OBS JAVA SDK Demo:文件语义桶之修改写、追加写
lanxinliuli 发表于 2019/07/08 10:13:05 2019/07/08
【摘要】 1 背景介绍OBS 文件语义桶支持文件系统语义,提供文件修改写、rename等功能。下面代码展示OBS SDK使用文件语义桶进行修改写、追加写的功能。2 代码展示2.1 文件语义桶之修改写需要先下载OBS最新的JAVA SDK,参考官网链接:https://developer.huaweicloud.cn/sdk?OBS,并在自己的项目中导入SDK中的JAR包...
1      背景介绍
2      代码展示
2.1      文件语义桶之修改写
需要先下载OBS最新的JAVA SDK,参考官网链接:https://developer.huaweicloud.cn/sdk?OBS,并在自己的项目中导入SDK中的JAR包。
前提条件:已创建文件语义桶,例如obs-bigdata00-posix
package samples_java;
import java.io.IOException;
import java.io.ByteArrayInputStream;
import com.obs.services.ObsClient;
import com.obs.services.ObsConfiguration;
import com.obs.services.exception.ObsException;
import com.obs.services.model.*;
import com.obs.services.model.fs.ObsFSFile;
import com.obs.services.model.fs.WriteFileRequest;
public class ObjectTestSample {
private static final String endPoint = "XXX";
private static final String ak = "XXX";
private static final String sk = "XXX";
private static ObsClient obsClient;
private static String bucketName = "obs-bigdata00-posix";
private static String objectKey = "obs-testfile";
public static void main(String[] args)
throws IOException {
        ObsConfiguration config =
new ObsConfiguration();
        config.setSocketTimeout(
30000);
        config.setConnectionTimeout(
10000);
        config.setEndPoint(
endPoint);
try {
            obsClient = new ObsClient(ak, sk, config);
String content = "Hello OBS";
obsClient.putObject(bucketName,objectKey,new ByteArrayInputStream(content.getBytes("UTF-8")), null);
            ObjectMetadata metadata =
obsClient.getObjectMetadata(bucketName,objectKey);
            WriteFileRequest request =
new WriteFileRequest();
            request.setBucketName(
bucketName);
            request.setObjectKey(
objectKey);
            request.setInput(
new ByteArrayInputStream("Hi".getBytes()));
            request.setPosition(
2);
            ObsFSFile result =
obsClient.writeFile(request);
} catch (ObsException e) {
            System.
out.println("Response Code: " + e.getResponseCode());
            System.
out.println("Error Message: " + e.getErrorMessage());
            System.
out.println("Error Code:       " + e.getErrorCode());
            System.
out.println("Request ID:      " + e.getErrorRequestId());
            System.
out.println("Host ID:           " + e.getErrorHostId());
finally {
if (obsClient != null) {
try {
obsClient.close();
catch (IOException e) {
                    System.
out.println(e);
2.2      文件语义桶之追加写
30000);
10000);
        config.setEndPoint(
endPoint);
try {
bucketName);
objectKey);
            request.setInput(
new ByteArrayInputStream("Hi Huawei".getBytes()));
            request.setPosition(metadata.getContentLength());
            ObsFSFile result =
obsClient.appendFile(request);
            System.
            System.
            System.
            System.
            System.
finally {
try {
obsClient.close();
                    System.
out.println(e);
3      效果展示
3.1      文件语义桶之修改写
第一步:上传文件obs-testfile,内容为Hello OBS
第二步:修改写文件obs-testfile,从Position(2)开始,修改内容为Hi,修改后文件obs-testfile,内容为HeHio OBS
3.2      文件语义桶之追加写
第二步:追加写文件obs-testfile后,文件内容为Hello OBSHi Huawei
