pandas的引用与复制
钱塘小甲子 发表于 2019/01/23 20:10:37 2019/01/23
【摘要】 之前一直以为pandas任何的切片和筛选都是引用,也就是说,会改变最原始的数据。但是前几天发现并不是这样的。 下面对最常见的几种pandas 数据截取的方式做一个整理。import pandas as pddef df_gen(): l1 = [1,2,3] l2 = [4,5,6] l3 = [7,6,5] df_t = pd.DataFrame(...
import pandas as pd
def df_gen():
    l1 = [1,2,3]
    l2 = [4,5,6]
    l3 = [7,6,5]
    df_t = pd.DataFrame()
    df_t['a'] = l1
    df_t['b'] = l2
    df_t['c'] = l3
    return df_t
print 'df:', df_gen()
print 'refernece:'
df = df_gen()
d1 = df.a
d1[0] = 999
print '1', df
df = df_gen()
d1 = df.ix[0]
d1[0] = 999
print '2', df
df = df_gen()
d1 = df.loc[1,:]
d1[0] = 999
print '3', df
df = df_gen()
d1 = df['a']
d1[0] = 999
print '4', df
print 'copy:'
df = df_gen()
d1 = df.iloc[1]
d1[0] = 999
print '1', df
df = df_gen()
d1 = df[df.a > 1]
d1[0] = 999
print '2', df
df = df_gen()
d1 = df.loc[df.a > 1, 'b']
d1[0] = 999
print '3', df
        上面总共7种方式,前面四种是引用的方式,后面的三种是复制。
        输出是这样一串:
df:    a  b  c
0  1  4  7
1  2  5  6
2  3  6  5
refernece:
1      a  b  c
0  999  4  7
1    2  5  6
2    3  6  5
1      a  b  c
0  999  4  7
1    2  5  6
2    3  6  5
1      a  b  c
0    1  4  7
1  999  5  6
2    3  6  5
1      a  b  c
0  999  4  7
1    2  5  6
2    3  6  5
copy:
F:/int/ProjectIntern/DatabaseTransfer/dd.py:37: SettingWithCopyWarning:
A value is trying to be set on a copy of a slice from a DataFrame
See the caveats in the documentation: http://pandas.pydata.org/pandas-docs/stable/indexing.html#indexing-view-versus-copy
  d1[0] = 999
1    a  b  c
0  1  4  7
1  2  5  6
2  3  6  5
1 F:/int/ProjectIntern/DatabaseTransfer/dd.py:41: SettingWithCopyWarning:
A value is trying to be set on a copy of a slice from a DataFrame.
Try using .loc[row_indexer,col_indexer] = value instead
  d1[0] = 999
   a  b  c
0  1  4  7
1  2  5  6
2  3  6  5
1    a  b  c
0  1  4  7
1  2  5  6
2  3  6  5
        我们发现pandas不是refernce的时候会有警告。refernce的时候,df原始的值被改变了,说明d1只是一个引用,而后面的copy则不然。
        在使用pandas的时候要注意这一特性。
作者:钱塘小甲子
来源:CSDN
原文:https://blog.csdn.net/qtlyx/article/details/70500145
版权声明:本文为博主原创文章,转载请附上博文链接!
