Fortify自定义规则编写教程笔记(四):数据流规则
开发者学堂小助 发表于 2017/12/22 10:05:37 2017/12/22
【摘要】 Fortify自定义规则编写教程笔记之数据流规则。
一、规则类型:
DataflowEntrypointRule
DataflowSourceRule
DataflowPassthroughRule
DataflowSinkRule
DataflowCleanseRule
二、规则中的通用属性:
formatVersion
language
RuleID
VulKingdom
VulnCategory
VulnSubcategory
DefaultSeverity(1.0-5.0)
Description:Abstract...
三、函数的匹配与识别:FunctionIdentifier
(1)函数的维度:NamespaceName,ClassName,FunctionName
(2)正则识别:Pattern
(3)精确识别:Value
四、具体规则:
(1)Dataflow sink Rule:
InArguments,Conditional
(2)Dataflow Passthrough Rule:
InArguments,OutArguments,+/-(add/removetaint flags)
(3)Dataflow Entrypoint Rule:
InArguments,Modifiers(e.g:static)
(4)Dataflow Cleanse Rule:
OutArguments,Parameters
(5)Dataflow Source Rule:
ApplyTo: extends,overrides,implements
TaintFlags
OutArguments:this,return,参数索引
五、Conditionals
逻辑运算:And,Or,Not
常量相关:IsConstant,ConstantEq,ConstantGt,ConstantLt
标记:TaintFlagSet
类相关:Type
六、Taint Flags
类型:General(默认行为),Neutral(主要用于VALIDATED_xxx),Specific(自定义taint flags,且不让其他sink报错)
声明:TaintFlagDeclarations
七、总结:
Entrypoint/Source->Passthrough->Sink: Report
Entrypoint/Source->Passthrough->Cleanse: Do not report
八、附加参考:
(1)Decription中的替代键:
(2)Fortify认可的验证库或方法(类似于Cleanse)
a).Validator for XSS issue
Encoder/Encoding/Escapefrom several supported library are recognized by fortify, however, issue willstill get reported, with lower rating: LOW.
Sample: xss: poor validation
b).Validator for Path Manipulation
org.owasp.esapi.getValidDirectoryPathor org.owasp.esapi.getValidFilename
c).Validator for SQL Injection (encoder/escaper) ,eg:
org.owasp.esapi.Encoder.encodeForSQL
org.apache.commons.lang.StringEscapeUtils.escapeSql
d).Validator for Command Injection
org.owasp.esapi.Encoder.encodeForOS
作者:陈辉军
