欧式聚类
Joey啊 发表于 2019/12/09 16:43:20 2019/12/09
【摘要】 Euclidean Cluster Extraction欧式聚类流程如下:设置一个合适的聚类搜索半径Cluster-Tolerance很重要,如果半径过小,那么会分割出多个对象,如果设置太高会造成多个对应聚类到成一个,因此需要测试找到合适的搜索半径。http://pointclouds.org/documentation/tutorials/cluster_extraction.php#cl...
欧式聚类流程如下:
#include <pcl/kdtree/kdtree.h>#include <pcl/io/pcd_io.h>#include <pcl/point_types.h>#include <pcl/segmentation/extract_clusters.h>pcl::PointCloud<pcl::PointXYZ>::Ptr cloud_filtered (new pcl::PointCloud<pcl::PointXYZ>);// Creating the KdTree object for the search method of the extractionpcl::search::KdTree<pcl::PointXYZ>::Ptr tree (new pcl::search::KdTree<pcl::PointXYZ>);
tree->setInputCloud (cloud_filtered);std::vector<pcl::PointIndices> cluster_indices;
pcl::EuclideanClusterExtraction<pcl::PointXYZ> ec;
ec.setClusterTolerance (0.02); //设置近邻搜索的搜索半径2cmec.setMinClusterSize (100);    //设置一个聚类需要的最少点数目ec.setMaxClusterSize (25000);  //设置一个聚类需要的最大数目ec.setSearchMethod (tree);     //设置点云的搜索方法ec.setInputCloud (cloud_filtered);
ec.extract (cluster_indices);        //从点云中提取聚类并保存到cluster_indices中//保存聚类后的点到磁盘int j = 0;for (std::vector<pcl::PointIndices>::const_iterator it = cluster_indices.begin (); it != cluster_indices.end (); ++it)
   pcl::PointCloud<pcl::PointXYZ>::Ptr cloud_cluster (new pcl::PointCloud<pcl::PointXYZ>);   for (std::vector<int>::const_iterator pit = it->indices.begin (); pit != it->indices.end (); ++pit)
     cloud_cluster->points.push_back (cloud_filtered->points[*pit]); //*
   cloud_cluster->width = cloud_cluster->points.size ();
   cloud_cluster->height = 1;
   cloud_cluster->is_dense = true;   std::cout << "PointCloud representing the Cluster: " << cloud_cluster->points.size () << " data points." << std::endl;   std::stringstream ss;
   ss << "cloud_cluster_" << j << ".pcd";
   writer.write<pcl::PointXYZ> (ss.str (), *cloud_cluster, false); //*
   j++;
