今天总结一下我自建的自动化测试和数据展示平台的工作
蒋明明哥 发表于 2019/01/23 14:56:51 2019/01/23
【摘要】 今天总结一下我自建的自动化测试和数据展示平台的工作测试首先需要打包.打包和测试是一个比较繁琐的任务.之前我们持续集成中这些代码都是人工打包的.现在做成代码进行持续集成.持续集成能大大提高程序开发的速度.在bug发现和处理方面解决人力支出的部分.推动公司开发的速度.现在一个程序员薪水就是几万. 本次代码替代了ios程序员和安卓程序员 测试工程师.手工测试的部分.实乃杀价越活的必备良器.这段代码...
这段代码是windows下的打包程序
用批处理语言写的
set /a TODAY=%date:~0,4%%date:~5,2%%date:~8,2%
set _TIME=%time:~0,8%
set CURRENTTIME=%_time::=%
set CURRENTTIME=%CURRENTTIME: =0%
set MYDIR=%TODAY%_%CURRENTTIME%
echo %MYDIR%
d:
cd /laicunba_android_studio
rd /q/s D:\laicunba_android_studio\app\build\outputs\apk
copy /y d:\bijiao1.txt d:\bijiao2.txt
svn cleanup
svn update>d:\bijiao1.txt
sed -i 's/minifyEnabled true/minifyEnabled false/g' D:\laicunba_android_studio\app\build.gradle
#sed -i 's/minifyEnabled false/minifyEnabled true/g' D:\laicunba_android_studio\app\build.gradle
svn log -v -l1 d:\laicunba_android_studio| grep  " 1 " |cut -d "|" -f 1|sed s/[[:space:]]//g>version.txt
for /f "delims=" %%a in (version.txt) do (
set version=%%a
echo !version!
set MYDIR=%version%_%TODAY%_%CURRENTTIME%
set MYNAME="%version%_Laicunba_insider_%TODAY%_%CURRENTTIME%.apk"
fc /b d:\bijiao1.txt d:\bijiao2.txt &&echo 相同||gradle clean&&gradle assembleRelease&&mkdir E:\nginx\html\%MYDIR%&&cd D:\laicunba_android_studio\app\build\outputs\apk&&dir /b *_2*.apk > xsxxb.tmp&&for /f "eol=| delims=|" %%i in (xsxxb.tmp) do (set MYNAME=%version%_%%i&&copy "%%i" E:\nginx\html\%MYDIR%\%version%_%%i)
rem gradle :app:assembleLaicunba_insiderRelease&&cd D:\laicunba_android_studio\app\build\outputs\apk&&dir /b laicunba*.apk > xsxxb.tmp&&for /f "eol=| delims=|" %%i in (xsxxb.tmp) do (copy /y "%%i" E:\nginx\html\%version%_%%i&&copy /y "%%i" C:\Users\a\Downloads\r4650_laicunba_insider_20107_2.1.7.apk&&curl -F "file=@C:/Users/a/Downloads/r4650_laicunba_insider_20107_2.1.7.apk" -F "_api_key=c98d013b1a2cdf30410f7bbdbb2f6bfe" -F "uKey=123fe965b6f7a7a90cb2e88e5a2571a6" http://www.pgyer.com/apiv1/app/upload)
rem C:\Users\a\Downloads\r4650_laicunba_insider_20107_2.1.7.apk
rem copy /y D:\laicunba_android_studio\app\build\outputs\apk\app-laicunba_insider-release-unaligned.apk  E:\nginx\html\%MYNAME%
if errorlevel 1 exit
forfiles /p E:\nginx\html\ /m *.apk -d -60 /c "cmd /c del /f @path"
ios的自动化打包代码
cd /Users/mingjiang/Desktop/ComeSave1.22
rm ../ver2
mv ../ver1 ../ver2
svn update > ../ver1
diff ../ver1 ../ver2
if [ $? == 0 ]; then
   exit 0;
fi
xcodebuild -workspace ComeSave.xcworkspace -scheme ComeSave -configuration Release -sdk iphoneos10.0 clean
xcodebuild -workspace ComeSave.xcworkspace -scheme ComeSave -configuration Release -sdk iphoneos10.0 build
xcrun -sdk iphoneos packageapplication -v /Users/mingjiang/Library/Developer/Xcode/DerivedData/ComeSave-clogwjmbprnvakdnwldlrhlxvtfc/Build/Products/Release-iphoneos/ComeSave.app -o ~/test.ipa
xcrun -sdk iphoneos PackageApplication -v build/Release-iphoneos/xxx.app -o build/Release-iphoneos/xxx.ipa
curl -F "file=@/Users/mingjiang/test.ipa" -F "_api_key=c98d013b1a2cdf30410f7bbdbb2f6bfe" -F "uKey=123fe965b6f7a7a90cb2e88e5a2571a6" http://www.pgyer.com/apiv1/app/upload
cp /Users/mingjiang/test.ipa /usr/local/var/www
打包完成后需要自动化测试
#!/usr/bin/python
# coding: UTF-8
#作者 蒋明
#作用 自动测试
#pip install pywinauto
#日期 2016-12-16
from selenium import webdriver
from selenium.webdriver.common.keys import Keys
import win32gui
import win32con
import re,time,platform,sys, getopt
import io
import sys
import urllib.request
apptestname=""
appname="c:\\Users\\a\\Downloads\\r4650_laicunba_insider_20107_2.1.7.apk"
def load(filename):
 # win32gui
 #dialog = win32gui.FindWindow('#32770', u'文件上传')  # 对话框
 dialog = win32gui.FindWindow('#32770', u'打开')  # 对话框
 ComboBoxEx32 = win32gui.FindWindowEx(dialog, 0, 'ComboBoxEx32', None)
 ComboBox = win32gui.FindWindowEx(ComboBoxEx32, 0, 'ComboBox', None)
 Edit = win32gui.FindWindowEx(ComboBox, 0, 'Edit', None)  # 上面三句依次寻找对象,直到找到输入框Edit对象的句柄
 button = win32gui.FindWindowEx(dialog, 0, 'Button', None)  # 确定按钮Button
 win32gui.SendMessage(Edit, win32con.WM_SETTEXT, None, filename)  # 往输入框输入绝对地址
 win32gui.SendMessage(dialog, win32con.WM_COMMAND, 1, button)  # 按button
 time.sleep(10)
def login():
 url="https://login.taobao.com/member/login.jhtml?redirectURL=https%3A%2F%2Flogin.taobao.com%2Fjump%3Ftarget%3Dhttp%253A%252F%252Fmqc.yunos.com%252FtestManager.htm"
 d.set_window_size(1024, 768)
 d.get(url)
 time.sleep(1)
 d.find_element_by_css_selector("#J_Quick2Static").click()
 d.find_element_by_css_selector("#TPL_username_1").send_keys("91111761@qq.com")
 d.find_element_by_css_selector("#TPL_password_1").send_keys("81110.")
 d.find_element_by_css_selector("#J_SubmitStatic").click()
 time.sleep(5)
def xingneng():
 url="http://mqc.yunos.com/performance.htm?spm=0.0.0.0.Eu5mDe"
 d.get(url)
 d.find_element_by_css_selector("#chooseApp > div:nth-child(2) > button:nth-child(4)").click()
 time.sleep(1)
 load(appname)
 d.find_element_by_css_selector("#Step-two-next").click()
 time.sleep(1)
