【昇腾】【玩转Atlas200DK系列】Atlas 200 DK安装python2的hiai库以及opencv
山人_mhc 发表于 2019/11/12 12:01:59 2019/11/12
【摘要】 Atlas 200 DK安装python的hiai库以及opencv
【昇腾】开发板上安装python2的hiai库和opencv库
Matrix是已经支持phthon接口了,但是发现目前python的hiai库并没有自动安装,需要自己安装;
话不多说下面是安装步骤:
步骤1. 开发板联网,如果已联网则跳过该步骤;
          否则请参考以下链接配置开发板联网(https://bbs.huaweicloud.cn/forum/thread-26546-1-1.html )
           接下来需要在开发板上配置arm的源(编辑/etc/apt/sources.list内容替换为如下中科大的源或者清华的源);
中科大源
deb http://mirrors.ustc.edu.cn/ubuntu-ports/ xenial main multiverse restricted universe
deb http://mirrors.ustc.edu.cn/ubuntu-ports/ xenial-backports main multiverse restricted universe
deb http://mirrors.ustc.edu.cn/ubuntu-ports/ xenial-proposed main multiverse restricted universe
deb http://mirrors.ustc.edu.cn/ubuntu-ports/ xenial-security main multiverse restricted universe
deb http://mirrors.ustc.edu.cn/ubuntu-ports/ xenial-updates main multiverse restricted universe
deb-src http://mirrors.ustc.edu.cn/ubuntu-ports/ xenial main multiverse restricted universe
deb-src http://mirrors.ustc.edu.cn/ubuntu-ports/ xenial-backports main multiverse restricted universe
deb-src http://mirrors.ustc.edu.cn/ubuntu-ports/ xenial-proposed main multiverse restricted universe
deb-src http://mirrors.ustc.edu.cn/ubuntu-ports/ xenial-security main multiverse restricted universe
deb-src http://mirrors.ustc.edu.cn/ubuntu-ports/ xenial-updates main multiverse restricted universe
清华源:
deb http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports/ xenial main multiverse restricted universe
deb http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports/ xenial-security main multiverse restricted universe
deb http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports/ xenial-updates main multiverse restricted universe
deb http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports/ xenial-backports main multiverse restricted universe
deb-src http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports/ xenial main multiverse restricted universe
deb-src http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports/ xenial-security main multiverse restricted universe
deb-src http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports/ xenial-updates main multiverse restricted universe
deb-src http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports/ xenial-backports main multiverse restricted universe
                 更换源以后注意执行:sudo apt-get update
步骤2. 安装依赖以及hiai库
    a) 安装依赖
(如果apt-get没有sudo权限请配置:在/etc/sudoers中HwHiAiUser的权限配置一行最后添加:/usr/bin/apt-get)
(如果保存不了,保存时用wq!保存即可)
        sudo apt-get install python-setuptools python-dev build-essential python-pip
        pip install numpy==1.16.0 enum34==1.1.6 future==0.17.1 funcsigs==1.0.2
    b) 下载python2_hiai_install.sh
        wget   https://gitee.com/Atlas200DK/sample-classification-python/raw/master/scripts/python2_hiai_install.sh
    c)安装hiai库(需要再root用户下)
            su
            bash python2_hiai_install.sh
步骤3. 安装opencv
            sudo apt-get install python-opencv
4. 检查,登录开发板以后在python下分别执行如下import,不报错则说明hiai和opencv均已经完成安装,可以愉快的玩耍喽:
            import hiai
            import cv2
