华为云微服务CSEJavaSDK问题一:契约在SC中无法获取
BitM 发表于 2019/03/17 01:05:10 2019/03/17
【摘要】 Idea启动provider后服务契约SC无法获取,Eclipse中启动正常Provider Log:2019-03-16 23:00:57,413 [ERROR] Can not output merged.log4j.properties,because can not write to directory of file file:/Users/zhenbing/.m2/reposit...
Provider Log:
2019-03-16 23:00:57,413 [ERROR] Can not output merged.log4j.properties,because can not write to directory of file file:/Users/zhenbing/.m2/repository/org/apache/servicecomb/transport-rest-vertx/1.1.0.B036/transport-rest-vertx-1.1.0.B036.jar!/config/base/log4j.properties org.apache.servicecomb.foundation.common.utils.Log4jUtils.outputFile(Log4jUtils.java:103)
2019-03-16 23:00:57,427 [INFO] Found main class "com.intellij.rt.execution.application.AppMain". org.apache.servicecomb.foundation.common.utils.JvmUtils.findMainClass(JvmUtils.java:62)
2019-03-16 23:00:57,490 [INFO] Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@97e1986: startup date [Sat Mar 16 23:00:57 CST 2019]; root of context hierarchy org.springframework.context.support.AbstractApplicationContext.prepareRefresh(AbstractApplicationContext.java:583)
2019-03-16 23:00:57,596 [INFO] Loading XML bean definitions from URL [jar:file:/Users/zhenbing/.m2/repository/org/apache/servicecomb/foundation-config/1.1.0.B036/foundation-config-1.1.0.B036.jar!/META-INF/spring/cse.bean.xml] org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:317)
2019-03-16 23:00:57,892 [INFO] Loading XML bean definitions from URL [jar:file:/Users/zhenbing/.m2/repository/org/apache/servicecomb/foundation-vertx/1.1.0.B036/foundation-vertx-1.1.0.B036.jar!/META-INF/spring/cse.bean.xml] org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:317)
2019-03-16 23:00:57,921 [INFO] Loading XML bean definitions from URL [jar:file:/Users/zhenbing/.m2/repository/org/apache/servicecomb/java-chassis-core/1.1.0.B036/java-chassis-core-1.1.0.B036.jar!/META-INF/spring/cse.bean.xml] org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:317)
2019-03-16 23:00:58,863 [INFO] Loading XML bean definitions from URL [jar:file:/Users/zhenbing/.m2/repository/org/apache/servicecomb/handler-bizkeeper/1.1.0.B036/handler-bizkeeper-1.1.0.B036.jar!/META-INF/spring/cse.bean.xml] org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:317)
2019-03-16 23:00:58,883 [INFO] Loading XML bean definitions from URL [jar:file:/Users/zhenbing/.m2/repository/org/apache/servicecomb/handler-loadbalance/1.1.0.B036/handler-loadbalance-1.1.0.B036.jar!/META-INF/spring/cse.bean.xml] org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:317)
2019-03-16 23:00:58,904 [INFO] Loading XML bean definitions from URL [jar:file:/Users/zhenbing/.m2/repository/com/huawei/paas/cse/cse-handler-cloud-extension/2.3.62/cse-handler-cloud-extension-2.3.62.jar!/META-INF/spring/services.bean.xml] org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:317)
2019-03-16 23:00:59,296 [INFO] Environment received, will get configurations from [org.springframework.core.env.StandardEnvironment@1532554556]. org.apache.servicecomb.config.ConfigurationSpringInitializer.setEnvironment(ConfigurationSpringInitializer.java:59)
2019-03-16 23:00:59,336 [WARN] No URLs will be polled as dynamic configuration sources. com.netflix.config.sources.URLConfigurationSource.<init>(URLConfigurationSource.java:121)
2019-03-16 23:00:59,336 [INFO] To enable URLs as dynamic configuration sources, define System property archaius.configurationSource.additionalUrls or make config.properties available on classpath. com.netflix.config.sources.URLConfigurationSource.<init>(URLConfigurationSource.java:122)
2019-03-16 23:00:59,419 [INFO] create local config: org.apache.servicecomb.config.ConfigUtil.createLocalConfig(ConfigUtil.java:114)
2019-03-16 23:00:59,419 [INFO]  jar:file:/Users/zhenbing/.m2/repository/org/apache/servicecomb/java-chassis-core/1.1.0.B036/java-chassis-core-1.1.0.B036.jar!/microservice.yaml. org.apache.servicecomb.config.ConfigUtil.createLocalConfig(ConfigUtil.java:116)
2019-03-16 23:00:59,419 [INFO]  jar:file:/Users/zhenbing/.m2/repository/com/huawei/paas/cse/cse-solution-service-engine/2.3.62/cse-solution-service-engine-2.3.62.jar!/microservice.yaml. org.apache.servicecomb.config.ConfigUtil.createLocalConfig(ConfigUtil.java:116)
2019-03-16 23:00:59,420 [INFO]  file:/Users/zhenbing/IdeaProjects/MicroService/Demo-Day4-Homework/helloworld-consumer/target/classes/microservice.yaml. org.apache.servicecomb.config.ConfigUtil.createLocalConfig(ConfigUtil.java:116)
2019-03-16 23:00:59,458 [INFO] Found SPI service org.apache.servicecomb.config.spi.ConfigCenterConfigurationSource, count=1. org.apache.servicecomb.foundation.common.utils.SPIServiceUtils.loadSortedService(SPIServiceUtils.java:79)
2019-03-16 23:00:59,458 [INFO]   0. org.apache.servicecomb.config.archaius.sources.ConfigCenterConfigurationSourceImpl. org.apache.servicecomb.foundation.common.utils.SPIServiceUtils.loadSortedService(SPIServiceUtils.java:82)
2019-03-16 23:00:59,467 [INFO] create local config: org.apache.servicecomb.config.ConfigUtil.createLocalConfig(ConfigUtil.java:114)
2019-03-16 23:00:59,467 [INFO]  jar:file:/Users/zhenbing/.m2/repository/org/apache/servicecomb/java-chassis-core/1.1.0.B036/java-chassis-core-1.1.0.B036.jar!/microservice.yaml. org.apache.servicecomb.config.ConfigUtil.createLocalConfig(ConfigUtil.java:116)
2019-03-16 23:00:59,468 [INFO]  jar:file:/Users/zhenbing/.m2/repository/com/huawei/paas/cse/cse-solution-service-engine/2.3.62/cse-solution-service-engine-2.3.62.jar!/microservice.yaml. org.apache.servicecomb.config.ConfigUtil.createLocalConfig(ConfigUtil.java:116)
2019-03-16 23:00:59,468 [INFO]  file:/Users/zhenbing/IdeaProjects/MicroService/Demo-Day4-Homework/helloworld-consumer/target/classes/microservice.yaml. org.apache.servicecomb.config.ConfigUtil.createLocalConfig(ConfigUtil.java:116)
2019-03-16 23:00:59,476 [INFO] Found SPI service org.apache.servicecomb.deployment.DeploymentProvider, count=1. org.apache.servicecomb.foundation.common.utils.SPIServiceUtils.loadSortedService(SPIServiceUtils.java:79)
2019-03-16 23:00:59,476 [INFO]   0. org.apache.servicecomb.deployment.DefaultDeploymentProvider. org.apache.servicecomb.foundation.common.utils.SPIServiceUtils.loadSortedService(SPIServiceUtils.java:82)
缺少了产生swagger的步骤(下面是Eclipse输出的Log信息):
2019-03-16 23:14:36,313 [INFO] Service startup completed! microservice.demo.training21days.provider.bootevent.CustomBootEventListener.onBootEvent(CustomBootEventListener.java:18)
2019-03-16 23:14:36,313 [INFO] ============================= microservice.demo.training21days.provider.bootevent.CustomBootEventListener.onBootEvent(CustomBootEventListener.java:19)
2019-03-16 23:14:36,319 [WARN] keyStore [server.p12] file not exist, please check! org.apache.servicecomb.foundation.vertx.VertxTLSBuilder.buildTCPSSLOptions(VertxTLSBuilder.java:118)
2019-03-16 23:14:36,320 [WARN] trustStore [trust.jks] file not exist, please check! org.apache.servicecomb.foundation.vertx.VertxTLSBuilder.buildTCPSSLOptions(VertxTLSBuilder.java:138)
2019-03-16 23:14:36,324 [INFO] Monitor data sender started. Configured data providers is {com.huawei.paas.monitor.HealthMonitorDataProvider,} com.huawei.paas.monitor.DataFactory.start(DataFactory.java:62)
2019-03-16 23:14:36,325 [INFO] ServiceComb is ready. org.apache.servicecomb.core.SCBEngine$1.afterRegistryInstance(SCBEngine.java:188)
2019-03-16 23:14:36,342 [INFO] Waiting for status up. timeout: 10000ms org.apache.servicecomb.core.SCBEngine.waitStatusUp(SCBEngine.java:362)
2019-03-16 23:14:36,343 [INFO] Status already changed to up. org.apache.servicecomb.core.SCBEngine.waitStatusUp(SCBEngine.java:371)
2019-03-16 23:15:06,343 [INFO] sc task interval changed from -1 to 30 org.apache.servicecomb.serviceregistry.task.ServiceCenterTaskMonitor.beginCycle(ServiceCenterTaskMonitor.java:39)
