dws作业三下载dota数据,并全部导入数据仓库分析.txt
tscswcn 发表于 2019/05/25 22:12:14 2019/05/25
【摘要】 CREATE schema dota;set current_schema='dota';drop FOREIGN table if exists region;CREATE FOREIGN TABLE REGION( like tpch.region) SERVER gsmpp_server OPTIONS ( encod...
 CREATE schema dota;
        like tpch.region
SERVER gsmpp_server
OPTIONS (
        encoding 'utf8',
        location 'obs://obs-dota/data/region.tbl',
        format 'text',
        delimiter '|',
        access_key 'L0GLVZYJ0ZCXDHHICH8D',
        secret_access_key 'x9ixihZl6ngQdZY7GSydSAPPj5CwQ8MQ9pnymCKx',
        chunksize '64',
        IGNORE_EXTRA_DATA 'on'
  CREATE schema dota;
drop FOREIGN table if exists ability_ids;
CREATE FOREIGN TABLE ability_ids
ability_id int,
ability_name VARCHAR2(100)
SERVER gsmpp_server
OPTIONS (
        encoding 'utf8',
        location 'obs://obs-dota/data/dota-2-matches/ability_ids1.csv',
        format 'text',
        delimiter ',',
        chunksize '64',
        header 'on'
create Sever obs_server FOREIGN DATA WRAPPER DFS_FDW options (ADDESSS '', access_key 'L0GLVZYJ0ZCXDHHICH8D',secret_access_key 'x9ixihZl6ngQdZY7GSydSAPPj5CwQ8MQ9pnymCKx',TYPE 'OBS')
drop FOREIGN table if exists ability_upgrades;
CREATE FOREIGN TABLE ability_upgrades
ability int,
level int,
time  int,
player_slot int,
match_id int
SERVER gsmpp_server
OPTIONS (
        encoding 'utf8',
        location 'obs://obs-dota/data/dota-2-matches/ability_upgrades.csv',
        format 'text',
        delimiter ',',
        chunksize '64',
        IGNORE_EXTRA_DATA 'on',
        header 'on'
drop FOREIGN table if exists chat;
CREATE FOREIGN TABLE chat
match_id int,
key varchar2(100),
slot int,
time int,
unit varchar(200)
SERVER gsmpp_server
OPTIONS (
        encoding 'utf8',
        location 'obs://obs-dota/data/dota-2-matches/chat.csv',
        format 'csv',
        delimiter ',',
        chunksize '64',
        header 'on'
drop FOREIGN table if exists cluster_regions;
CREATE FOREIGN TABLE cluster_regions
cluster int,
region varchar2(100)
SERVER gsmpp_server
OPTIONS (
        encoding 'utf8',
        location 'obs://obs-dota/data/dota-2-matches/cluster_regions.csv',
        format 'csv',
        delimiter ',',
        chunksize '64',
        header 'on'
drop FOREIGN table if exists hero_names;
CREATE FOREIGN TABLE hero_names
name varchar2(100),
hero_id int,
localized_name varchar2(200)
SERVER gsmpp_server
OPTIONS (
        encoding 'utf8',
        location 'obs://obs-dota/data/dota-2-matches/hero_names.csv',
        format 'csv',
        delimiter ',',
        chunksize '64',
        header 'on'
select * from hero_names;
drop FOREIGN table if exists item_ids;
CREATE FOREIGN TABLE item_ids
item_id int,
item_name varchar2(200)
SERVER gsmpp_server
OPTIONS (
        encoding 'utf8',
        location 'obs://obs-dota/data/dota-2-matches/item_ids.csv',
        format 'csv',
        delimiter ',',
        chunksize '64',
        header 'on'
select * from item_ids;
drop FOREIGN table if exists match;
CREATE FOREIGN TABLE match
match_id int,
start_time text,
duration int,
tower_status_radiant int,
tower_status_dire int,
barracks_status_dire int,
barracks_status_radiant int,
first_blood_time int,
game_mode int,
radiant_win boolean,
negative_votes int,
positive_votes int,
cluster int
SERVER gsmpp_server
OPTIONS (
        encoding 'utf8',
        location 'obs://obs-dota/data/dota-2-matches/match.csv',
        format 'csv',
        delimiter ',',
        chunksize '64',
        header 'on'
select * from match;
drop FOREIGN table if exists match_outcome;
CREATE FOREIGN TABLE match_outcome
match_id decimal,
account_id_0 float8,
account_id_1 float8,
account_id_2 float8,
account_id_3 float8,
account_id_4 float8,
start_time text,
parser_version int,
win int,
rad int
SERVER gsmpp_server
OPTIONS (
        encoding 'utf8',
        location 'obs://obs-dota/data/dota-2-matches/match_outcome.csv',
        format 'csv',
        delimiter ',',
        chunksize '64',
        header 'on'
select * from match_outcome;
/*********** 没数据
drop FOREIGN table if exists objectives;
CREATE FOREIGN TABLE objectives
match_id int,
key int,
player1 int,
player2 int,
slot text,
subtype varchar2(100),
team int,
time float,
value int
SERVER gsmpp_server
OPTIONS (
        encoding 'utf8',
        location 'obs://obs-dota/data/dota-2-matches/objectives.csv',
        format 'csv',
        delimiter ',',
        chunksize '64',
        header 'on'
select * from objectives;
可能分割符号问题
drop FOREIGN table if exists patch_dates;
CREATE FOREIGN TABLE patch_dates
patch_date timestamp,
name varchar2(100)
SERVER gsmpp_server
OPTIONS (
        encoding 'utf8',
        location 'obs://obs-dota/data/dota-2-matches/patch_dates.csv',
        format 'csv',
        delimiter ',',
        chunksize '64',
        header 'on'
select * from patch_dates;
drop FOREIGN table if exists player_ratings;
CREATE FOREIGN TABLE player_ratings
account_id float,
total_wins int,
total_matches int,
trueskill_mu float,
trueskill_sigma float
SERVER gsmpp_server
OPTIONS (
        encoding 'utf8',
        location 'obs://obs-dota/data/dota-2-matches/player_ratings.csv',
        format 'csv',
        delimiter ',',
        chunksize '64',
        header 'on'
select * from player_ratings;
drop FOREIGN table if exists player_time;
CREATE FOREIGN TABLE player_time
match_id int,
times int,
gold_t_0 int,
lh_t_0 int,
xp_t_0 int,
gold_t_1 int,
lh_t_1 int,
xp_t_1 int,
gold_t_2 int,
lh_t_2 int,
xp_t_2 int,
gold_t_3 int,
lh_t_3 int,
xp_t_3 int,
gold_t_4 int,
lh_t_4 int,
xp_t_4 int,
gold_t_128 int,
lh_t_128 int,
xp_t_128 int,
gold_t_129 int,
lh_t_129 int,
xp_t_129 int,
gold_t_130 int,
lh_t_130 int,
xp_t_130 int,
gold_t_131 int,
lh_t_131 int,
xp_t_131 int,
gold_t_132 int,
lh_t_132 int,
xp_t_132 int
SERVER gsmpp_server
OPTIONS (
        encoding 'utf8',
        location 'obs://obs-dota/data/dota-2-matches/player_time.csv',
        format 'csv',
        delimiter ',',
        chunksize '64',
        header 'on'
select * from player_time;
drop FOREIGN table if exists players;
CREATE FOREIGN TABLE players
match_id float,
account_id float,
hero_id float,
player_slot float,
gold float,
gold_spent float,
gold_per_min float,
xp_per_min float,
kills float,
deaths float,
assists float,
denies float,
last_hits float,
stuns text,
hero_damage float,
hero_healing float,
tower_damage float,
item_0 float,
item_1 float,
item_2 float,
item_3 float,
item_4 float,
item_5 float,
level float,
leaver_status float,
xp_hero text,
xp_creep float,
xp_roshan float,
xp_other float,
gold_other float,
gold_death float,
gold_buyback float,
gold_abandon float,
gold_sell float,
gold_destroying_structure float,
gold_killing_heros float,
gold_killing_creeps float,
gold_killing_roshan float,
gold_killing_couriers float,
unit_order_none float,
unit_order_move_to_position float,
unit_order_move_to_target float,
unit_order_attack_move float,
unit_order_attack_target float,
unit_order_cast_position float,
unit_order_cast_target float,
unit_order_cast_target_tree float,
unit_order_cast_no_target float,
unit_order_cast_toggle float,
unit_order_hold_position float,
unit_order_train_ability float,
unit_order_drop_item float,
unit_order_give_item float,
unit_order_pickup_item float,
unit_order_pickup_rune float,
unit_order_purchase_item float,
unit_order_sell_item float,
unit_order_disassemble_item float,
unit_order_move_item float,
unit_order_cast_toggle_auto float,
unit_order_stop float,
unit_order_taunt float,
unit_order_buyback float,
unit_order_glyph float,
unit_order_eject_item_from_stash float,
unit_order_cast_rune float,
unit_order_ping_ability float,
unit_order_move_to_direction float,
unit_order_patrol float,
unit_order_vector_target_position float,
unit_order_radar float,
unit_order_set_item_combine_lock float,
unit_order_continue float
SERVER gsmpp_server
OPTIONS (
        encoding 'utf8',
        location 'obs://obs-dota/data/dota-2-matches/players.csv',
        format 'csv',
        delimiter ',',
        chunksize '64',
        header 'on'
select * from players;
drop FOREIGN table if exists purchase_log;
CREATE FOREIGN TABLE purchase_log
item_id int,
time int,
player_slot int,
match_id int
SERVER gsmpp_server
OPTIONS (
        encoding 'utf8',
        location 'obs://obs-dota/data/dota-2-matches/purchase_log.csv',
        format 'csv',
        delimiter ',',
        chunksize '64',
        header 'on'
select * from purchase_log;
drop FOREIGN table if exists teamfights;
CREATE FOREIGN TABLE teamfights
match_id int ,
start int ,
eend int,
last_death int,
deaths int
SERVER gsmpp_server
OPTIONS (
        encoding 'utf8',
        location 'obs://obs-dota/data/dota-2-matches/teamfights.csv',
        format 'csv',
        delimiter ',',
        chunksize '64',
        header 'on'
select * from teamfights;
drop FOREIGN table if exists teamfights_players;
CREATE FOREIGN TABLE teamfights_players
match_id int
player_slot int,
buybacks int,
damage int,
deaths int,
gold_delta int,
xp_end int,
xp_start int
SERVER gsmpp_server
OPTIONS (
        encoding 'utf8',
        location 'obs://obs-dota/data/dota-2-matches/teamfights_players.csv',
        format 'csv',
        delimiter ',',
        chunksize '64',
        header 'on'
select * from teamfights_players;
drop FOREIGN table if exists test_labels;
CREATE FOREIGN TABLE test_labels
match_id int,
radiant_win int
SERVER gsmpp_server
OPTIONS (
        encoding 'utf8',
        location 'obs://obs-dota/data/dota-2-matches/test_labels.csv',
        format 'csv',
        delimiter ',',
        chunksize '64',
        header 'on'
select * from test_labels;
drop FOREIGN table if exists test_player;
CREATE FOREIGN TABLE test_player
match_id int,
account_id int,
hero_id int,
player_slot int
SERVER gsmpp_server
OPTIONS (
        encoding 'utf8',
        location 'obs://obs-dota/data/dota-2-matches/test_player.csv',
        format 'csv',
        delimiter ',',
        chunksize '64',
        header 'on'
select * from test_player;
