IPsecVPN CE端配置
Elopin@腾飞 发表于 2019/01/05 08:10:20 2019/01/05
【摘要】 CE设备Hostname Hostname CE设备loopback100地址 Loopback 100 ip add Tunnel 号 Tunnel number Tunnel ip 地址 Tunnel ip address Tunnel 源地址 Tunnel source Tunnel 目的地址 Tunnel destination ADSL WAN接口 ADSL-Inter...
hostname
vpdn enable
vpdn-group ADSL
request-dialin
protocol pppoe
crypto keyring
pre-shared-key address  key
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp identity hostname
crypto isakmp profile IPSECPRO
keyring
match identity address  255.255.255.255
initiate mode aggressive
crypto ipsec transform-set IPSECTRAN esp-3des esp-sha-hmac
crypto map IPSECMAP 10 ipsec-isakmp
set peer
set transform-set IPSECTRAN
set isakmp-profile IPSECPRO
match address IPSEC
interface Loopback100
ip address  255.255.255.255
interface Tunnel
ip address  255.255.255.252
ip tcp adjust-mss 1432
tunnel source Loopback100
tunnel destination
interface
no shutdown
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip virtual-reassembly
encapsulation ppp
dialer pool 1
ppp authentication pap callin
ppp pap sent-username  password 0
crypto map IPSECMAP
ip route  255.255.255.255 Dialer1
ip access-list extended IPSEC
permit ip host  host
router bgp
neighbor  remote-as
address-family ipv4
neighbor  activate
neighbor  route-map ipsec-bgp-in in
neighbor  route-map ipsec-bgp-out out
ip access-list extended ipsec-bgp-in
permit ip any any
ip access-list extended ipsec-bgp-out
permit ip any any
route-map ipsec-bgp-in permit 10
set local-preference 30
route-map ipsec-bgp-out permit 10
set metric 120
评论(0
