【玩转Docker系列2】Docker安装
fengfeng 发表于 2017/03/08 00:01:13 2017/03/08
【摘要】 Docker当前支持不同类型不同版本的操作系统,其具体配套关系详见官方文档:https://docs.docker.com/engine/installation/。安装前确保已准备了满足Docker安装的一台操作系统。
Docker安装
操作系统准备
备注:本文所有示例都是基于Ubuntu 14.04,后面不再对操作系统版本进行重复说明。
UbuntuTest:~ # uname -ar
Linux UbuntuTest 3.19.0-25-generic   #26~14.04.1-Ubuntu SMP Fri Jul 24 21:16:20 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
网络配置
Ubuntu系统安装Docker以及Docker在使用过程中如从公共仓库下载镜像,都需要配置操作系统的外网权限,Ubuntu系统的具体配置如下(网络配置完成后需要重启生效):
UbuntuTest:~ # cat /etc/network/interfaces
# This file describes the network interfaces   available on your system
# and how to activate them. For more information,   see interfaces(5).
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
auto eth0
iface eth0 inet static
address 10.71.96.200
netmask 255.255.255.0
gateway 10.71.96.1
dns-nameservers 10.98.48.39
dns-search huawei.com
备注:如上配置最后两行为添加公司可用的域名服务器。
UbuntuTest:~ # ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536   qdisc noqueue state UNKNOWN group default
    link/loopback   00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP>   mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 00:50:56:84:a4:3c   brd ff:ff:ff:ff:ff:ff
    inet 10.71.96.200/24 brd   10.71.96.255 scope global eth0
       valid_lft forever   preferred_lft forever
    inet6   fe80::250:56ff:fe84:a43c/64 scope link
添加网络代理的环境变量,当前系统中结果如下:
UbuntuTest:~ # tail -n 2 /root/.bashrc
export http_proxy="http://username:password@proxy.huawei.cn:8080"
export https_proxy="http://username:password@proxy.huawei.cn:8080"
备注:username为域帐号,password为域帐号密码,密码不能带@”字符。
UbuntuTest:~ # source /root/.bashrc
UbuntuTest:~ # env |grep http
http_proxy=http://username:password @proxy.huawei.cn:8080
https_proxy=http://username:password @proxy.huawei.cn:8080
UbuntuTest:~ # curl www.google.com   >/dev/null
  % Total    % Received %   Xferd  Average Speed   Time      Time     Time  Current
                                   Dload  Upload   Total   Spent      Left  Speed
100  7237  100    7237    0     0    80829      0 --:--:-- --:--:-- --:--:-- 81314
UbuntuTest:~ # echo $?
0
Docker如需从官网拉镜像还需要进行如下配置(该配置文件在Docker安装后才有):
UbuntuTest:~ # cat /etc/default/docker
# If you need Docker to use an HTTP proxy, it can   also be specified here.
#export   http_proxy="http://127.0.0.1:3128/"
作者 | 胡国胜
转载请注明出处:华为云博客 https://portal.hwclouds.com/blogs
评论(0
