记一次修改sga大小之后出现的一系列报错
技术火炬手 发表于 2019/05/06 15:10:10 2019/05/06
【摘要】 修改了oracle的sga大小之后,遇到了一系列的报错。
00844和00851报错
SQL> startup;ORA-00844: Parameter not taking MEMORY_TARGET into account
ORA-00851: SGA_MAX_SIZE 2147483648 cannot be set to more than MEMSQL>
01078报错
SQL> startup;
ORA-01078: failure in processing system parameters
LRM-00109: could not open parameter file '/u01/app/oracle/product/11.2.4/db_1/dbs/inittest.ora'
一、修改过程
1.1 为什么我要修改sga大小
在测试的时候,插入大量数据发现30009错误,我以为是sga小导致的
SQL> insert into t select rownum from dual connect by level<=10000000;
ERROR at line 1:
ORA-30009: Not enough memory for CONNECT BY operation
Elapsed: 00:00:13.51SQL>
查看sga
SQL> show parameter sga;NAME                     TYPE                  VALUE
lock_sga                 boolean                   FALSE
pre_page_sga                 boolean                   FALSE
sga_max_size                 big integer               1584M
sga_target               big integer               1GSQL>
查看pga
SQL> show parameter pgaNAME                     TYPE                  VALUE
pga_aggregate_target             big integer               0SQL>
1.2 修改sga
更改sga
SQL> alter system set sga_max_size=2048M scope=spfile;System altered.
Elapsed: 00:00:00.06SQL>
1.3 报错1
关闭和启动数据库
SQL> shutdownDatabase closed.
Database dismounted.
ORACLE instance shut down.SQL>SQL> startupORA-00844: Parameter not taking MEMORY_TARGET into account
ORA-00851: SGA_MAX_SIZE 2147483648 cannot be set to more than MEMORY_TARGET 1660944384.
结果出错了。经过查找资料,发现11g新增了个参数MEMORY_TARGET,其大小等于PGA+SGA,当sga的大小大于MEMORY_TARGET就会报如上错误。
查看MEMORY_TARGET大小,发现大小为1584M,与sga不符。
SQL> show parameter memory_target;NAME                     TYPE                  VALUE
memory_target                big integer               1584MSQL>
修改spfile文件中的参数
sga_max_size=1653604352
启动数据库
SQL> startup nomount;
LRM-00109: could not open parameter file '/u01/app/oracle/product/11.2.4/db_1/dbs/inittest.ora'SQL>
1.4 报错2
启动后遇到了01078报错。解决办法如下:
将test(实例名)文件夹下的init.ora.xxx 文件复制到dbs目录下即可,复制后的名字按照之前报错的提示输入。
[oracle@localhost ~]$ cp /u01/app/oracle/admin/test/pfile/init.ora.922018114616 /u01/app/oracle/product/11.2.4/db_1/dbs/inittest.ora
启动数据库
SQL> startup;ORACLE instance started.
Total System Global Area 1653518336 bytes
Fixed Size          2213896 bytes
Variable Size         956303352 bytes
Database Buffers      687865856 bytes
Redo Buffers            7135232 bytes
Database mounted.
Database opened.SQL>
二、总结
归根结底还是对数据库原理不熟导致的,牢记memory_target值需为sga+pga内存的和。
本文转自运维少年博客51CTO博客
如需转载,请联系作者授权
原文链接:https://blog.51cto.com/xiaowangzai/2384925
