数据库源代码里隐式类型转换导致的性能问题
GaussDB数据库 发表于 2019/06/12 15:40:59 2019/06/12
【摘要】 今天在处理一个现网问题时,发现平台的一个SQL里一对单引号的缺失导致业务性能很差。 问题背景 客户现场电视墙每天凌晨11点50分左右会卡顿一会儿,通过搜集数据库的statspack以及业务侧的平台日志检查,发现以下SQL执行时间需要9-10秒: SELECT ACTLOGID,ALARMLOGID,ALARMCODE,ACTDATE,RECSTARTTIM...
问题背景
SELECT ACTLOGID,ALARMLOGID,ALARMCODE,ACTDATE,RECSTARTTIME,RECSTOPTIME FROM ALARM_ACT_LOG WHERE RESPID=001200003680101 AND RECSTOPTIME>20151113235012;
因为该表数据从未清理过(有500万+条数据),而且其中大部分数据都是过期数据,所以为了提高性能,每天凌晨2点对该表实施了清理动作,清理之后,每次执行还是需要3秒多。
处理过程
查看该SQL的执行计划:
SQL> SELECT ACTLOGID,ALARMLOGID,ALARMCODE,ACTDATE,RECSTARTTIME,RECSTOPTIME FROM ALARM_ACT_LOG WHERE RESPID=001200003680101 AND RECSTOPTIME>20151113235012;
29 rows selected.
Elapsed: 00:00:03.46
Execution Plan
Plan hash value: 4149311700
| Id  | Operation         | Name          | Rows  | Bytes | Cost (%CPU)| Time     |
|   0 | SELECT STATEMENT  |               |    23 |  1771 | 17678   (1)| 00:03:33 |
|*  1 |
TABLE ACCESS FULL| ALARM_ACT_LOG |    23 |  1771 | 17678   (1)| 00:03:33 |
Predicate Information (identified by operation id):
   1 - filter(TO_NUMBER("RESPID")=001200003680101 AND
              TO_NUMBER("RECSTOPTIME")>20151113235012)
Statistics
          0  recursive calls
          0  db block gets
65195  consistent gets
        735  physical reads
          0  redo size
       2900  bytes sent via SQL*Net to client
        531  bytes received via SQL*Net from client
          3  SQL*Net roundtrips to/from client
          0  sorts (memory)
          0  sorts (disk)
         29  rows processed
这个SQL走了全表扫描,而且物理读和逻辑读都较大。
查看该表的记录数以及在RESPID上的不同记录数:
SQL> select count(*) from alarm_act_log;
  COUNT(*)
    994176
SQL> select count(*) from (select distinct respid from alarm_act_log);
  COUNT(*)
       371
理论上讲,这个SQL的查询走respid这个字段上的索引的INDEX RANGE SCAN应该能减少物理读和逻辑读。于是,在alarm_act_log的respid上创建了索引:
SQL> create index nvs.ALARM_ACT_LOG_RESPID_IDX on nvs.alarm_act_log(respid);
Index created.
再次查看执行计划,还是走的全表扫描:
29 rows selected.
Execution Plan
|*  1 |
Statistics
          0  recursive calls
          0  db block gets
        735  physical reads
          0  redo size
          0  sorts (memory)
          0  sorts (disk)
         29  rows processed
检查表的定义:
SQL> desc alarm_act_log
 Name                                      Null?    Type
 ACTLOGID                                  NOT NULL NUMBER(20)
 ALARMLOGID                                         NUMBER(20)
 ALARMCODE                                          NUMBER(4)
 CTLCODE                                            NUMBER(5)
 RESPIDTYPE                                NOT NULL VARCHAR2(5)
RESPID                                             VARCHAR2(32)
 PARAM                                              VARCHAR2(128)
 ACTDATE                                            VARCHAR2(14)
 ACTENDDATE                                         VARCHAR2(14)
 RECSTARTTIME                                       VARCHAR2(14)
RECSTOPTIME                                        VARCHAR2(14)
 ALARMDAY                                           VARCHAR2(8)
RESPID和RECSTOPTIME都是VARCHAR2数据类型,但是在SQL里与这两个字段对应的值都是数值类型:RESPID=001200003680101 AND RECSTOPTIME>20151113235012
所以数据库要做一个隐式类型转换,也就是说它需要执行TO_NUMBER(RESPID)和TO_NUMBER(RECSTOPTIME)之后才会分别与001200003680101和20151113235012进行比较。如果创建基于TO_NUMBER的函数索引,它应该会走INDEX RANGE SCAN。
SQL> DROP INDEX NVS.ALARM_ACT_LOG_RESPID_IDX;
Index dropped.
SQL> create index nvs.ALARM_ACT_LOG_RESPID_IDX on nvs.alarm_act_log(to_number(respid));
Index created.
再次查看执行计划:
SQL>  SELECT ACTLOGID,ALARMLOGID,ALARMCODE,ACTDATE,RECSTARTTIME,RECSTOPTIME FROM ALARM_ACT_LOG WHERE RESPID=001200003680101 AND RECSTOPTIME>'20151113235012';
29 rows selected.
Elapsed: 00:00:00.01
Execution Plan
Plan hash value: 2486932655
|   0 | SELECT STATEMENT            |                          |   496 | 41168 |  2099   (0)| 00:00:26 |
|*  1 |  TABLE ACCESS BY INDEX ROWID| ALARM_ACT_LOG            |   496 | 41168 |  2099   (0)| 00:00:26 |
|*  2 |
INDEX RANGE SCAN          | ALARM_ACT_LOG_RESPID_IDX |  3975 |       |     9   (0)| 00:00:01 |
   1 - filter(TO_NUMBER("RECSTOPTIME")>20151113235012)
   2 - access(TO_NUMBER("RESPID")=001200003680101)
Statistics
         24  recursive calls
          0  db block gets
 620  consistent gets
          4  physical reads
          0  redo size
          0  sorts (memory)
          0  sorts (disk)
         29  rows processed
可以看到逻辑读和物理读都大幅减少,执行时间也从3秒多降为0.01秒。当然也可以在RESPID和RECSTOPTIME上建立复合函数索引: create index nvs.ALARM_ACT_LOG_RESPID_STOPTIME_IDX on nvs.alarm_act_log(to_number(respid),to_number(recstoptime));
因为是平台SQL,不能直接修改,只能创建函数索引规避这个问题。其实函数索引对于增删改频繁的表有一定的副作用,因为对于增删改的数据的索引维护都要做一个函数操作,好在这个表增删改并不频繁。最好的办法就是将SQL改为:SELECT ACTLOGID,ALARMLOGID,ALARMCODE,ACTDATE,RECSTARTTIME,RECSTOPTIME FROM ALARM_ACT_LOG WHERE RESPID='001200003680101' AND RECSTOPTIME>'20151113235012';然后在RESPID上建立索引或在RESPID和RECSTOPTIME上建立复合索引。
而实际上,这个表上有一个复合索引,这个索引上的一个字段就是RESPID。如果平台的这个SQL不做隐式类型转换,写成:SELECT ACTLOGID,ALARMLOGID,ALARMCODE,ACTDATE,RECSTARTTIME,RECSTOPTIME FROM ALARM_ACT_LOG WHERE RESPID='001200003680101' AND RECSTOPTIME>20151113235012;
那么它的执行计划还是可以做INDEX SKIP SCAN:
SQL> SELECT ACTLOGID,ALARMLOGID,ALARMCODE,ACTDATE,RECSTARTTIME,RECSTOPTIME FROM ALARM_ACT_LOG WHERE RESPID='001200003680101' AND RECSTOPTIME>'20151113235012';
29 rows selected.
Execution Plan
Plan hash value: 3344032797
|   0 | SELECT STATEMENT            |                   |    49 |  3773 |   621   (0)| 00:00:08 |
|*  1 |  TABLE ACCESS BY INDEX ROWID| ALARM_ACT_LOG     |    49 |  3773 |   621   (0)| 00:00:08 |
|*  2 |
INDEX SKIP SCAN           | ALARM_ACT_LOG_IDX |  1018 |       |    62   (0)| 00:00:01 |
   2 - access("RESPID"='001200003680101')
       filter("RESPID"='001200003680101')
Statistics
          1  recursive calls
          0  db block gets
   632  consistent gets
          0  physical reads
          0  redo size
       2888  bytes sent via SQL*Net to client
          0  sorts (memory)
          0  sorts (disk)
         29  rows processed
可以看到在INDEX SKIP SCAN时,SQL的性能也很好。那么这个因隐式数据类型转换引起的性能问题完全可以避免。
