Android Weex 自定义 Component 具体实现(WEEX SDK 0.19.0)
wenhai 发表于 2019/01/29 10:27:13 2019/01/29
【摘要】 Android Weex 自定义 Component 具体实现(WEEX SDK 0.19.0)
class WeexSeekBar(instance: WXSDKInstance, parent: WXVContainer<*>  , basic: BasicComponentData<AppCompatSeekBar>) : WXComponent<AppCompatSeekBar>(instance, parent,basic), SeekBar.OnSeekBarChangeListener {
    companion object {
        private const val KEY_MAX = "max"
        private const val KEY_MIN = "min"
        private const val KEY_PROGRESS = "progress"
        private const val EVENT_ON_START_SLIDE = "startSlide"
        private const val EVENT_ON_SLIDE = "slide"
        private const val EVENT_ON_STOP_SLIDE = "stopSlide"
        private const val TYPE_BRIGHTNESS = "normal"
        private const val TYPE_COLOR = "horizontal_hux_color"
        private const val TYPE_SHADE = "horizontal_linear_gradient"
    //注册hostview  此方法必须重写
    override fun initComponentHostView(context: Context): AppCompatSeekBar {
        val tempView = AppCompatSeekBar(context).apply {
            val pxValue = dp2px(context, 16f).toInt();
            setPadding(pxValue, 0, pxValue, 0)
            thumb = ContextCompat.getDrawable(context, R.drawable.button_slide)
        tempView.setOnSeekBarChangeListener(this)
        return tempView
    override fun onProgressChanged(seekBar: SeekBar, progress: Int, fromUser: Boolean) {
           //key值为vue中的响应标签如key 为slide  在vue中的标签为 @slide="funtionname"
          //当fireevent 发送数据时weex会转到你标签中的对应的方法
        fireEvent(EVENT_ON_SLIDE, seekBar.getSeekBarInfo())
    override fun onStartTrackingTouch(seekBar: SeekBar) {
        fireEvent(EVENT_ON_START_SLIDE, seekBar.getSeekBarInfo())
    override fun onStopTrackingTouch(seekBar: SeekBar) {
//        Log.e("seekbar",GsonHelp.gson().toJson(seekBar.getSeekBarInfo()))
        fireEvent(EVENT_ON_STOP_SLIDE, seekBar.getSeekBarInfo())
    @WXComponentProp(name = "max")
    fun max(maximum:Int){
        hostView?.max = maximum
    //注册vue中的props 属性 name 为vue中使用的标签
    @WXComponentProp(name = "progress")
    fun progress(progress:Int){
        Log.e("wx",progress.toString())
        hostView?.progress = progress
    override fun bindData(component: WXComponent<*>?) {
        super.bindData(component)
  // 此标注标识注册为weex端代码使用  调用方法在下方给出 下面同理
    @JSMethod
    fun setProgress(progress:Int){
    @JSMethod
    fun setMax(max:Int){
        hostView?.max = max
    @WXComponentProp(name = "type")
    fun setType(type:String){
        when(type){
            TYPE_BRIGHTNESS -> {
//                hostView.progressDrawable=context.resources.getDrawable(R.drawable.seekbar_bg)
            TYPE_COLOR -> {
                hostView.progressDrawable = PaintDrawable().apply {
                    shape = RectShape()
                    setCornerRadius(10f)
                    shaderFactory = object : ShapeDrawable.ShaderFactory(){
                        override fun resize(width: Int, height: Int): Shader
                                = LinearGradient(0f,0f,width.toFloat(),height.toFloat(),
                                ColorPickGradient.PICKCOLORBAR_COLORS,ColorPickGradient.PICKCOLORBAR_POSITIONS,
                                Shader.TileMode.REPEAT)
            TYPE_SHADE -> {
                hostView.progressDrawable = ContextCompat.getDrawable(context, R.drawable.seek_bar_bg1)
    @JSMethod
    fun setProgressDrawable(hue:Int){
        //设置的颜色
        val hueVal = (hue.toFloat() / 100f * 360f)
        val PICKCOLORBAR_COLORS = intArrayOf(Color.HSVToColor(floatArrayOf(hueVal, 0f, 1f)),
                Color.HSVToColor(floatArrayOf(hueVal, 1f, 1f)))
        val shaderFactory = object : ShapeDrawable.ShaderFactory() {
            override fun resize(width: Int, height: Int): Shader {
                return LinearGradient(0f, 0f, width.toFloat(), height.toFloat(), PICKCOLORBAR_COLORS, floatArrayOf(0f, 1f), Shader.TileMode.REPEAT)
        val paint = PaintDrawable()
        paint.shape = RectShape()
        paint.setCornerRadius(10f)
        paint.shaderFactory = shaderFactory
        hostView?.progressDrawable = paint
    fun SeekBar.getSeekBarInfo():HashMap<String, Any>{
        return HashMap<String, Any>().apply {
            put(KEY_MAX, this@getSeekBarInfo.max)
            put(KEY_PROGRESS, this@getSeekBarInfo.progress)
            put(KEY_MIN, if (Build.VERSION.SDK_INT >= Build.VERSION_CODES.O){
                this@getSeekBarInfo.min
            }else{
                0
    fun <T : Any> HashMap<String,T>.getValue(key:String, defaultValue:T):T
            = this.get(key) ?: defaultValue
    private fun dp2px(context: Context, size:Float):Float{
        return TypedValue.applyDimension(TypedValue.COMPLEX_UNIT_DIP, size, context.getResources().getDisplayMetrics())
    class ColorPickGradient {
        companion object {
            //设置的颜色
            val PICKCOLORBAR_COLORS = intArrayOf(0xFFff0000.toInt(), 0xFFffff00.toInt(), 0xFF00ff00.toInt(),
                    0xFF00ffff.toInt(), 0xFF0000ff.toInt(),
                    0xFFff00ff.toInt(), 0xFFff0000.toInt())
            //每个颜色的位置
            val PICKCOLORBAR_POSITIONS = floatArrayOf(0f, 0.16f, 0.33f, 0.51f, 0.67f, 0.85f, 1f)
        private var mColorArr = PICKCOLORBAR_COLORS
        private var mColorPosition = PICKCOLORBAR_POSITIONS
        constructor()
        constructor(colorArr : IntArray){
            this.mColorArr = colorArr
         * 获取某个百分比位置的颜色
         * @param radio 取值[0,1]
         * @return
        fun getColor(radio:Float):Int{
            var startColor = 0
            var endColor = 0
            if (radio >= 1) {
                return mColorArr[mColorArr.size - 1]
            for(i in 0 until mColorPosition.size){
                if (radio <= mColorPosition[i]) {
                    if (i == 0) {
                        return mColorArr[0]
                    startColor = mColorArr[i - 1]
                    endColor = mColorArr[i]
                    val areaRadio : Float = getAreaRadio(radio, mColorPosition[i - 1], mColorPosition[i])
                    return getColorFrom(startColor, endColor, areaRadio)
            return -1;
    fun getAreaRadio(radio : Float ,startPosition : Float , endPosition:Float ):Float{
        return (radio - startPosition) / (endPosition - startPosition)
     * 取两个颜色间的渐变区间 中的某一点的颜色
     * @param startColor
     * @param endColor
     * @param radio
     * @return
    fun getColorFrom( startColor : Int,  endColor : Int,  radio : Float) : Int {
        val redStart = Color.red(startColor);
        val blueStart = Color.blue(startColor);
        val greenStart = Color.green(startColor);
        val redEnd = Color.red(endColor);
        val blueEnd = Color.blue(endColor);
        val greenEnd = Color.green(endColor);
        val red =  (redStart + ((redEnd - redStart) * radio + 0.5)).toInt()
        val greed =  (greenStart + ((greenEnd - greenStart) * radio + 0.5)).toInt()
        val blue =  (blueStart + ((blueEnd - blueStart) * radio + 0.5)).toInt()
        return Color.argb(255, red, greed, blue)
