OBS JAVA SDK 实践8:批量下载文件(e.g 下载文件夹)
chongchongly 发表于 2019/07/08 09:50:34 2019/07/08
【摘要】 1 背景介绍 & 效果展示通过OBS JAVA SDK可以实现批量下载文件,如下载文件夹,效果如下。注:有关标准存储、低频访问、归档存储三种存储类型的更多信息,参考链接:https://support.huaweicloud.cn/usermanual-obs/zh-cn_topic_0050321036.html图1 桶下面有“FunctionGraphDemo-VideoCo...
1      背景介绍 & 效果展示
图1 桶下面有“FunctionGraphDemo-VideoConvert/”为前缀的文件夹
图2 把上图中的文件夹下载到本地"C:/software/"目录下
2      java代码参考
前提:
需要先下载OBS最新的JAVA SDK,参考官网链接:https://developer.huaweicloud.cn/sdk?OBS,并在自己的项目中导入SDK中的JAR包。
       public static void main(String[] args) throws IOException {
                   // 需要将endPoint/ak/sk更新为实际信息
                   String endPoint = "https://your-endpoint";
                   String ak = "*** Provide your Access Key ***";
                   String sk = "*** Provide your Secret Key ***";
                   // 创建ObsClient实例
                   ObsClient obsClient = new ObsClient(ak, sk, endPoint);
                   try
                                      String bucketName = "bucketXXX";                // 需要将bucketName更新为实际信息
String fileLocatePrefix = "C:/software/";    // 需要下载到本地哪个目录,这里面举例"C:/software/"
                                       ListObjectsRequest request = new ListObjectsRequest(bucketName);
                                       // 指定下载"FunctionGraphDemo-VideoConvert/"文件夹
                                       request.setPrefix("FunctionGraphDemo-VideoConvert/");
                                       request.setMaxKeys(500);
                                       ObjectListing result;
System.out.println("Objects:");
                                       do{
                                                  result = obsClient.listObjects(request);
                                                 for (ObsObject obsObject : result.getObjects())
                                                 System.out.println("\t" + obsObject.getObjectKey());
                                                 DownloadFileRequest requestDownload = new DownloadFileRequest(bucketName, obsObject.getObjectKey());
                                                 requestDownload.setDownloadFile(fileLocatePrefix+obsObject.getObjectKey());
                                                 // 设置分段下载时的最大并发数
                                                 requestDownload.setTaskNum(5);
                                                 // 设置分段大小为10MB
                                                 requestDownload.setPartSize(10 * 1024 * 1024);
                                                 // 开启断点续传模式
                                                 requestDownload.setEnableCheckpoint(true);
                                                  try{
                                                           // 进行断点续传下载
                                                           DownloadFileResult resultDownload = obsClient.downloadFile(requestDownload);
                                                  }catch (ObsException e) {
System.out.println("Response Code: " + e.getResponseCode());
                                                           System.out.println("Error Message: " + e.getErrorMessage());
                                                           System.out.println("Error Code:       " + e.getErrorCode());
                                                           System.out.println("Request ID:      " + e.getErrorRequestId());
                                                           System.out.println("Host ID:           " + e.getErrorHostId());
                                                  System.out.println("------------------------------");
                                                  request.setMarker(result.getNextMarker());
                                       }while(result.isTruncated());
3      附录链接
OBS JAVA SDK使用方法,官网参考链接:https://support.huaweicloud.cn/sdk-java-devg-obs/zh-cn_topic_0142815558.html
