Python 安装psutil包遇到的问题
tscswcn 发表于 2019/02/09 00:24:55 2019/02/09
【摘要】 [root@node-1 gcc-4.8.2]# sudo pip install --user psutilDEPRECATION: Python 2.7 will reach the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 won't be maintained af...
DEPRECATION: Python 2.7 will reach the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 won't be maintained after that date. A future version of pip will drop support for Python 2.7.
Collecting psutil
  Using cached https://files.pythonhosted.org/packages/6e/a0/833bcbcede5141cc5615e50c7cc5b960ce93d9c9b885fbe3b7d36e48a2d4/psutil-5.5.0.tar.gz
Building wheels for collected packages: psutil
  Building wheel for psutil (setup.py) ... error
  Complete output from command /usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-uAr_gl/psutil/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-vbL04e --python-tag cp27:
  /usr/lib64/python2.7/distutils/dist.py:267: UserWarning: Unknown distribution
option: 'python_requires'
    warnings.warn(msg)
  running bdist_wheel
  running build
  running build_py
  creating build
  creating build/lib.linux-x86_64-2.7
  creating build/lib.linux-x86_64-2.7/psutil
  copying psutil/_compat.py -> build/lib.linux-x86_64-2.7/psutil
  copying psutil/_psposix.py -> build/lib.linux-x86_64-2.7/psutil
  copying psutil/_exceptions.py -> build/lib.linux-x86_64-2.7/psutil
  copying psutil/_psaix.py -> build/lib.linux-x86_64-2.7/psutil
  copying psutil/_pssunos.py -> build/lib.linux-x86_64-2.7/psutil
  copying psutil/_pslinux.py -> build/lib.linux-x86_64-2.7/psutil
  copying psutil/_common.py -> build/lib.linux-x86_64-2.7/psutil
  copying psutil/__init__.py -> build/lib.linux-x86_64-2.7/psutil
  copying psutil/_psosx.py -> build/lib.linux-x86_64-2.7/psutil
  copying psutil/_psbsd.py -> build/lib.linux-x86_64-2.7/psutil
  copying psutil/_pswindows.py -> build/lib.linux-x86_64-2.7/psutil
  creating build/lib.linux-x86_64-2.7/psutil/tests
  copying psutil/tests/test_linux.py -> build/lib.linux-x86_64-2.7/psutil/tests
  copying psutil/tests/test_bsd.py -> build/lib.linux-x86_64-2.7/psutil/tests
  copying psutil/tests/test_aix.py -> build/lib.linux-x86_64-2.7/psutil/tests
  copying psutil/tests/test_windows.py -> build/lib.linux-x86_64-2.7/psutil/tests
  copying psutil/tests/test_memory_leaks.py -> build/lib.linux-x86_64-2.7/psutil/tests
  copying psutil/tests/__main__.py -> build/lib.linux-x86_64-2.7/psutil/tests
  copying psutil/tests/test_process.py -> build/lib.linux-x86_64-2.7/psutil/tests
  copying psutil/tests/test_system.py -> build/lib.linux-x86_64-2.7/psutil/tests
  copying psutil/tests/test_posix.py -> build/lib.linux-x86_64-2.7/psutil/tests
  copying psutil/tests/test_connections.py -> build/lib.linux-x86_64-2.7/psutil/tests
  copying psutil/tests/test_contracts.py -> build/lib.linux-x86_64-2.7/psutil/tests
  copying psutil/tests/test_misc.py -> build/lib.linux-x86_64-2.7/psutil/tests
  copying psutil/tests/test_unicode.py -> build/lib.linux-x86_64-2.7/psutil/tests
  copying psutil/tests/__init__.py -> build/lib.linux-x86_64-2.7/psutil/tests
  copying psutil/tests/test_osx.py -> build/lib.linux-x86_64-2.7/psutil/tests
  copying psutil/tests/test_sunos.py -> build/lib.linux-x86_64-2.7/psutil/tests
  running build_ext
  building 'psutil._psutil_linux' extension
  creating build/temp.linux-x86_64-2.7
  creating build/temp.linux-x86_64-2.7/psutil
  gcc -pthread -fno-strict-aliasing -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -DNDEBUG -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -fPIC -DPSUTIL_POSIX=1 -DPSUTIL_VERSION=550 -DPSUTIL_LINUX=1 -I/usr/include/python2.7 -c psutil/_psutil_common.c -o build/temp.linux-x86_64-2.7/psutil/_psutil_common.o
  psutil/_psutil_common.c:9:20: fatal error: Python.h: No such file or directory
   #include <Python.h>
  compilation terminated.
  error: command 'gcc' failed with exit status 1
  Failed building wheel for psutil
  Running setup.py clean for psutil
Failed to build psutil
Installing collected packages: psutil
  Running setup.py install for psutil ... error
    Complete output from command /usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-uAr_gl/psutil/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-Tj6uEX/install-record.txt --single-version-externally-managed --compile --user --prefix=:
    /usr/lib64/python2.7/distutils/dist.py:267: UserWarning: Unknown distribution option: 'python_requires'
      warnings.warn(msg)
    running install
    running build
    running build_py
    creating build
    running build_ext
     #include <Python.h>
Command "/usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-uAr_gl/psutil/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))"
install --record /tmp/pip-record-Tj6uEX/install-record.txt --single-version-externally-managed --compile --user --prefix=" failed with error code 1 in /tmp/pip-install-uAr_gl/psutil/
后通过 如下 解决
 yum install python-devel -y
Loaded plugins: langpacks, versionlock
Resolving Dependencies
--> Running transaction check
---> Package python-devel.x86_64 0:2.7.5-76.el7 will be installed
--> Processing Dependency: python(x86-64) = 2.7.5-76.el7 for package: python-devel-2.7.5-76.el7.x86_64
---> Package python.x86_64 0:2.7.5-48.el7 will be updated
---> Package python.x86_64 0:2.7.5-76.el7 will be an update
--> Processing Dependency: python-libs(x86-64) = 2.7.5-76.el7 for package: python-2.7.5-76.el7.x86_64
---> Package python-libs.x86_64 0:2.7.5-48.el7 will be updated
---> Package python-libs.x86_64 0:2.7.5-76.el7 will be an update
--> Finished Dependency Resolution
Dependencies Resolved
 Package              Arch           Version                 Repository    Size
Installing:
 python-devel         x86_64         2.7.5-76.el7            base         398 k
Updating for dependencies:
 python               x86_64         2.7.5-76.el7            base          94 k
 python-libs          x86_64         2.7.5-76.el7            base         5.6 M
Transaction Summary
Install  1 Package
Upgrade             ( 2 Dependent packages)
Total download size: 6.1 M
Downloading packages:
Delta RPMs disabled because /usr/bin/applydeltarpm not installed.
(1/3): python-devel-2.7.5-76.el7.x86_64.rpm                | 398 kB   00:00
(2/3): python-2.7.5-76.el7.x86_64.rpm                      |  94 kB   00:00
(3/3): python-libs-2.7.5-76.el7.x86_64.rpm                 | 5.6 MB   00:00
Total                                               38 MB/s | 6.1 MB  00:00
Running transaction test
Transaction test succeeded
Running transaction
  Updating   : python-libs-2.7.5-76.el7.x86_64                              1/5
  Updating   : python-2.7.5-76.el7.x86_64                                   2/5
  Installing : python-devel-2.7.5-76.el7.x86_64                             3/5
  Cleanup    : python-2.7.5-48.el7.x86_64                                   4/5
  Cleanup    : python-libs-2.7.5-48.el7.x86_64                              5/5
  Verifying  : python-2.7.5-76.el7.x86_64                                   1/5
  Verifying  : python-devel-2.7.5-76.el7.x86_64                             2/5
  Verifying  : python-libs-2.7.5-76.el7.x86_64                              3/5
  Verifying  : python-2.7.5-48.el7.x86_64                                   4/5
  Verifying  : python-libs-2.7.5-48.el7.x86_64                              5/5
Installed:
Dependency Updated:
  python.x86_64 0:2.7.5-76.el7         python-libs.x86_64 0:2.7.5-76.el7
Complete!
Collecting psutil
  Building wheel for psutil (setup.py) ... done
  Stored in directory: /root/.cache/pip/wheels/23/6f/5a/f84c1790d7c9be43de2842cf8782fa84c9ec07e72b041d7251
Successfully built psutil
Successfully installed psutil-5.5.0
