《重新定义Spring Cloud实战》——2.3.2 REST API实例
华章计算机 发表于 2019/06/04 14:21:38 2019/06/04
【摘要】 本书摘自《重新定义Spring Cloud实战》——书中第2章,第2.3.2节,作者是许进、叶志远、钟尊发、蔡波斯、方志朋、郭芳碧、朱德明。
2.3.2 REST API实例
1.查询所有应用实例
HTTP/1.1 200
Content-Type: application/xml
Transfer-Encoding: chunked
Date: Tue, 19 Jun 2018 06:22:56 GMT
<applications>
    <versions__delta>1</versions__delta>
    <apps__hashcode>UP_1_</apps__hashcode>
    <application>
        <name>DEMO-CLIENT1</name>
        <instance>
            <instanceId>10.2.238.223:demo-client1:8081</instanceId>
            <hostName>10.2.238.223</hostName>
            <app>DEMO-CLIENT1</app>
            <ipAddr>10.2.238.223</ipAddr>
            <status>UP</status>
            <overriddenstatus>UNKNOWN</overriddenstatus>
            <port enabled="true">8081</port>
            <securePort enabled="false">443</securePort>
            <countryId>1</countryId>
            <dataCenterInfo class="com.netflix.appinfo.InstanceInfo$DefaultDataCenterInfo">
                <name>MyOwn</name>
            </dataCenterInfo>
            <leaseInfo>
                <renewalIntervalInSecs>30</renewalIntervalInSecs>
                <durationInSecs>90</durationInSecs>
                <registrationTimestamp>1529377552795</registrationTimestamp>
        <lastRenewalTimestamp>1529389437739</lastRenewalTimestamp>
                <evictionTimestamp>0</evictionTimestamp>
                <serviceUpTimestamp>1529377552795</serviceUpTimestamp>
            </leaseInfo>
            <metadata>
                <management.port>8081</management.port>
            </metadata>
            <homePageUrl>http://10.2.238.223:8081/</homePageUrl>
<statusPageUrl>http://10.2.238.223:8081/actuator/info</statusPageUrl>
<healthCheckUrl>http://10.2.238.223:8081/actuator/health</healthCheckUrl>
            <vipAddress>demo-client1</vipAddress>
            <secureVipAddress>demo-client1</secureVipAddress>
<isCoordinatingDiscoveryServer>false</isCoordinatingDiscoveryServer>
            <lastUpdatedTimestamp>1529377552795</lastUpdatedTimestamp>
            <lastDirtyTimestamp>1529377552665</lastDirtyTimestamp>
            <actionType>ADDED</actionType>
        </instance>
    </application>
</applications>
2.根据appId查询
curl -i http://localhost:8761/eureka/apps/demo-client1
HTTP/1.1 200
Date: Tue, 19 Jun 2018 06:28:34 GMT
<application>
    <instance>
        <status>UP</status>
            <name>MyOwn</name>
        </dataCenterInfo>
        <leaseInfo>
            <lastRenewalTimestamp>1529389797866</lastRenewalTimestamp>
        </leaseInfo>
        <metadata>
        </metadata>
    </instance>
</application>
查询不到则返回如下结果:
HTTP/1.1 404
Content-Length: 0
Date: Tue, 19 Jun 2018 06:38:14 GMT
3.根据appId及instanceId查询
查询出数据时跟上面的返回一致,查找不到则返回如下结果:
curl -i http://localhost:8761/eureka/apps/demo-client1/notfound
HTTP/1.1 404
Content-Length: 0
Date: Tue, 19 Jun 2018 06:33:42 GMT
4.根据instanceId查询
curl -i http://localhost:8761/eureka/instances/10.2.238.223:demo-client1:8081
HTTP/1.1 200
Date: Tue, 19 Jun 2018 06:36:09 GMT
<instance>
    <status>UP</status>
        <name>MyOwn</name>
    </dataCenterInfo>
    <leaseInfo>
        <lastRenewalTimestamp>1529390248015</lastRenewalTimestamp>
    </leaseInfo>
    <metadata>
    </metadata>
</instance>
查询不到则返回如下结果:
curl -i http://localhost:8761/eureka/instances/demo-instance-id
HTTP/1.1 404
Content-Length: 0
Date: Tue, 19 Jun 2018 06:36:51 GMT
5.注册新应用实例
xml格式提交的实例如下:
curl -i -H "Content-Type: application/xml" -H "Content-Length: 773" -H "Accept-Encoding: gzip" -X POST -d '<instance>
    <instanceId>client2:8082</instanceId>
    <hostName>127.0.0.1</hostName>
    <app>CLIENT2</app>
    <ipAddr>127.0.0.1</ipAddr>
    <status>UP</status>
    <port enabled="true">8082</port>
    <securePort enabled="false">7002</securePort>
        <name>MyOwn</name>
    </dataCenterInfo>
    <metadata class="java.util.Collections$EmptyMap"/>
    <vipAddress>client2</vipAddress>
    <secureVipAddress>client2</secureVipAddress>
    <lastUpdatedTimestamp>1529397327986</lastUpdatedTimestamp>
    <lastDirtyTimestamp>1529397327986</lastDirtyTimestamp>
</instance>' http://localhost:8761/eureka/apps/client2
HTTP/1.1 204
Date: Tue, 19 Jun 2018 08:35:59 GMT
json格式提交的实例如下:
curl -i -H "Content-Type: application/json" -X POST -d '{
    "instance": {
        "instanceId": "client2:8082",
        "app": "client2",
        "appGroupName": null,
        "ipAddr": "127.0.0.1",
        "sid": "na",
        "homePageUrl": null,
        "statusPageUrl": null,
        "healthCheckUrl": null,
        "secureHealthCheckUrl": null,
        "vipAddress": "client2",
        "secureVipAddress": "client2",
        "countryId": 1,
        "dataCenterInfo": {
            "@class": "com.netflix.appinfo.InstanceInfo$DefaultDataCenterInfo",
            "name": "MyOwn"
        "hostName": "127.0.0.1",
        "status": "UP",
        "leaseInfo": null,
        "isCoordinatingDiscoveryServer": false,
        "lastUpdatedTimestamp": 1529391461000,
        "lastDirtyTimestamp": 1529391461000,
        "actionType": null,
        "asgName": null,
        "overridden_status": "UNKNOWN",
        "port": {
            "$": 8082,
            "@enabled": "true"
        "securePort": {
            "$": 7002,
            "@enabled": "false"
        "metadata": {
            "@class": "java.util.Collections$EmptyMap"
}' http://localhost:8761/eureka/apps/client2
HTTP/1.1 204
Date: Tue, 19 Jun 2018 06:58:18 GMT
6.注销应用实例
curl -i -X DELETE http://localhost:8761/eureka/apps/client2/client2:8082
HTTP/1.1 200
Content-Length: 0
Date: Tue, 19 Jun 2018 06:59:31 GMT
7.暂停/下线应用实例
成功则返回:
curl -i -X PUT http://localhost:8761/eureka/apps/demo-client1/10.2.238.223:demo-client1:8081/status\?value\=OUT_OF_SERVICE
HTTP/1.1 200
Content-Length: 0
Date: Tue, 19 Jun 2018 07:12:24 GMT
此时Eureka界面示例如图2-3所示。
图2-3 下线服务时Eureka界面展示示例
找不到该实例返回:
HTTP/1.1 404
Content-Length: 0
Date: Tue, 19 Jun 2018 07:11:17 GMT
8.恢复应用实例
curl -i -X DELETE http://localhost:8761/eureka/apps/demo-client1/10.2.238.223:demo-client1:8081/status
HTTP/1.1 200
Content-Length: 0
Date: Tue, 19 Jun 2018 07:14:03 GMT
9.应用实例发送心跳
HTTP/1.1 200
Content-Length: 0
Date: Tue, 19 Jun 2018 07:16:38 GMT
10.修改应用实例元数据
curl -i -X PUT http://localhost:8761/eureka/apps/demo-client1/10.2.238.223:demo-client1:8081/metadata\?profile\=canary
HTTP/1.1 200
Content-Length: 0
Date: Tue, 19 Jun 2018 07:18:18 GMT
设置metadata,其中key为proflie,value为canary。
