GaussDB 100 游标---带参游标的应用示例
骑着上帝去流浪 发表于 2019/07/25 18:58:03 2019/07/25
【摘要】 示例1,带参数的游标; create or replace procedure test_getparameters (c1 in varchar2 , c2 in int ) is cursor getsome(c5 varchar2 ,c6 int ) is select * from test_02 where col1 = c5...
示例1,带参数的游标;
 is
       select * from test_02  where col1 = c5 and col2 =c6  order by id ;
      corsor_record  getsome%rowtype ;
 begin
      open getsome(c1 ,c2 );
      loop
           fetch getsome into  corsor_record ;
           exit when getsome%notfound ;
           dbms_output.put_line('result is '||'-----'|| corsor_record.id ||corsor_record.col1||'-----'||corsor_record.col2);
  end loop ;
      close getsome ;
 end;
 说明;(1)带参数的游标在open时须传参,在fetch时不传参。
            (2)游标名%notfoud 参数在游标获取不到参数时,返回false;
            (3)loop循环,通过exit when条件跳出循环。
