SpringBoot系列:SpringBoot第十九篇: 验证表单信息
云享专家 发表于 2019/09/06 17:55:41 2019/09/06
【摘要】 这个实体类,在2个属性:name,age.它们各自有验证的注解: · @Size(min=2, max=30) name的长度为2-30个字符 · @NotNull 不为空 · @Min(18)age不能小于18
这篇文篇主要简述如何在springboot中验证表单信息。在springmvc工程中,需要检查表单信息,表单信息验证主要通过注解的形式。
构建工程
创建一个springboot工程,由于用到了web 、thymeleaf、validator、el,引入相应的起步依赖和依赖,代码清单如下:
<dependencies>
        <dependency>
            <artifactId>spring-boot-starter-web</artifactId>
        </dependency>
        <dependency>
            <artifactId>spring-boot-starter-test</artifactId>
            <scope>test</scope>
        </dependency>
        <dependency>
            <artifactId>spring-boot-starter-thymeleaf</artifactId>
        </dependency>
        <dependency>
            <groupId>org.hibernate</groupId>
            <artifactId>hibernate-validator</artifactId>
        </dependency>
        <dependency>
            <groupId>org.apache.tomcat.embed</groupId>
            <artifactId>tomcat-embed-el</artifactId>
        </dependency>
    </dependencies>
创建一个PresonForm的Object类
package com.forezp.entity;
import javax.validation.constraints.Min;
import javax.validation.constraints.NotNull;
import javax.validation.constraints.Size;
 * Created by fangzhipeng on 2017/4/19.
public class PersonForm {
    @NotNull
    private String name;
    @NotNull
    @Min(18)
    private Integer age;
    public String getName() {
        return this.name;
    public void setName(String name) {
        this.name = name;
    public Integer getAge() {
        return age;
    public void setAge(Integer age) {
        this.age = age;
    public String toString() {
        return "Person(Name: " + this.name + ", Age: " + this.age + ")";
·      @NotNull 不为空
·      @Min(18)age不能小于18
创建web Controller
@Controller
public class WebController extends WebMvcConfigurerAdapter {
    @Override
    public void addViewControllers(ViewControllerRegistry registry) {
        registry.addViewController("/results").setViewName("results");
    @GetMapping("/")
    public String showForm(PersonForm personForm) {
        return "form";
    @PostMapping("/")
    public String checkPersonInfo(@Valid PersonForm personForm, BindingResult bindingResult) {
        if (bindingResult.hasErrors()) {
            return "form";
        return "redirect:/results";
创建form表单
src/main/resources/templates/form.html:
<html>
    <body>
        <form action="#" th:action="@{/}" th:object="${personForm}" method="post">
            <table>
                <tr>
                    <td>Name:</td>
                    <td><input type="text" th:field="*{name}" /></td>
                    <td th:if="${#fields.hasErrors('name')}" th:errors="*{name}">Name Error</td>
                </tr>
                <tr>
                    <td>Age:</td>
                    <td><input type="text" th:field="*{age}" /></td>
                    <td th:if="${#fields.hasErrors('age')}" th:errors="*{age}">Age Error</td>
                </tr>
                <tr>
                    <td><button type="submit">Submit</button></td>
                </tr>
            </table>
        </form>
    </body>
</html>
注册成功的页面
src/main/resources/templates/results.html:
html>
    <body>
        Congratulations! You are old enough to sign up for this site.
    </body>
</html>
演示
启动工程,访问http://localhost:8080/:
如果你输入A和15,点击submit:
如果name 输入N, age为空:
如果输入:forezp. 18
参考资料
https://spring.io/guides/gs/validating-form-input/
源码下载
https://github.com/forezp/SpringBootLearning
原创作者:方志朋
方志朋简介:SpringCloud中国社区联合创始人,博客访问量突破一千万,爱好开源,热爱分享,活跃于各大社区,保持着非常强的学习驱动力,终身学习践行者,终身学习受益者。目前就职于国内某家知名互联网保险公司,担任DEVOPS工程师,对微服务领域和持续集成领域研究较深,精通微服务框架SpringCloud
