python3抓取m3U8视频
JuneXCoder 发表于 2018/12/30 10:58:26 2018/12/30
【摘要】 最近听了一个课程,流媒体视频只能在线看,视频用python3抓取下来
    最近听了一个课程,视频只能在线看,播放声音很小,机智的我决定把视频抓下来。
首先在网页视频右键-审核元素-把m3u8的路径复制下来,然后路径放到下面的python执行(python3以上版本的),最后再用格式工厂把视频声音增大,视频大小限制(不要超过原视频大小),完美解决问题。如果代码改进可以运用到爬虫抓取。
python示例代码如下:
# !/user/bin/env python
# -*- coding: utf-8 -*-
import os, shutil
import urllib.request, urllib.error, requests
# 打开并读取网页内容
def getUrlData(url):
    try:
        urlData = urllib.request.urlopen(url, timeout=20)  # .read().decode('utf-8', 'ignore')
        # urlData = requests.get(url, timeout=20)  # .read().decode('utf-8', 'ignore')
        return urlData
    except Exception as err:
        print('err getUrlData({url})\n'.format(url), err)
        return -1
# 下载文件-requests
def getDown_reqursts(url, file_path):
    try:
        header = {"User-Agent":"Mozilla/5.0 (Windows NT 6.1; rv:2.0.1) Gecko/20100101 Firefox/4.0.1"}
        response = requests.get(url, timeout=120, headers=header)
        with open(file_path, mode='ab+') as f:
            f.write(response.content)
        # 下载文件较大时,使用循环下载
        print("down successful!")
    except Exception as e:
        print(e)
def getVideo_requests(url_m3u8, path, videoName):
    urlData = getUrlData(url_m3u8)
    tempName_video = os.path.join(path, '%s.ts'%videoName)  # f'{}' 相当于'{}'.format() 或 '%s'%videoName
    open(tempName_video, "wb").close()  # 继续下载重复写入
    # print(urlData)
    for line in urlData:
         url_ts = str(line.decode("utf-8")).strip()  # 清除字符串前后存在的空格符和换行符
        if not '.ts' in url_ts:
            continue
        else:
            if not url_ts.startswith('http'):  # 判断字符串是否以'http'开头,如果不是则说明url链接不完整,需要拼接
                # 拼接ts流视频的url
                url_ts = url_m3u8.replace(url_m3u8.split('/')[-1], url_ts)
        print(url_ts)
        getDown_reqursts(url=url_ts, file_path=tempName_video)  # 下载视频流
    filename = os.path.join(path, '%s.mp4'%videoName)
    shutil.move(tempName_video, filename)
    print('Great,%s.mp4 well down!'%videoName)
if __name__ == '__main__':
    url_m3u8 = 'http://www.xxxx.com/video.m3u8' # 下载视频流地址
    path = r'E:\123\'
    videoName = url_m3u8.split('/')[-2]
