OBS JAVA SDK Demo:设置桶策略
lanxinliuli 发表于 2019/06/29 15:23:56 2019/06/29
【摘要】 1 背景介绍OBS桶策略可以给特定用户设置特定的权限。下面代码展示通过JAVA SDK给用户桶设置高级桶策略。2 代码展示需要先下载OBS最新的JAVA SDK,参考官网链接:https://developer.huaweicloud.cn/sdk?OBS,并在自己的项目中导入SDK中的JAR包。前提条件:已创建OBS桶,例如my-bucket123设置的桶策略为:给用...
1      背景介绍
2      代码展示
设置的桶策略为:给用户userB给予桶的所有权限和桶内所有对象的读权限
桶策略格式如下,其中domain和user请根据实际账号ID和用户ID进行配置:
  "Statement": [
      "Sid": "Stmt1375240018062",
      "Action": [
      "Effect": "Allow",
      "Resource": "my-bucket123",
      "Principal": {
        "ID": [
          "domain/c41**************************8cf:user/053**************************2c4 "
      "Sid": "Stmt1375240018063",
      "Action": [
        "Get*"
      "Effect": "Allow",
      "Resource": "my-bucket123/*",
      "Principal": {
        "ID": [
Demo代码如下:
 package samples_java;
import com.obs.services.ObsClient;
import com.obs.services.ObsConfiguration;
import com.obs.services.exception.ObsException;
import java.io.IOException;
public class BucketTestSample {
private static final String endPoint = "XXX";
private static final String ak = "XXX";
private static final String sk = "XXX";
private static ObsClient obsClient;
private static String bucketName = "my-bucket123";
public static void main(String[] args)
throws IOException {
        ObsConfiguration config =
new ObsConfiguration();
        config.setSocketTimeout(
30000);
        config.setConnectionTimeout(
10000);
        config.setEndPoint(
endPoint);
try {
obsClient = new ObsClient(ak, sk, config);
            String  Policy =
"{\"Statement\":[{\"Sid\":\"Stmt1375240018062\",\"Action\":[\"*\"],\"Effect\":\"Allow\",\"Resource\":\"my-bucket123\",\"Principal\":{\"ID\":[\"domain/c41**************************8cf:user/053**************************2c4\"]}},{\"Sid\":\"Stmt1375240018063\",\"Action\":[\"Get*\"],\"Effect\":\"Allow\",\"Resource\":\"my-bucket123/*\",\"Principal\":{\"ID\":[\"domain/c41**************************8cf:user/053**************************2c4\"]}}]}";
obsClient.setBucketPolicy(bucketName,Policy);
catch (ObsException e) {
            System.
out.println("Response Code: " + e.getResponseCode());
            System.
out.println("Error Message: " + e.getErrorMessage());
            System.
out.println("Error Code:       " + e.getErrorCode());
            System.
out.println("Request ID:      " + e.getErrorRequestId());
            System.
out.println("Host ID:           " + e.getErrorHostId());
finally {
if (obsClient != null) {
try {
obsClient.close();
catch (IOException e) {
                    System.
out.println(e);
3      效果展示
设置后的桶策略如下:
userB在桶内上传文件失败(没有权限),下载文件成功
4      附录
OBS JAVA SDK使用,官网参考链接:https://support.huaweicloud.cn/sdkreference-obs/obs_02_0001.html
更多桶策略的具体格式(JSON格式字符串)请参考《对象存储服务API参考》:https://support.huaweicloud.cn/api-obs/zh-cn_topic_0100846742.html
