微云实施时网络配置
gd1979 发表于 2019/01/24 18:04:19 2019/01/24
【摘要】 交换机配置cisco交换机配置示例configure terminalinterface Port-channel 1 创建一个以太网通道接口interface range gigabitEthernet 0/23 - 24 在所有物理口上做同样的配置switchport access vlan 1 ...
交换机配置
cisco交换机配置示例
configure terminal
switchport access vlan 1                       将接口设成默认的VLAN 1
switchport trunk encapsulation dot1q            设置封装类型为802.1Q
switchport mode trunk                        设置成802.1Q  trunk协议
channel-protocol lacp                         设置802.ad LACP端口聚合协议
channel-group 1 mode active                   设置模式为active
port-channel load-balance src-dst-mac           设置载均衡的模式
show etherchannel summary                   显示端口聚合状态
H3C交换机配置示例
system view                                 进入系统视图
interface bridge-aggregation 1                  进入二层聚合接口视图
link-aggregation mode dynamic                 配置成动态LACP聚合模式,部分使用不了
quit
interface ethernet 1/1                                 进入以太网1/1接口
port link-type trunk                           设置成trunk
port trunk permit vlan all                       允许所有VLAN在trunk上通过
port link aggregation group 1                   将二层以太网接口加入聚合组
interface ethernet 1/2
display link-aggregation summary                显示所有聚合组的摘要信息
华为交换机配置示例
System-view
interface eth-trunk 1
port trunk allow-pass vlan 2 to 4094
max active-linknumber 4
max bandwidth-affected-linknumber 4
bpdu enable
mode lacp-static
lacp priority 100
Lacp preempt delay 100
interface gigabitethernet 0/0/1
eth-trunk 1
undo ntdp enable
undo ndp enable
interface gigabitethernet 0/0/2
eth-trunk 1
undo ntdp enable
undo ndp enable
在配置端口前,一定要将端口原有配置清空,全部undo掉,否则无法应用eth-trunk命令。如果之前端口配置过trunk口,可以使用undo port link-type清除trunk状态
display eth-trunk 1                      显示端口聚合状态
 交换机聚合状态检查
思科交换机检查聚合状态
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 6
Number of aggregators:           6
Group  Port-channel  Protocol    Ports
1      Po1(SU)         LACP      Gi0/1(s)    Gi0/2(P)    Gi0/3(D)
                                 Gi0/4(D)
2      Po2(SU)         LACP      Gi0/5(P)    Gi0/6(P)    Gi0/7(D)
                                 Gi0/8(D)
3      Po3(SU)         LACP      Gi0/9(P)    Gi0/10(P)   Gi0/11(D)
                                 Gi0/12(D)
4      Po4(SU)         LACP      Gi0/13(P)   Gi0/14(P)   Gi0/15(D)
                                 Gi0/16(D)
5      Po5(SU)         LACP      Gi0/17(P)   Gi0/18(P)   Gi0/19(D)
                                 Gi0/20(D)
6      Po6(SU)         LACP      Gi0/21(P)   Gi0/22(P)
服务器上通过show命令检查服务器状态
show ?
?             display parameters
dcs           distributed coordination service information   显示分布式协调服务
dss           distribute storage service information         显示分布式存储服务
lss           local storage service information              显示本地存储
dbs           desktop backup service information             显示桌面备份服务
du            disk used for server                           显示本服务器本地硬盘使用
df            disk not mounted for server                    显示本服务器未挂载的硬盘
cache         disk cache information                         显示SSD固态盘Cache状况
lacp          display lacp status                            显示端口聚合状态
ip            display system ip settings                     显示服务器管理口mgt0 IP地址、网关及VLAN
link          ethernet interface link information            显示以太口链路状态
ver           show system version information                显示系统版本
tech          show system information for Tech-Support       显示技术支持信息
date          show current date and time                     显示系统时间
health        show server health                             显示服务器健康状况
