OBS JAVA SDK Demo:下载对象到本地文件系统
lanxinliuli 发表于 2019/07/18 17:34:09 2019/07/18
【摘要】 1 背景介绍OBS桶内的对象可以下载到本地文件系统,本文档将展示如何调用OBS SDK实现对象下载到本地的功能。2 代码展示需要先下载OBS最新的JAVA SDK,参考官网链接:https://developer.huaweicloud.cn/sdk?OBS,并在自己的项目中导入SDK中的JAR包。前提条件:已创建OBS桶,且桶内 已上传文件f1.txt代码示例:将f1...
1      背景介绍
2      代码展示
代码示例:将f1.txt下载到本地保存为downf1.txt
package samples_java;
import com.obs.services.ObsClient;
import com.obs.services.ObsConfiguration;
import com.obs.services.exception.ObsException;
import com.obs.services.model.DownloadFileRequest;
import com.obs.services.model.DownloadFileResult;
import java.io.FileInputStream;
import java.io.IOException;
import java.util.Properties;
public class DownloadObject {
private static final String endPoint = " XXX";
private static final String ak = "XXX";
private static final String sk = "XXX";
private static ObsClient obsClient;
private static DownloadFileRequest downloadFileRequest;
private static String bucketName = "obs-bucket001";
private static String objectName = "f1.txt";
private static String dstPath = "E://downf1.txt";
public static void main(String[] args)
throws IOException
        ObsConfiguration config =
new ObsConfiguration();
        config.setSocketTimeout(
30000);
        config.setConnectionTimeout(
10000);
        config.setEndPoint(
endPoint);
try
             * Constructs a obs client instance with your account for accessing OBS
obsClient = new ObsClient(ak, sk, config);
             * Download Object
downloadFileRequest = new DownloadFileRequest(bucketName,objectName,dstPath);
downloadFileRequest.setTaskNum(1);
downloadFileRequest.setPartSize(1024 * 1024 * 1024);
//            downloadFileRequest.setEnableCheckpoint(true);
long startTime = System.currentTimeMillis();
            DownloadFileResult downloadFileResult =
obsClient.downloadFile(downloadFileRequest);
long endtime = System.currentTimeMillis();
            System.
out.println(String.valueOf((endtime - startTime) / 1000.0D) + "s");
            System.
out.println(String.valueOf((downloadFileResult.getObjectMetadata().getContentLength() * 1000.0 / (endtime - startTime)) / (1024 * 1024)) + "MB/s");;
catch (ObsException e)
            System.
out.println("Response Code: " + e.getResponseCode());
            System.
out.println("Error Message: " + e.getErrorMessage());
            System.
out.println("Error Code:       " + e.getErrorCode());
            System.
out.println("Request ID:      " + e.getErrorRequestId());
            System.
out.println("Host ID:           " + e.getErrorHostId());
finally
if (obsClient != null)
try
                     * Close obs client
obsClient.close();
catch (IOException e)
3      效果展示
下载的文件保存在E://downf1.txt
对于大文件还可以打开断点续传,只需要打开Checkpoint
4      附录
OBS JAVA SDK使用,官网参考链接:https://support.huaweicloud.cn/sdkreference-obs/obs_02_0001.html
