.net 串口操作学习记录
Amrf 发表于 2019/10/24 20:04:45 2019/10/24
【摘要】 由于既没有实际串口也没有虚拟串口,上面的代码都没有进行实际测试,改进空间应该还比较巨大;首先需要一个单例:private static MSerialPort _instance = null;private static Object _mutex = new Object();public static MSerialPort GetInstance(int ComPortNum) { ...
首先需要一个单例:
    if (_instance == null)
        lock (_mutex) // now I can claim some form of thread safety...
                _instance = new MSerialPort(ComPortNum);
    return _instance;
private MSerialPort(int ComPortNum):base(){
异步写:
public async Task<bool> WriteStr(string value)
    if (!base.IsOpen) {
        if (!doConnect(_ComPortNum)) {
            return false;
    byte[] buffer = new byte[128];
    Encoding.UTF8.GetBytes(value, 0, value.Length, buffer, 0);
    bool flag = false;
    try
        base.BaseStream.WriteTimeout = 2;
        await base.BaseStream.WriteAsync(buffer, 0, 128);
        flag = true;
    catch (Exception ex)
        Console.WriteLine("MSerialPort exception: " + ex);
    return flag;
异步读一次:
public async Task<Tuple<bool,string>> readStr()//ref string value
    if (!base.IsOpen)
        doConnect(_ComPortNum);
    bool flag = false;
    try
        base.BaseStream.ReadTimeout = 2;
        await base.BaseStream.ReadAsync(buffer, 0, 128);//这种一旦读到任何内容就结束
        flag = true;
    return new Tuple<bool, string>(flag, System.Text.Encoding.UTF8.GetString(buffer, 0, buffer.Length));
异步读到特征值:
public async Task<Tuple<bool, MatchCollection>> readUntil(Regex reg)//ref string value,
    Console.WriteLine("readUntil");
    if (!base.IsOpen)
    DateTime beforDT = System.DateTime.Now;
    double spend = 0;
    bool flag = false;
    StringBuilder sb = new StringBuilder();
    MatchCollection matchx = null;
    await Task.Run(() => {
        do
            Array.Clear(buffer, 0, buffer.Length);
            try
                base.BaseStream.Read(buffer, 0, 128);
            }catch(Exception ex)
                //Console.WriteLine("MSerialPort exception: " + ex);
            sb.Append(System.Text.Encoding.UTF8.GetString(buffer, 0, buffer.Length));
            string value = sb.ToString();
            if(value != "")
                matchx = reg.Matches(value);
                if (matchx.Count > 0)
                    flag = true;
                    break;
            DateTime afterDT = System.DateTime.Now;
            TimeSpan ts = afterDT.Subtract(beforDT);
            spend = ts.TotalMilliseconds;
        } while (spend <= 5000.0);
    return new Tuple<bool, MatchCollection>(flag, matchx);
测试调用:
单例:
static async void MyAsyncMethod()
    MSerialPort s = GetInstance(1);
    Task<bool> calculateResult = s.WriteStr("123");
    await calculateResult;
    Regex rx = new Regex(@"(\d+)", RegexOptions.Compiled | RegexOptions.IgnoreCase);
    Task<Tuple<bool, MatchCollection>> calculateResult1 = s.readUntil(rx);
    await calculateResult1;
看到这种建议:
Strongly recommend PInvokeSerialPort, it fires one event for every byte, and more stable than .net built in one ===>(一个c++串口的wrapper)
https://stackoverflow.com/questions/42568662/serial-port-on-c-read-until-a-byte-sequence
其他参考:
https://stackoverflow.com/questions/18716928/how-to-write-a-async-method-with-out-parameter
https://stackoverflow.com/questions/40686776/what-exactly-is-a-reference-in-c-sharp
https://www.tutorialspoint.com/csharp/csharp_reference_parameters.htm+&cd=16&hl=en&ct=clnk&gl=sg
https://stackoverflow.com/questions/11654562/how-to-convert-byte-array-to-string
https://msdn.microsoft.com/en-us/magazine/cc301786.aspx
https://www.codeproject.com/Questions/1060886/Continuosly-serial-port-read
https://blog.csdn.net/xzjxylophone/article/details/6832160
https://blog.csdn.net/u013658041/article/details/78203931
https://stackoverflow.com/questions/51658706/await-async-on-anonymous-function
https://stackoverflow.com/questions/20395826/explicitly-use-a-functask-for-asynchronous-lambda-function-when-action-overloa
https://stackoverflow.com/questions/1897555/what-is-the-equivalent-of-memset-in-c
https://stackoverflow.com/questions/1407715/how-to-quickly-zero-out-an-array/43188508
https://docs.microsoft.com/en-us/dotnet/api/system.text.regularexpressions.regex?view=netframework-4.8
https://www.geeksforgeeks.org/destructors-in-c-sharp/+&cd=1&hl=en&ct=clnk&gl=sg
https://stackoverflow.com/questions/5732282/using-the-destructor-dispose-of-the-base-class
https://csharpindepth.com/articles/singleton+&cd=1&hl=en&ct=clnk&gl=sg
https://stackoverflow.com/questions/4203634/singleton-with-parameters
https://blogs.msdn.microsoft.com/benjaminperkins/2017/03/08/how-to-call-an-async-method-from-a-console-app-main-method/
https://stackoverflow.com/questions/24894774/how-to-use-await-within-main
https://recaffeinate.co/post/how-to-await-console-application/+&cd=4&hl=en&ct=clnk&gl=sg
https://github.com/ebraminio/PInvokeSerialPort
/*-------------------------C#有名管道-------------------------------------*/
https://docs.microsoft.com/en-us/dotnet/api/system.io.pipes.namedpipeclientstream?view=netframework-4.8
https://bytes.com/topic/c-sharp/answers/277259-readtoend-blocking+&cd=2&hl=en&ct=clnk&gl=sg
https://github.com/sovprene/named-pipe-examples/tree/master/Inter-Process%20Communication%20(IPC)/CSNamedPipeClient
https://www.codeproject.com/Articles/864679/Creating-a-Server-Using-Named-Pipes
https://gist.github.com/Suplanus/f652a15a55bff64b6ccb33836041f8bb
https://stackoverflow.com/questions/48059410/using-namedpipeserverstream-and-namedpipeclientstream-asynchronously
https://gist.github.com/AArnott/0d5f4645ad7e9a765cee
https://stackoverflow.com/questions/23304311/async-namedpipeclientstream-implementation-feedback
https://stackoverflow.com/questions/49838628/named-pipe-input-output-in-c-sharp
1.ReadToEnd阻塞的原因(https://bytes.com/topic/c-sharp/answers/277259-readtoend-blocking+&cd=2&hl=en&ct=clnk&gl=sg)
--No - there's no real sense of "all data" until the stream has been
closed, because the server could always have sent some more since you
2.WaitForPipeDrain();//等待管道另一端读取所有
/*-------------------------C#单元测试-------------------------------------*/
https://blog.csdn.net/lang791534167/article/details/50778246
https://docs.microsoft.com/en-us/visualstudio/test/walkthrough-creating-and-running-unit-tests-for-managed-code?view=vs-2019
/*-------------------------C#异步-------------------------------------*/
https://blog.csdn.net/madongchunqiu/article/details/69855744
https://blog.csdn.net/jl1134069094/article/details/50511418
https://blog.csdn.net/a_little_a_day/article/details/78519265
https://codeday.me/bug/20190223/699688.html
https://medium.com/software-development-2/coroutines-and-fibers-why-and-when-5798f08464fd+&cd=3&hl=en&ct=clnk&gl=sg
https://blog.csdn.net/lxrj2008/article/details/78677810
https://blog.csdn.net/wlk1229/article/details/81276970
https://stackoverflow.com/questions/5096926/what-is-the-get-set-syntax-in-c
https://msdn.microsoft.com/en-us/magazine/cc164086.aspx
https://stackoverflow.com/questions/1949051/is-there-a-fiber-api-in-net
https://paoloseverini.wordpress.com/tag/fibers/+&cd=5&hl=zh-CN&ct=clnk&gl=sg
https://medium.com/%40deep_blue_day/long-story-short-async-await-best-practices-in-net-1f39d7d84050+&cd=7&hl=zh-CN&ct=clnk&gl=sg
https://blog.csdn.net/mawming/article/details/52385405
https://docs.microsoft.com/en-us/windows/win32/procthread/fibers
https://stackoverflow.com/questions/31221210/fibers-vs-async-await
https://www.zhihu.com/question/23955356
https://github.com/markpapadakis/coros-fibers
https://medium.com/software-development-2/coroutines-and-fibers-why-and-when-5798f08464fd+&cd=11&hl=zh-CN&ct=clnk&gl=sg
评论(0
