ElasticSearch异常归纳
北京小马哥 发表于 2018/12/30 16:22:41 2018/12/30
【摘要】 ElasticSearch在日常使用中的一些异常总结
  • 异常1: can not run elasticsearch as root
[WARN ][o.e.b.ElasticsearchUncaughtExceptionHandler] [node-2] uncaught exception in thread [main]
org.elasticsearch.bootstrap.StartupException: java.lang.RuntimeException: can not run elasticsearch as rootat org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:125) ~[elasticsearch-5.1.2.jar:5.1.2]
at org.elasticsearch.bootstrap.Elasticsearch.execute(Elasticsearch.java:112) ~[elasticsearch-5.1.2.jar:5.1.2]
at org.elasticsearch.cli.SettingCommand.execute(SettingCommand.java:54) ~[elasticsearch-5.1.2.jar:5.1.2]
at org.elasticsearch.cli.Command.mainWithoutErrorHandling(Command.java:122) ~[elasticsearch-5.1.2.jar:5.1.2]
at org.elasticsearch.cli.Command.main(Command.java:88) ~[elasticsearch-5.1.2.jar:5.1.2]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:89) ~[elasticsearch-5.1.2.jar:5.1.2]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:82) ~[elasticsearch-5.1.2.jar:5.1.2]
Caused by: java.lang.RuntimeException: can not run elasticsearch as root
at org.elasticsearch.bootstrap.Bootstrap.initializeNatives(Bootstrap.java:100) ~[elasticsearch-5.1.2.jar:5.1.2]
at org.elasticsearch.bootstrap.Bootstrap.setup(Bootstrap.java:176) ~[elasticsearch-5.1.2.jar:5.1.2]
at org.elasticsearch.bootstrap.Bootstrap.init(Bootstrap.java:306) ~[elasticsearch-5.1.2.jar:5.1.2]
at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:121) ~[elasticsearch-5.1.2.jar:5.1.2]
... 6 more
  • 异常1解决方式:
在es-linux环境中,不允许使用root用户运行ElasticSearch,所以添加一个新的普通用户就可以了(linux命令如下)
1 groupadd es      -- 创建一个用户组(我使用的es作为组名)2 useradd -g es es   -- 创建一个用户(我使用es作为用户名,并加入到es组里面)3 passwd es       -- 为刚刚创建的es用户添加密码4 su es         -- 切换到es用户下5 $ElasticSearch_Home/bin/elasticsearch  --启动ElasticSearch
  • 异常2: failed to obtain lock on ...
 1 Caused by: java.io.IOException: failed to obtain lock on /bigdata/env/elasticsearch512/data/nodes/0 2     at org.elasticsearch.env.NodeEnvironment.<init>(NodeEnvironment.java:238) ~[elasticsearch-5.1.2.jar:5.1.2] 3     at org.elasticsearch.node.Node.<init>(Node.java:249) ~[elasticsearch-5.1.2.jar:5.1.2] 4     at org.elasticsearch.node.Node.<init>(Node.java:229) ~[elasticsearch-5.1.2.jar:5.1.2] 5     at org.elasticsearch.bootstrap.Bootstrap$6.<init>(Bootstrap.java:214) ~[elasticsearch-5.1.2.jar:5.1.2] 6     at org.elasticsearch.bootstrap.Bootstrap.setup(Bootstrap.java:214) ~[elasticsearch-5.1.2.jar:5.1.2] 7     at org.elasticsearch.bootstrap.Bootstrap.init(Bootstrap.java:306) ~[elasticsearch-5.1.2.jar:5.1.2] 8     at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:121) ~[elasticsearch-5.1.2.jar:5.1.2] 9     ... 6 more10 Caused by: java.nio.file.AccessDeniedException: /bigdata/env/elasticsearch512/data/nodes/0/node.lock11     at sun.nio.fs.UnixException.translateToIOException(UnixException.java:84) ~[?:?]12     at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:102) ~[?:?]13     at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:107) ~[?:?]14     at sun.nio.fs.UnixFileSystemProvider.newFileChannel(UnixFileSystemProvider.java:177) ~[?:?]15     at java.nio.channels.FileChannel.open(FileChannel.java:287) ~[?:1.8.0_181]16     at java.nio.channels.FileChannel.open(FileChannel.java:335) ~[?:1.8.0_181]17     at org.apache.lucene.store.NativeFSLockFactory.obtainFSLock(NativeFSLockFactory.java:113) ~[lucene-core-6.3.0.jar:6.3.0 a66a44513ee8191e25b477372094bfa846450316 - shalin - 2016-11-02 19:47:11]18     at org.apache.lucene.store.FSLockFactory.obtainLock(FSLockFactory.java:41) ~[lucene-core-6.3.0.jar:6.3.0 a66a44513ee8191e25b477372094bfa846450316 - shalin - 2016-11-02 19:47:11]19     at org.apache.lucene.store.BaseDirectory.obtainLock(BaseDirectory.java:45) ~[lucene-core-6.3.0.jar:6.3.0 a66a44513ee8191e25b477372094bfa846450316 - shalin - 2016-11-02 19:47:11]20     at org.elasticsearch.env.NodeEnvironment.<init>(NodeEnvironment.java:225) ~[elasticsearch-5.1.2.jar:5.1.2]21     at org.elasticsearch.node.Node.<init>(Node.java:249) ~[elasticsearch-5.1.2.jar:5.1.2]22     at org.elasticsearch.node.Node.<init>(Node.java:229) ~[elasticsearch-5.1.2.jar:5.1.2]23     at org.elasticsearch.bootstrap.Bootstrap$6.<init>(Bootstrap.java:214) ~[elasticsearch-5.1.2.jar:5.1.2]24     at org.elasticsearch.bootstrap.Bootstrap.setup(Bootstrap.java:214) ~[elasticsearch-5.1.2.jar:5.1.2]25     at org.elasticsearch.bootstrap.Bootstrap.init(Bootstrap.java:306) ~[elasticsearch-5.1.2.jar:5.1.2]26     at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:121) ~[elasticsearch-5.1.2.jar:5.1.2]27     ... 6 more
  • 异常2解决方式:
由于上面使用root创建的es目录,导致ElasticSearch安装目录的所属用户和所属组都是root,现在使用es用户去启动elasticsearch命令,导致没有权限获取node.lock
最直接的解决方式: 将es所有目录更改所属用户到es下就可以了
1 chown -R es:es ./elasticsearch5122     --(elasticsearch512是我对es安装目录的命名)3     --(-R选项: 将elasticsearch512目录及内部所有子目录都更改所属用户)4     --(es:es  代表:  用户:用户组)
  • 异常3: BindTransportException[Failed to bind to [9300-9400]]
 1 [WARN ][o.e.b.ElasticsearchUncaughtExceptionHandler] [node-2] uncaught exception in thread [main] 2 org.elasticsearch.bootstrap.StartupException: BindTransportException[Failed to bind to [9300-9400]]; nested: BindException[Cannot assign requested address]; 3     at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:125) ~[elasticsearch-5.1.2.jar:5.1.2] 4     at org.elasticsearch.bootstrap.Elasticsearch.execute(Elasticsearch.java:112) ~[elasticsearch-5.1.2.jar:5.1.2] 5     at org.elasticsearch.cli.SettingCommand.execute(SettingCommand.java:54) ~[elasticsearch-5.1.2.jar:5.1.2] 6     at org.elasticsearch.cli.Command.mainWithoutErrorHandling(Command.java:122) ~[elasticsearch-5.1.2.jar:5.1.2] 7     at org.elasticsearch.cli.Command.main(Command.java:88) ~[elasticsearch-5.1.2.jar:5.1.2] 8     at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:89) ~[elasticsearch-5.1.2.jar:5.1.2] 9     at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:82) ~[elasticsearch-5.1.2.jar:5.1.2]10 Caused by: org.elasticsearch.transport.BindTransportException: Failed to bind to [9300-9400]11     at org.elasticsearch.transport.TcpTransport.bindToPort(TcpTransport.java:636) ~[elasticsearch-5.1.2.jar:5.1.2]12     at org.elasticsearch.transport.TcpTransport.bindServer(TcpTransport.java:601) ~[elasticsearch-5.1.2.jar:5.1.2]13     at org.elasticsearch.transport.netty4.Netty4Transport.doStart(Netty4Transport.java:182) ~[?:?]14     at org.elasticsearch.common.component.AbstractLifecycleComponent.start(AbstractLifecycleComponent.java:69) ~[elasticsearch-5.1.2.jar:5.1.2]15     at org.elasticsearch.transport.TransportService.doStart(TransportService.java:188) ~[elasticsearch-5.1.2.jar:5.1.2]16     at org.elasticsearch.common.component.AbstractLifecycleComponent.start(AbstractLifecycleComponent.java:69) ~[elasticsearch-5.1.2.jar:5.1.2]17     at org.elasticsearch.node.Node.start(Node.java:577) ~[elasticsearch-5.1.2.jar:5.1.2]18     at org.elasticsearch.bootstrap.Bootstrap.start(Bootstrap.java:234) ~[elasticsearch-5.1.2.jar:5.1.2]19     at org.elasticsearch.bootstrap.Bootstrap.init(Bootstrap.java:308) ~[elasticsearch-5.1.2.jar:5.1.2]20     at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:121) ~[elasticsearch-5.1.2.jar:5.1.2]21     ... 6 more22 Caused by: java.net.BindException: Cannot assign requested address23     at sun.nio.ch.Net.bind0(Native Method) ~[?:?]24     at sun.nio.ch.Net.bind(Net.java:433) ~[?:?]25     at sun.nio.ch.Net.bind(Net.java:425) ~[?:?]26     at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:223) ~[?:?]27     at io.netty.channel.socket.nio.NioServerSocketChannel.doBind(NioServerSocketChannel.java:127) ~[?:?]28     at io.netty.channel.AbstractChannel$AbstractUnsafe.bind(AbstractChannel.java:554) ~[?:?]29     at io.netty.channel.DefaultChannelPipeline$HeadContext.bind(DefaultChannelPipeline.java:1258) ~[?:?]30     at io.netty.channel.AbstractChannelHandlerContext.invokeBind(AbstractChannelHandlerContext.java:512) ~[?:?]31     at io.netty.channel.AbstractChannelHandlerContext.bind(AbstractChannelHandlerContext.java:497) ~[?:?]32     at io.netty.channel.DefaultChannelPipeline.bind(DefaultChannelPipeline.java:980) ~[?:?]33     at io.netty.channel.AbstractChannel.bind(AbstractChannel.java:250) ~[?:?]34     at io.netty.bootstrap.AbstractBootstrap$2.run(AbstractBootstrap.java:363) ~[?:?]35     at io.netty.util.concurrent.AbstractEventExecutor.safeExecute(AbstractEventExecutor.java:163) ~[?:?]36     at io.netty.util.concurrent.SingleThreadEventExecutor.runAllTasks(SingleThreadEventExecutor.java:418) ~[?:?]37     at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:454) ~[?:?]38     at io.netty.util.concurrent.SingleThreadEventExecutor$5.run(SingleThreadEventExecutor.java:873) ~[?:?]39     at java.lang.Thread.run(Thread.java:748) [?:1.8.0_181]
  • 异常3解决方式
1 network.host: 0.0.0.0     -- 绑定IP到本机
  • 启动失败1:
1 ERROR: bootstrap checks failed2 max file descriptors [65535] for elasticsearch process is too low, increase to at least [65536]
  • 启动失败1解决方式:
  原因: elasticsearch 能够打开的最大句柄数为65536,这个数量不能满足最低65536的要求,更改一下可以linux的配置文件解决
 vi /etc/security/limits.conf  root soft nofile 65535 root hard nofile 65535 * soft nofile   --将所有用户能够打开的最大句柄数都修改为65536 * hard nofile
  • 启动失败2:
  原因: 直接翻译就是虚拟内存65530太低
1 max virtual memory areas vm.max_map_count [65530] is too low, increase to at least [262144]
  • 启动失败2解决方式:
1 vi /etc/sysctl.conf2 vm.max_map_count=6553603 按Esc-->按Shift+:-->输入wq 保存退出4 sysctl -p       -- 命令意思: 从指定的文件加载系统参数,如不指定即从/etc/sysctl.conf中加载
  • 从节点加入集群失败1:  failed to send join request to master
 [INFO ][o.e.d.z.ZenDiscovery     ] [node-2] failed to send join request to master [{node-1}{7Wy1WO3fQZmBDwcDQRDh2Q}{kqmtZtjiSuC79opYfj1jzg}{172.31.87.193}{172.31.87.193:9300}],
  reason [RemoteTransportException[[node-1][172.31.87.193:9300][internal:discovery/zen/join]];
nested: IllegalArgumentException[ {node-2}{7Wy1WO3fQZmBDwcDQRDh2Q}{HW7YhCEBRbGti1ra7WXTYg}{172.31.87.192}{172.31.87.192:9300},
 {node-1}{7Wy1WO3fQZmBDwcDQRDh2Q}{kqmtZtjiSuC79opYfj1jzg}{172.31.87.193}{172.31.87.193:9300} ]; ]
  • 从节点加入集群失败1解决方式:
出错原因: 该节点(node2)的安装文件都是妥妥的在主节点(node1)拷贝过来的,所以,数据文件(data文件夹下面的数据也拷贝过来了),按照抛错意思,可能是里面保存了node1的id等信息导致了冲突
 rm -rf /data/*    --删除data目录下面的从Node1考来的所有数据
 在node2节点上重启elasticsearch
 在node1主节点上会发现如下状态信息:  [node-1]  {{node-2}{Qg2j8WLgQpy10mzs-r42Eg}{85mIKdCRRG-BAb42g8YhDg}{172.31.87.192}{172.31.87.192:9300},}, reason: zen-disco-node-join[{node-2}{Qg2j8WLgQpy10mzs-r42Eg}{85mIKdCRRG-BAb42g8YhDg}{172.31.87.192}{172.31.87.192:9300}] [2018-08-04T23:40:25,006][INFO ][o.e.c.r.a.AllocationService] [node-1]   [] to [] (reason: [shards started [[megacorp][4]] ...]).
JavaAPI开发异常1:  NoNodeAvailableException: None of the configured nodes are available
 1 Exception in thread "main" NoNodeAvailableException[None of the configured nodes are available: [{#transport#-1}{9zZ22lWuQpKTZlroNRCrNg}{47.105.116.201}{47.105.116.201:9300}]] 2     at org.elasticsearch.client.transport.TransportClientNodesService.ensureNodesAreAvailable(TransportClientNodesService.java:328) 3     at org.elasticsearch.client.transport.TransportClientNodesService.execute(TransportClientNodesService.java:226) 4     at org.elasticsearch.client.transport.TransportProxyClient.execute(TransportProxyClient.java:59) 5     at org.elasticsearch.client.transport.TransportClient.doExecute(TransportClient.java:345) 6     at org.elasticsearch.client.support.AbstractClient.execute(AbstractClient.java:403) 7     at org.elasticsearch.action.ActionRequestBuilder.execute(ActionRequestBuilder.java:80) 8     at org.elasticsearch.action.ActionRequestBuilder.execute(ActionRequestBuilder.java:54) 9     at org.elasticsearch.action.ActionRequestBuilder.get(ActionRequestBuilder.java:62)10     at com.nengli51.es.data.Demo.main(Demo.java:23)
异常原因: 通过 TransportClient 连接集群时,需要配置 cluster.name 信息,出错原因可能是 使用Settings.EMPTY选项,或者使用了错误的Setting配置,导致连接集群失败
 Settings settings = Settings.builder().put("cluster.name", "estest").build(); TransportClient client =  PreBuiltTransportClient();   //这里是连接配置了cluster.name的集群的连接方式,如果你的ElasticSearch集群使用的默认集群名字(压根就没设置elasticsearch)那么直接使用下面的
* TransportClient client = new PreBuiltTransportClient();
