Oracle EBS Concurrent Manager 始终无法启动的一个解决方法
fancanny 发表于 2019/01/18 09:45:03 2019/01/18
【摘要】 Concurrent Manager无法启动的解决 EBS 主页 > System Administration(或System Administrator) > Oracle Applications Manager > Concurrent Managers > Site Map > Diagnostics and Repair > Concurrent Manager Recovery
EBS V12.2.4 版本,Clone 的系统,其 Concurrent Manager 始终无法启动:
运行 /jit/jit13/fs1/inst/apps/JIT13_fxsljit04/admin/scripts/adcmctl.sh status apps/passwords
出现信息:You are running adcmctl.sh version 120.19.12020000.3
Internal Concurrent Manager is Not Active at this time.
adcmctl.sh: exiting with status 0
adcmctl.sh: check the logfile /jit/jit13/fs1/inst/apps/JIT13_fxsljit04/logs/appl/admin/log/adcmctl.txt for more information …
将 Profile: Concurrent:GSM Enabled 从 Y 改为 N, 也没有解决问题
在 $APPLCSF/$APPLLOG/JIT13_0228.mgr (/jit/jit13/fs_ne/inst/JIT13_fxsljit04/logs/appl/conc/log/SID_DATE.mgr)中出现如下错误信息:
sh: line 68: 18223 Segmentation fault
FNDLIBR FND CPMGR "FNDCPMBR sysmgr=\"\" sleep=30 pmon=4 quesiz=1 diag=N logfile=/jit/jit13/fs_ne/inst/JIT13_fxsljit04/logs/appl/conc/log/JIT13_0227.mgr "
<<STOP $unpw STOP
The JIT13_0227@JIT13 internal concurrent manager has terminated with status 139 - giving up.
此问题查阅了大量资料,花了很长时间才解决;
详细信息可见:https://community.oracle.com/message/12922099#12922099
Concurrent Processing - Concurrent Manager Recovery Troubleshooting Wizard (Doc ID 134007.1)
问题解决后,偶然发现通过 google 搜索 internal concurrent manager is not active at this time (google 直接跳出这个问题)
这么好的 google 却被封了,一声叹息。
解决方法:
EBS 主页 -> System Administration(或者System Administrator) -> Oracle Applications Manager > Concurrent Managers
