SpringBoot系列:SpringBoot第六篇:springboot整合mybatis
云享专家 发表于 2019/09/05 18:18:48 2019/09/05
【摘要】 本文主要讲解如何在springboot下整合mybatis,并访问数据库。由于mybatis这个框架太过于流行,所以我就不讲解了。
引入依赖
在pom文件引入mybatis-spring-boot-starter的依赖:
       <dependency>
            <groupId>org.mybatis.spring.boot</groupId>
            <artifactId>mybatis-spring-boot-starter<artifactId>
            <version>1.3.0</version>
        </dependency>
引入数据库连接依赖:
<dependency>
            <groupId>mysql</groupId>
            <artifactId>mysql-connector-java</artifactId>
            <scope>runtime</scope>
        </dependency>
        <dependency>
            <groupId>com.alibaba</groupId>
            <artifactId>druid</artifactId>
            <version>1.0.29</version>
        </dependency>
引入数据源
application.properties配置文件中引入数据源:
spring.datasource.url=jdbc:mysql://localhost:3306/test
spring.datasource.username=root
spring.datasource.password=123456
spring.datasource.driver-class-name=com.mysql.jdbc.Driver
这样,springboot就可以访问数据了。
创建数据库表
建表语句:
-- create table `account`
# DROP TABLE `account` IF EXISTS
CREATE TABLE `account` (
  `id` int(11) NOT NULL AUTO_INCREMENT,
  `name` varchar(20) NOT NULL,
  `money` double DEFAULT NULL,
  PRIMARY KEY (`id`)
) ENGINE=InnoDB AUTO_INCREMENT=4 DEFAULT CHARSET=utf8;
INSERT INTO `account` VALUES ('1', 'aaa', '1000');
INSERT INTO `account` VALUES ('2', 'bbb', '1000');
INSERT INTO `account` VALUES ('3', 'ccc', '1000');
具体实现
这篇文篇通过注解的形式实现。
创建实体:
 public class Account {
    private int id ;
    private String name ;
    private double money;
  setter...
  getter...
dao层
@Mapper
public interface AccountMapper {
    @Insert("insert into account(name, money) values(#{name}, #{money})")
    int add(@Param("name") String name, @Param("money") double money);
    @Update("update account set name = #{name}, money = #{money} where id = #{id}")
    int update(@Param("name") String name, @Param("money") double money, @Param("id") int  id);
    @Delete("delete from account where id = #{id}")
    int delete(int id);
    @Select("select id, name as name, money as money from account where id = #{id}")
    Account findAccount(@Param("id") int id);
    @Select("select id, name as name, money as money from account")
    List<Account> findAccountList();
service层
@Service
public class AccountService {
    @Autowired
    private AccountMapper accountMapper;
    public int add(String name, double money) {
        return accountMapper.add(name, money);
    public int update(String name, double money, int id) {
        return accountMapper.update(name, money, id);
    public int delete(int id) {
        return accountMapper.delete(id);
    public Account findAccount(int id) {
        return accountMapper.findAccount(id);
    public List<Account> findAccountList() {
        return accountMapper.findAccountList();
controller层,构建restful API
package com.forezp.web;
import com.forezp.entity.Account;
import com.forezp.service.AccountService;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.web.bind.annotation.*;
import java.util.List;
 * Created by fangzhipeng on 2017/4/20.
@RestController
@RequestMapping("/account")
public class AccountController {
    @Autowired
    AccountService accountService;
    @RequestMapping(value = "/list", method = RequestMethod.GET)
    public List<Account> getAccounts() {
        return accountService.findAccountList();
    @RequestMapping(value = "/{id}", method = RequestMethod.GET)
    public Account getAccountById(@PathVariable("id") int id) {
        return accountService.findAccount(id);
    @RequestMapping(value = "/{id}", method = RequestMethod.PUT)
    public String updateAccount(@PathVariable("id") int id, @RequestParam(value = "name", required = true) String name,
                                @RequestParam(value = "money", required = true) double money) {
        int t= accountService.update(name,money,id);
        if(t==1) {
            return "success";
        }else {
            return "fail";
    @RequestMapping(value = "/{id}", method = RequestMethod.DELETE)
    public String delete(@PathVariable(value = "id")int id) {
        int t= accountService.delete(id);
        if(t==1) {
            return "success";
        }else {
            return "fail";
    @RequestMapping(value = "", method = RequestMethod.POST)
    public String postAccount(@RequestParam(value = "name") String name,
                              @RequestParam(value = "money") double money) {
       int t= accountService.add(name,money);
       if(t==1) {
           return "success";
       }else {
           return "fail";
通过postman测试通过。
源码下载:https://github.com/forezp/SpringBootLearning
原创作者:方志朋
方志朋简介:SpringCloud中国社区联合创始人,博客访问量突破一千万,爱好开源,热爱分享,活跃于各大社区,保持着非常强的学习驱动力,终身学习践行者,终身学习受益者。目前就职于国内某家知名互联网保险公司,担任DEVOPS工程师,对微服务领域和持续集成领域研究较深,精通微服务框架SpringCloud
