (empty for no passphrase):
Enter same passphrase again:
6:当出现以下图案, 则表示生成 成功
Your identification has been saved in /Users/user/.ssh/id_rsa.
Your public key has been saved in /Users/user/.ssh/id_rsa.pub.
The key fingerprint is:
SHA256:IQP0sSMslL9VG+HXO9oqlnFNTkeI1/m9fBiBoKIcdxk nanananamln@163.com
The key's randomart image is:
+---[RSA 2048]----+
|  .oo . E..o + . |
| ... o +o+..+ =  |
|  ..+ O.*o.... o.|
|   o.=.*.o  o.o o|
|    oo  S  =o..o.|
|    .   . .oo..o.|
+----[SHA256]-----+
6:打开.pub文件复制生成的ssh key粘贴到Git上即可
// 路径是上面的默认路径
sudo vi ~/.ssh/id_rsa.pub
也可以直接用命令把key复制到剪贴板
pbcopy < ~/.ssh/id_rsa.pub
7:配置一下Git
git config --global user.email "你的邮箱"
   git config --global user.name "你的名字"
本文转自“机器在学习”
原文链接:http://www.siyuanblog.com/?p=115201
