pip的源和一些好用的参数
AvatusXan 发表于 2019/11/11 16:00:47 2019/11/11
【摘要】 pip的参数:pip -vvv install [pakagename]pip -vvv uninstall [pakagename]......看到更详细的logpip install [pakagename] --no-cache-dir这种方法来安装包可以缓解有时候pip的log提示:安装成功,但是pip自己一直卡住不退出的情况。或者:直接去删掉缓存目录......缓存目录在:Uni...
pip的参数:
......看到更详细的log
或者:
直接去删掉缓存目录......
缓存目录在:
Unix
~/.cache/pip and it respects the XDG_CACHE_HOME directory.
macOS
~/Library/Caches/pip.
Windows
<CSIDL_LOCAL_APPDATA>\pip\Cache
Wheel Cache
Pip will read from the subdirectory wheels within the pip cache directory and use any packages found there.
参考文档:
https://pip.pypa.io/en/latest/reference/pip_install/#caching
pip的源:
https://pypi.tuna.tsinghua.edu.cn/simple
https://repo.huaweicloud.cn/repository/pypi/simple
Have fun : )
